Old 05-26-2007, 02:26 PM   #241
Deadly
Asphalt Adventurer!
Deadly's Avatar
Oddometer: 1,522
Well, I went and sat on an XT today. I liked it a lot so next spring when I buy it will be an XT for sure.
I also sat on a DR200 (and liked it also) but I liked the XT much better.
Thanks for the links you all posted earlier.
Richard
IBA #14873
02' Nighthawk 750
My Website
Deadly is offline   Reply With Quote
Old 06-04-2007, 02:10 PM   #242
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
I put in the 42.5 and 130 jets and got the dreaded stumble upon acceleration. I attributed it to an inadequate float level. I went back in and adjusted the float and got it almost to disappear except for a bit that shows up when winding out the gears entering the highway. The bike is very robust at 60, 65, 70, 75 and will hit 80 easily. I think the float bowl is just to small to supply fuel needs when winding it out. My mind is made up that these CV carbs suck and I ordered the Mikuni pumper from ENDUCO. The bike is too good to waste farting with this economy carb.
Old 06-04-2007, 03:26 PM   #243
acejones
acejones's Avatar
Oddometer: 5,158
I agree. The Mikuni carb on these bikes is JUNK !
acejones is offline   Reply With Quote
Old 06-04-2007, 04:50 PM   #244
blimpman
Fla Trail Rider
blimpman's Avatar
Oddometer: 707
My second one....
'92 Serow
'09 DR650
'08 YX250F
'85 IT200
http://www.floridatrailriders.org
blimpman is offline   Reply With Quote
Old 06-04-2007, 05:54 PM   #245
Reposado1800
Juicy J fan!
Oddometer: 5,785
Now that I'm waiting on the new carb, I went back in and replaced the original 125 main jet. No more stumble but its back to an anemic 60-75 mph. I really like the 130 main but just wanted to be sure it IS the reason for the stumble. I'm convinced it is sucking the bowl nearly dry for brief moments while winding out. The float valve is very restrictive until the float is near bottom of travel. I think I can go in and pry on it a bit more to get it filling sooner but enough is enough. This bike is worthy of a real fricken carb. The CV is designed for a choked up, plugged up, lean jetted, wet noodle performance. It does that really good.
Old 06-05-2007, 07:13 AM   #246
ADVmouse
Whiskered Adventurer
ADVmouse's Avatar
Oddometer: 149
XT225 hand-protectors / bark-busters?
Who makes a good set of hand-protectors / bark-busters for the XT225? Nothing fancy, but something that fits well, for easy installation.
thanks,
Chris
ADVmouse is offline   Reply With Quote
Old 06-05-2007, 07:20 AM   #247
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
thanks,
Chris
I use these, they go on easy and you could hang your bike from the ceiling with them.
http://www.amotostuff.com/Merchant2/...gory_Code=emgo
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 06-07-2007, 07:02 AM   #248
AD7AN
Goat Roaper
AD7AN's Avatar
Oddometer: 11
Speedometer accurate?
I have a Garmin GPS attatched to my handle bars. When the same GPS is in my Dodge Durango it reads identical to the speedometer, but when it is on my XT225 it reads about 52 mph when my speedometer says I'm going sixty. How accurate is the Serow's speedometer?
"When I became a man, I put childish ways behind." 1 Corinthians 13:11
1st bike: Benelli Moped at age 14.
2nd bike: Yamaha Serow XT-225 at age 42.
Well...it's a start.
AD7AN is offline   Reply With Quote
Old 06-07-2007, 07:38 AM   #249
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
Not very, I had my speedo reading 80, I was only going 72. It also depends on the front tire you are using.
Old 06-10-2007, 05:07 PM   #250
Reposado1800
Juicy J fan!
Oddometer: 5,785
Does anyone have a solution to the tiny footpegs? i have been riding the bike off road and think larger pegs would do wonders to improve feel and control. I already upgraded the bars to Moose CR hi bend and think it was a great improvement over stock.
Old 06-10-2007, 05:16 PM   #251
deej
Deej (Deric)
deej's Avatar
Oddometer: 512
http://www.xt225.com/forums/ubbthrea...ge=1#Post22206
deej is offline   Reply With Quote
Old 06-10-2007, 06:30 PM   #252
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,131
Did the XT225 ever have a kickstarter?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 06-11-2007, 05:17 AM   #253
autolycos
True vulgarian
autolycos's Avatar
Oddometer: 4,211
Yes, and there is one available through your Yamaha dealer. I think it's ~$90 US + installation.
XT225.com has good information about it.
autolycos is offline   Reply With Quote
Old 06-11-2007, 09:42 PM   #254
Reposado1800
Juicy J fan!
Oddometer: 5,785
Have any of you guys drilled the slide on your CV carb? I did it tonight and the new snappy throttle response is wonderful.
Old 06-12-2007, 04:03 AM   #255
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
Well ya can't just leave us with that
what did you do, what jets & muffler ya runnin and how big did you drill it?
Times are GMT -7.   It's 05:50 AM.
