07-08-2008, 12:32 AM
#16 |
Oddometer: 18
damn guys i think im in love and cant wait to have mine here at home with me
08-20-2008, 11:25 PM
#17 | |
Oddometer: 7
Performance Issues CH150 - 1987
Seemingly randomly (but usually when the weather is warm) it will "snap out of it" and feel full powered, or when i first start it up. Is there anything i can try to clean the carb without taking it to a mechanic? What the heck is seafoam? Literally seafoam from the ocean? Are those car carb cleaning additives worth it? I've been putting 91 fuel in it per recommendation, is that worth it? Thanks! I'm going to post images soon of my scooter. Cameron |
10-22-2008, 03:28 PM
#18 |
Oddometer: 2
Slow clutch engage on ch 150
I have an 85 honda elite ch150 and it seems I need quite a bit of throttle before it starts to move, any suggestions?
10-23-2008, 06:42 PM
#19 |
Despair & Repair Garage
Oddometer: 2,039
Be a little more specific. What are you comparing it to - a motorcycle throttle?
The CVT transmission in the Elite will have a bit of a lag and come on up to speed - especially at the initial start - slower than a bike with a manual transmission. You might be okay. Find someone else with a auto scooter and compare rides with them.
2001 HD XL1200S 1977 Vespa + 1985 Honda Elite CB550K project. "Man whoever came up with Ronald McDonald was dropping some serious acid.." - SpoonKiller / tiotalruckus.com |
10-23-2008, 08:49 PM
#20 | |
Such a drag...
Oddometer: 1,313
10-24-2008, 06:15 AM
#21 |
Oddometer: 2
Thanks for reply on clutch
The engine seems fine, it's just that the RPM'S have to be increased to about 1/4 to 1/3 throttle before the scoot starts to move. I'll take the belt off and clutch apart and check the rollers to see if there's any wear. I just bought it and don't know anyone else in the area who has one. Where's the best place to buy parts online?
Thanks |
02-27-2009, 06:25 AM
#22 |
Oddometer: 2,039
Drivetrain swap update.
Also, I will probably be picking mine up from the shop today. I had swapped a '84 125cc drive train in place of the 150cc after trashing the spline on the shaft from the crank to the CVT.
I was stranding me after 10-15 minutes of riding after the swap and going thru batteries also.Battery wiring on the donor 125 drive train was fudged. A fellow rider helped me put MUCH larger terminals on the wiring, but the weight and vibration trashed two batteries - THE BATTERY TERMINALS WERE ACTUALLY FRACTURING!. I had the shop put the right size ring terminals back on and they replaced the spark plug with one of those 'Iridium' types. Also, near WOT, the speed could sometimes vary without a change in throttle input from me. Had them put new variator weights in. They added a paddle switch for the headlight, so it lights up again. Now I can start the bike without having the headlight on. ALSO - it was still running like crap when I went to pay the bill, so they kept the bike. The last thing I heard them say is that it might have been the coils. Wrong - another cheap fix! They replaced the plug wire - that fixed the driveability issue. So check your plug wires also if it's still running like crap. I can't wait to get it back - it will be reliabilty for the first time since I trashed the splines in 2007.
02-27-2009, 07:47 AM
#23 |
gets bored easily
Oddometer: 152
where are the pics?
02-27-2009, 03:58 PM
#24 |
Oddometer: 2,039
Well, I went to the shop to meet the owner and the bike wouldn't start, not only that, it was backfiring.
Whenever your Elite backfires, that means one thing - you have, or have previously just destroyed your exhaust gasket. It's about a $5.00 part and a 45 minute fix. So the scooter is still there. But here is a picture of the donor cycle for the drivetrain. ![]() And here's my Elite after the swap, one of the times that it stranded me post-drivetrain swap.
06-21-2009, 10:51 PM
#25 | |
Oddometer: 47
Cool elite150
everyone knowss in the terminator film, the mother of future Sara Ann Cornor rode the same model as you own one, it worth you cherish and keep it forever!!!
11-19-2009, 11:32 AM
#26 |
Oddometer: 7
performance/sluggish still
I was wondering how difficult it is to clean the jets or to rebuild the carb. Any thoughts on the Chinese Carbs on Ebay, Honda dealer says crap. If I bought a rebuild kit is it something I could do, I've replaced the belt and brakes myself so far.
I'm still having performance issues, intermittent power. When runny poorly the acceleration is flat, and it tops out around 45 mph. Seems sluggish, after I've ridden it for a while and restarted while warm, or when the weather is warm (over 80) it will run normally (either right when i start it or while riding). I've taken it to 3 shops and they tend to give me the response "seems to run normal" (honda and two others) even though I tell them I know it is not and that it sometimes runs at "full power". frustrating. The idle can sometimes spike (intermittent) to the point where the clutch almost wants to engage. Usually when it is warm for a while the idle will return to normal 15000 miles I have: replaced the belt valves adjusted, checked for vacuum leaks, replaced a gasket. -by Honda shop (they say it seems to run fine :() checked by two other shops previous to honda replaced battery and rectifier replaced air filter replaced tires (dont think exhaust gasket was replaced) Have not: cleaned carb replaced roller weights replaced clutch shoes replaced bearings replaced petcock noticed: while running and when i put on to main stand while parking... the idle drops and sometimes stalls. crappy photo:
Cameron1977 screwed with this post 11-19-2009 at 11:39 AM |
11-20-2009, 08:49 AM
#27 |
Oddometer: 43
87 Elite 150- also tops out at 45
I have the same problem with my 87 Elite 150- it absolutely tops out at 45. Seems to run stellar other than that. The rollers and belt are in spec. I am thinking it has got to be a carb problem but that has been replaced so I am a little stumped.
I have an Elite 50 that is faster- I am wondering if the 87s were intentionally limited for some reason. I am really beginning to think that the variator may be undersized to keep top speeds down. From what I can tell the belt is fully reaching the top of the variator and so I think that may be limiting top speed. Please update if you make any progress and I will do the same. Thanks, Nathan Acree Albuquerque New Mexico |
11-21-2009, 04:22 PM
#28 |
Oddometer: 2,039
I like that yellow bike, Cameron.
Throw one or two ounces of Seafoam ![]() in the gas tank. That will help ungum the carbs. My 150 with the 125 drivetrain tops out at about an indicated 52 - which means 50mph, since the speedometer is always 2mph optimistic. Make sure your spark plug wire is good. Make sure there is no air leaking in where the carb joins the boot. Exhaust gaskets okay? Mine needs to be changed.
01-17-2010, 07:19 AM
#29 |
Oddometer: 6
Honda Ch150 & 250
I have worked a many of these ole tanks. I have 150 + 250. I had all panels sprayed ( painted ) by LineX as well as spraying rubber coating on back side of old panel. Makes them much stronger and maintenance free. I re-dyed all exterior plastic and rubber with Renew Protect (.com)... even seat and grips. New carb, all springs upgrade, 9.5 gram sliders, open exhuast tip (1in), much larger tires... Ch150 will hold 70mph... even maintained 45 UP Blue Ridge Parkway. Any one found performance cams for these old GY6? Dorus |
01-17-2010, 11:42 AM
#30 | |
Full blown child
Oddometer: 160
My 1986 elite has a top speed of 66mph, could just be condition, elevation or something along those lines though. |
