Old 04-20-2015, 06:29 PM   #1
redgum78 OP
Oddometer: 7
Help from the Honda XL500 experts
Hi Guys,
I need some help identifying a piston.
Some time ago I picked up a rough but cheap 80/81 XL500S.
A few days ago I decided to give it a freshen up. I fitted new clutch plates and a new kick starter spring (old one had broken). I have got the bottom end all back together.
While it was out of the bike I thought I would put a set of rings in it as it is a smoky.
The Bore is 89.6mm and the piston has 0.50 stamped on the top. Cast into the underside of the piston are the letters "ART" and the number "2".
As it is an oversized piston I need to know if it is a Honda one or some other brand. No point getting oversize Honda rings if they don't suit the piston.
Does anyone know what the ART means?
redgum78 is offline   Reply With Quote
Old 04-20-2015, 08:00 PM   #2
redgum78 OP
Oddometer: 7
So not a honda piston. Thanks Gator.
Old 04-21-2015, 08:43 AM   #3
redprimo
Oddometer: 487
Have you checked the rings to be sure they are worn past spec?
redprimo is offline   Reply With Quote
Old 04-22-2015, 01:52 PM   #4
XRGRIFF
Oddometer: 38
Art
Thought they made OEM pistons for most of the Japanese factories, even Honda.
XRGRIFF is offline   Reply With Quote
Old Yesterday, 05:33 AM   #5
brucifer
brucifer's Avatar
Oddometer: 2,475
Every stock Honda piston I have seen--at least the old thumper pistons-- has ART cast into it.
The piston you have is a half mm oversize factory Honda piston.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old Yesterday, 06:50 AM   #6
The Ice Man
Can't Thaw Out
The Ice Man's Avatar
Oddometer: 21
The Ice Man is offline   Reply With Quote
Times are GMT -7.   It's 09:20 PM.
