Old 11-18-2006, 12:08 PM   #91
Micky
Geriatric Adventurer
Micky's Avatar
Oddometer: 79
Stranded whale comes to mind....
www.adventure.gs
"Growing old is compulsory... growing up is optional!"
Micky screwed with this post 12-08-2010 at 02:50 PM
Micky is offline   Reply With Quote
Old 11-18-2006, 12:37 PM   #92
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,539
About 1/2 hour earlier, there was section of about 20 fet of ice.
Mix that with a Dunlop D207, not a lot of speed, but the clutch was out, in third gear, and I got a nice highside for my trouble and recycled some plastic... Not a scratch to myself. But mangled the video camera in my tankbag. The bike lit in it's top.
Now the bad part of this is that I knew there would be ice up there and had planned on going another way. Didn't.
A bungi net, a couple feet of atheletic tape and we made it back to my garage.
Doesn't look all that bad, do it? No glass in that mirror on the right. Dented tank, dented frame... Crushed upper fairing, mid shattered and rashed. Bent brake lever, and smashed controls on the right. Rebuilt all the plastic and switch gear and rode the beast a 100,000 miles, then sold it.
Then there was this:
Went on this No Whimps ride. About two hours later a fat guy falls on me and knocks me and my bike over in the wet sand. Nobody got a picture.
I attempted this ride after spending the previous day at MotoVenture dirt school getting completely tired and whole body sore. I could barely move on the big pfig, but I had better skills than I had the previous weekend. Just not enough leg to hold my bike up against a little fat guy aon a big fat bike.
This is the first rest stop and probably some of the easiest road we saw all day. It was a fun ride, and I would have enjoyed it more, had I not been so sore, and maybe if I was on something smaller.
I did learn this though, never, ever go on a ride that is lead by some young kid on a real dirtbike. Or for that matter any old desert racer. For both these groups an easy ride is any ride that does not require emergency services, plaster or guns.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 11-18-2006, 05:07 PM   #93
brad21 OP
Farting in a Fan
brad21's Avatar
Oddometer: 3,589
...never, ever go on a ride that is lead by some young kid on a real dirtbike. Or for that matter any old desert racer. For both these groups an easy ride is any ride that does not require emergency services, plaster or guns.
Quote of the thread right there.
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
BRC Member #49252 JOIN TODAY! https://www.sharetrails.org/support/join-or-contribute
brad21 is offline   Reply With Quote
Old 11-19-2006, 11:47 PM   #94
Disquisitive Dave
Not so wise fool
Disquisitive Dave's Avatar
Oddometer: 457
Don't assume that just because you've been following a track that it will continue...
JT and I headed up to the Lefthand Canyon OHV area today (you know, where there are a gajillion jeeps and people shooting). Near the top, the beaten path suckers you into a small dead end mine complex, while the road to the top of the mountain sneaks off to the right. We took a break on the main tailings pile and JT asked about the road leading directly up. I said, "Oh it ends." I should have said "it ends in about 100 feet, around those trees... the road to the top is to the right." (I got suckered up the same road last year, but without the drama.) He thought I meant that it was a dead end at the top of the mountain (another 500 or so vertical feet up).
He got his gear on before me and said "I'm heading up." I said, "Fine, I'll be along in a minute." Then he headed up the sucker road. I figured that he just wanted to explore a bit. Fine I'll wait here, turning around up there was a little sketchy last time. I didn't remember the mine shaft.
At the end of the sucker road is another small tailings pile. For some reason, folks claw their way up it, then back down. Perhaps they assume the road continues. Anyway, it's steep and loose with roots sticking out. So JT got a run at it sort of diagonally, and pulled a bit of a wheelie in the process (as he likes to do). The grade switches from steep up to vertical down within a space that's difficult to stand on. So as his line of vision revealed his doom, he initiated an emergency eject maneuver.
From below I saw him burst up the base of the slope before my line of vision was blocked by trees. Then I hear a yell, follow by JT rolling back down the pile, sans bike. "Are you OK?!" Long pause. "Yeah, I think I messed up my bike though." As with pretty much all old mines around here, the shaft had been either filled or blocked near the top. The open portion was about only about 6 feet deep. As the good friend I am, I first went for my camera... only to find dead batteries. We resorted to the cell phone camera.
