11-14-2006, 01:02 PM
#31 | |
Canyon fodder
Oddometer: 314
11-14-2006, 05:37 PM
#32 |
Oddometer: 15
07 KTM 525 EXC |
11-15-2006, 10:02 AM
#33 | |
Canyon fodder
Oddometer: 314
). I missed the norcal neduro clinic and it looked like so much fun. I would love to do it on a XT. Even with the issues this bike is still so much fun. I've been browsing around for one of my own now. I better chill otherwise there won't be enough room in my garage and too much room in my bank account.
11-21-2006, 03:50 PM
#34 |
Canyon fodder
Oddometer: 314
Yay! I finaly figured it out. Stupid needle valve for the float was intermitently sticking open then shut causing a highly confusuing lean then rich then working properly then rich then lean then... A float valve stuck shut would just starve the bike for gas. Stuck open would flood it. I had suspicions but every time I checked it would be working fine. After eliminating everything else I just replaced the entire valve assembly. Viola! Runs like a peach now.
The good thing is that while I had assumed the whole time that my jetting was the culprit (I had played around with numerous configurations) I actualy found that the bike responds really well to jetting upgrades when it was occasionaly working properly. Now that I know the jetting wasn't the problem I can go back in and continue experimenting. The top end seemed very responsive to oversized main jets and airbox exhaust mods. |
11-21-2006, 06:08 PM
#35 |
True vulgarian
Oddometer: 4,189
Hey, Wickerman77, I don't know if you've been following on xt225.com, but probably the next place to go before a whole lot of jetting if you're looking for power will be the Z1 mod, take off the fire arrestor, and use a hole bit to drill a 1 inch up to 1 7/8 inch hole in the deep recesses of the muffler.
I'm planning on opening mine up on Monday following Turkey day. |
11-22-2006, 08:52 AM
#36 | |
Canyon fodder
Oddometer: 314
11-22-2006, 11:32 AM
#37 |
Oddometer: 160
Wickerman
Wickerman, what are the symptoms?
If you're running wide open, and then chop the throttle shut, and it bucks and doesn't immediately and smoothly slow down, you're too rich. The small cc singles react very strongly to minor jetting and needle changes. It's not like messing with a 4-cylinder or even a v-twin's carbs. A little lost efficiency is not noticed on a 500cc+ multi-cylinder bike, but even a tiny bit lost on a 225cc single is noticed right away. My advice is to leave the needle stock, and get the bike running correctly at wide open throttle. Once that's done, get the bike idling correctly and starting smoothly, by adjusting the pilot screw. Out means richer, in means leaner. NOW, and only now, consider adjusting the needle. If the bike has a flat spot in the middle of the rpm range, shim the needle NO MORE THAN .020" (that's twenty thousanths). TINY changes make a huge difference. Charles. ChopperCharles screwed with this post 12-11-2006 at 06:13 AM |
11-22-2006, 03:25 PM
#38 | |
Life behind "Bars"
Oddometer: 6,352
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
11-22-2006, 04:28 PM
#39 |
Ducatistanna
Oddometer: 1,620
How did I miss this thread
I've only had the XT since October, I'm still breaking it it, so far I like it.
11-22-2006, 05:02 PM
#40 |
PORTLY ADVENTURER
Oddometer: 262
Another positive vote for the 225. My wife loves hers and I have a TT225 which I use for trail riding. Both are great bikes.
2008 Suzuki DL650 2002 Suzuki DR650 2001 Yamaha XT225 1986 Yamaha TT225 1982 Yamaha XJ650RJ SECA 1978 Yamaha XS11 AMA Charter Life Member |
11-23-2006, 04:04 AM
#41 |
hold my beer & watch this
Oddometer: 732
My dad got one a couple of months ago. He doesn't plan to use it a ton, he's not a speed demon, and he didn't want to spend a bunch of money, so it's perfect for him.
11-23-2006, 08:10 PM
#42 |
Wind Powered
Oddometer: 10,409
I took mine for a litle ride today.
11-24-2006, 01:35 PM
#43 |
Wind Powered
Oddometer: 10,409
Ok, One more.
12-01-2006, 12:12 PM
#44 |
Canyon fodder
Oddometer: 314
Ok I'm just convinced that something deep inside this carb is fuxored. I've solved the main problem with fuel delivery but I can't get this thing to run consistently smooth no matter what I have done and this is just about everything imagineable.
I know for a fact that the original owner though only putting 500 miles on it managed to screw up the jetting and fill the carb with dirt and sand. I've cleaned the piss out of this thing repeatedly, replaced all the jets in many configurations including stock setup, inspected every possible issue I could think of and it still acts wonky. It will run perfectly one day then bog or surge the next. I'm sure that some debris got into this carb and is stuck way up where I can't clean it out and I'm not sure the intake boots are sealing correctly to the carb. I'm just going to buck up and get either a flatslide or utilize a carb from a different bike (just ran into a free carb off a klx250) and go from there. I've done alot of research on this bike and just about nobody seems to be having the problems I am experiencing so I'm confident the bike is not inherently flawed but it's vexing cause my girl spent alot of money on this bike and of the 1000 miles put on it only a couple hundred were ridden by her. I'm feeling guilty as I kind of pushed her to get this bike and though we technicaly got a smokin deal on it (the year she wanted with only 598 miles on it for less than blue book) it goes to show how decieving things can be and how badly and quickly people who don't know shit about their bikes can screw things up. It makes sense now why the second owner who purchased it at 500 miles and did not even put 100 miles on it just wanted to unload it. The first owner screwed it up and the second got stuck with a lemon that she never had fun on cause it ran like shit. Her local shop where we picked the bike up was a bit scetch too. I'm a mechanic and have been rebuilding and tuning carbs for a good while now and this thing is frustrating the hell out of me. Has anyone got a different carb on their xt and how is it. I'm a sea level west coast. |
12-01-2006, 02:19 PM
#45 | |
True vulgarian
Oddometer: 4,189
On XT225.com there is something about a replacement (read more power) carb that is available.
Since you're not afraid to tear into the carb on it, I'm fairly certain you've got the technical wherewithall to install this Mikuni pumper carb. http://www.xt225.com/projects/mikuni.htm Quote:
