Old 10-02-2012, 04:59 PM   #5686
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,602
X versus Dakar
While not perfect, the X is a pretty reliable bike. When you take out the numerous battery failures (which got me too), the issues are far less extensive.
Performance-wise, the X can basically do everything the Dakar can do, but do it better.
HOWEVER -
The Dakar is basically done when you roll it off the showroom floor. It has great range, whereas you will be re-filling the X every 100 miles or so until you spend some money more fuel capacity.
The Dakar can do two up right out of the box. Passenger pegs for the X are expensive and I would hate to be a passenger on the back of the X seat as well as trying to get on.
The X has a 37" seat height. That can be a bit intimidating for some. The Dakar is much lower and has factory options for lowering it further.
Your comparison to refined KLR is spot on. If you were wishing for more performance with your KLR, then the X will give you that. But if you liked the turn-key adventure readiness of the KLR, the Dakar is probably the better bike.
OOOOOOOOOOOOOOORRRRRRRRR . . . the new Husky 650 Terra may be a perfect compromise for you.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 10-02-2012, 06:06 PM   #5687
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,383
Thanks Marc. I'll have to read up on that. Only major issue there is I want to go used. I thought maybe TE610, but I'd like another BMW. Decisions, decisions. I did show the wife both and she likes the Dakar. Between that and the X, the Dakar is definitely closer to the KLR.
2013 Yamaha XT250 * 2005 BMW R1200ST
Royal Tiger is offline   Reply With Quote
Old 10-02-2012, 07:43 PM   #5688
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 165
X- country!
You might consider the XChallenge's fine sibling the XCountry. Comes with passenger pegs. (Just add TKC-80's, xtank, HID headlight and a great basin bag.)
Mine has stock suspension and 19" front wheel (wha?) but I just did most of the WABDR (dot com) plus another thousand miles of dirt in British Columbia. A 250-lb bike might have been less demanding on the dirt but not the slab between dirt chapters.
I'm a pencil-necked whiner but I honestly think there's no better compromise for doing both freeway and steep rutted rocky sandy crap "roads" that get you to fantastic places.
Yukon Ho! is online now   Reply With Quote
Old 10-02-2012, 10:30 PM   #5689
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Maybe you shpuld just pick a new Husqvarna TR650 Terra :):):) with almost same engine as Dakar and g650x...but then weight and offroad capabilities will be close to Dakar ones
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 10-03-2012, 07:05 AM   #5690
bens109
Oddometer: 47
Hi guys,
I'm just after a quick bit of information, hopefully someone can sort me out. I need to know the interior diameter of the radiator hoses on the x-ch in order to install a temp gauge, does anyone know it or have a spare hose laying around they could measure?
Cheers!
bens109 is offline   Reply With Quote
Old 10-03-2012, 07:13 AM   #5691
slide
A nation in despair
Oddometer: 21,122
What does the Terra weigh?
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 10-03-2012, 07:56 AM   #5692
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Out of my head 167 kgs (I'll look it up)
[edit] 368 lbs dry / 410 wet = 167 / 186 kgs
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 10-03-2012, 08:00 AM   #5693
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
[edit] I found 368 lbs dry / 410 wet = 167 / 186 kgs
Xtankteam™
Old 10-03-2012, 12:14 PM   #5694
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,383
The numbers I saw on MCN's chart were 369lbs wet for the X and 430lbs wet for the Dakar. What advantages would the Tera have over the Dakar? Better suspension?
Old 10-03-2012, 12:17 PM   #5695
slide
A nation in despair
Oddometer: 21,122
Yeah, I figured that. A bit less then the KLR. Thanks.
Old 10-03-2012, 06:10 PM   #5696
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,602
20+ pounds less weight and 5 extra horses, about $1500 less (vs a new Sertao), but a lesser warranty (1yr vs 3 yrs) and I would assume slightly less range.
Marc
07 XChallenge
Old 10-03-2012, 08:58 PM   #5697
aussiestrider
aussiestrider's Avatar
Oddometer: 91
X challenge front brake pad change ?
G'Day guys, sorry to change threads here. (I couldn't find this in the forum). How do I remove the pin in the Brembo caliper that holds the brake pads in place? It looks like it probably needs to be tapped out with a punch/drift and a hammer, but maybe it's threaded?
G'Dave
Transplanted Aussie - Argle Argle
2011 R1200GS
Previous rides: ST1300; G650Xch; KLR650; ST1100; WR250F; K100TIC; K100RS; K75s; R100RS; R100/7; K100; XV1000; GS450s; GT250
aussiestrider is offline   Reply With Quote
Old 10-03-2012, 11:42 PM   #5698
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Punch and hammer will do the job (from the wheelside).
Don't forget to remove the spring-clip first
Xtankteam™
Old 10-04-2012, 02:55 PM   #5699
The Jester
The Jester's Avatar
Oddometer: 845
Originally Posted by bens109 View Post
Hi guys,
Cheers!
22mm
If you track down a temp gauge please log the details. I want to keep an eye on mine as I have recently fitted a larger radiator without the stat.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 10-04-2012, 03:13 PM   #5700
kito
Oddometer: 278
what about fitting the trail tech . i think they have a temp sensor in a 22mm fitting
kito is offline   Reply With Quote
Times are GMT -7.   It's 04:43 PM.