With the help of a length of webbing and a bit of grunting, the bike came up without too much fuss. Amazingly, the only visible carnage was a broken mirror mount. Ironic. He busted the very same mount in a loop-out not more than 5 miles from here earlier this fall. "You know, when you order a new one, maybe you should get more than one..."
Disquisitive Dave is offline   Reply With Quote
Old 11-20-2006, 09:42 AM   #95
sandiegoland
Adventure Boy®
sandiegoland's Avatar
Oddometer: 1,743
Amen brother...
Looks okay...
Not okay...
sandiegoland is offline   Reply With Quote
Old 11-20-2006, 11:43 AM   #96
sixer
I suffer from Ainrofilac
Oddometer: 1,220
"There are no such things as accidents—just two people competing for the same point on the space-time continuum."
Support your local Search and Rescue Teams.
sixer is offline   Reply With Quote
Old 11-20-2006, 11:49 AM   #97
Mike D
Corporate Cog
Mike D's Avatar
Oddometer: 1,333
Originally Posted by iDave
I've see nthis pic before, and the thing that always got me was that it appears the rear wheel is still turning?? Did someonw just crawl off, swim to safety, and let it run out gas while getting a tow rope?
Enquiring minds want to know..............
"There are dreams of love, life, and adventure in all of us. But we are also sadly filled with reasons why we shouldn't try. These reasons seem to protect us, but in truth they imprison us. They hold life at a distance. Life will be over sooner than we think. If we have bikes to ride and people to love, now is the time." -Elisabeth Kubler-Ross (1926-2004)
Help keep our trails open; join COHVCO
Mike D is offline   Reply With Quote
Old 11-26-2006, 02:32 PM   #98
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 564
I think it is an illusion.
muddy chain- looks like it is blurred, but really just mudcovered
muddy rocks- looks like churning water and mud around rear tire, but just muddy rocks.
I could be wrong.
"It's not a death machine, Mom, it's a LIFE machine" - a motorcyclist
Chadleys1 is offline   Reply With Quote
Old 12-02-2006, 06:29 PM   #99
brad21 OP
Farting in a Fan
brad21's Avatar
Oddometer: 3,589
20 years ago, sand dunes at Buttercup after some serious wind that made the dunes super soft. This is a re-enactment of my buddy going over the bars of his Husky.
Old 12-02-2006, 07:55 PM   #100
dakariste
Over and over the hill...
dakariste's Avatar
Oddometer: 551
YOu don't want to know.
400 pounds of bike does not reverse easily.
Everyone loves Sherwood Forest road. If you decide that slick as snot mud is not really to your liking for the next 28 miles just make a u turn. As long as you need a 45 minute aerobic workout.
And of course, my all time favorite bat idea :
dakariste is offline   Reply With Quote
Old 12-02-2006, 09:24 PM   #101
Trailryder42
Trailryder42's Avatar
Oddometer: 1,061
This is one of those steeper/knarlier than it looks pics. I'd been down this twice in the last several years. The 2nd time just wondering if I could do it again and if making it down successfully the 1st time wasn't a fluke. 2nd time was successful. No reason to try it a 3rd, nothing left to prove to myself, except that I'm still capable of doing something stupid and having a bad idea.
There's nothing I hate more than a forward endo.
Trailryder42 is offline   Reply With Quote
Old 12-03-2006, 04:37 AM   #102
Frane
Frane's Avatar
Oddometer: 16
Frane is offline   Reply With Quote
Old 12-03-2006, 05:26 AM   #103
kelsow
kelsow's Avatar
Oddometer: 1,118
Oh to be 16 and foolish again...
kelsow is offline   Reply With Quote
Old 12-03-2006, 06:33 AM   #104
SQD8R
Eat squids and be merry
SQD8R's Avatar
Oddometer: 7,382
Excellent thread. It will be my constant reminder never to lend you guys my keys.
2006 BMW HP2E, 2011 Husqvarna TE630, 2015 Triumph Rocket III Roadster
Married men don't live longer, it just seems longer.
SQD8R is offline   Reply With Quote
Old 12-03-2006, 07:25 AM   #105
Bummer
Oddometer: 975
Originally Posted by Frane
Hey Frane Wellcome onboard.. What is that on the hillside?? Remains of old buildings or??
Bummer.
Denmark..
94- Honda Transalp..
We dont stop making foolish things because we get older.
But if we stop making foolish things, we get old to fast...(that goes for foolish nicknames too... )
Bummer is offline   Reply With Quote
Times are GMT -7.   It's 10:05 PM.
