08-14-2012, 09:40 AM
#7366 | |
Oddometer: 1,125
Chains Without O-Rings?
Being well old enough to remember when all chains were 'non O-ring'.... I never want to go back to that! An O-ring chain comes lubricated for life, all the oil/grease it needs is already inside there, you just have to clean the grit and junk off the outside and keep it from rusting so that the O-rings can do their job. You will find almost as many opinions as to what to use to clean/lube chains as there are riders.... and they are all right! That's because it doesn't matter all that much what you put on the outside (or how often) as long as the O-rings remain intact. Once you go to a non O-ring chain, it will become much more critical that you stay on top of chain maintenance. Do you really want to have to lube it every couple hundred miles and EVERY time it rains? O-ring chains do use up a fraction of a horsepower in extra friction, racers frequently don't use them, but they also don't run all that many miles at a time and the top level riders will start each day with a fresh (as in NEW not just cleaned and lubed) chain. O-ring chains are a little wider than non O-ring chains, some antiques don't really have the clearances to fit them. For everyone else, O-rings just make sense. Think about our XT 225s, Yamaha installed many of the cheapest components they could find (especially the tires) but even they figured out that O-ring chains were worth the cost. You can of course run any type of chain you wish on your bike but I bet you can't get more than 8,000 or 9,000 miles from a non O-ring chain on it and you will put in a lot more time and lube to get close to that than you did for the original. Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
08-14-2012, 09:45 AM
#7367 |
Oddometer: 39
Chains
I have used both types of chains. ORing chains are not suppose to need lubed. If you feel you must lube your chain get a non oring. Just my 2 cents.
08-14-2012, 09:54 AM
#7368 | |
Oddometer: 1,166
Really? I didn't know that.
Jonathan Quote:
08-14-2012, 02:00 PM
#7369 | |
Oddometer: 663
Excellent, our country is now run by folks that would allow you to smoke pot in Washington State, but not buy a Big-Gulp in New York. 10 State Trip 2010 2011, $1000 in the pocket, how far can we go |
08-14-2012, 02:10 PM
#7370 |
Permanent Lurker
Oddometer: 35
altitude jetting
Ok - heading to the mountains soon and wanted to confirm jetting specs:
For riding up to 13K ft. - 115 Main jet 35 pilot Snorkel pulled out Does this sound right? It's the best Ive gathered from searching this site and others. I don't want to drill holes in the airbox etc. My bike is completely stock; which is the way I like it. Any other recommendations? I saw this as well, but there's no mention of changing the pilot jet: http://www.formtechservices.com/dirt...com/Rejet.html Thanks! texasadv screwed with this post 08-14-2012 at 02:18 PM |
08-14-2012, 02:49 PM
#7371 | |
Oddometer: 4,587
'01 Kawasaki W650 '05 Yamaha XT225 |
08-14-2012, 03:51 PM
#7372 |
Can I ride it?
Oddometer: 3,514
08-14-2012, 03:53 PM
#7373 |
Can I ride it?
Oddometer: 3,514
08-14-2012, 03:59 PM
#7374 | |
All who wander r not lost
Oddometer: 1,982
Now that's what I call recycling... TP becomes sandpaper!
I've learned to give "impossible" the finger as I pass it by. The only way to get through life is to laugh your way through it! Day by day, nothing seems to change. But pretty soon, everything is different. |
08-14-2012, 05:17 PM
#7375 |
Oddometer: 39
arguement
@GI_Joe Instead of trying to get an on line arguement started begin a discussion on the best oil for a motorcycle. You'll get alot more responses.
08-14-2012, 05:20 PM
#7376 |
Oddometer: 39
tires
Or ask what is the best dual sport tire for motorcycle in question.
08-14-2012, 06:30 PM
#7377 |
FoolForDirt
Oddometer: 54
Chain & Sprockets
Hi Bob,
Thinking back to my dirt bikes of the '70s & '80's, I would never go back to non-O or X ring chains. They constantly needed adjustment, lubing, and cleaning. And, they didn't last that long. Comparing that routine with getting 17-20k on either a KLR650 or a 100+ hp FZ1. Can you tell which way I'm leaning?
Rich in Patagonia 67? YM-1, 02 FZ1, 04 XT225 |
08-15-2012, 04:54 AM
#7378 | |
Recreation Engineer
Oddometer: 226
Thanks for all the feedback. Many good points that I agree with. Here's a bit more context. One third of the miles (~8k) on the stock chain were put on this past year. I rarely adjusted the chain in four seasons prior. I commuted rain or shine and kept it garaged at home and work. What's different now with full time RVing is the bike is in the elements almost always. Carrying it across the front of my truck soaks the bike good driving rain. I bet that's when rust snuck into chain links. Once it started kinking I could hear sprocket teeth being gnawed. I have to lube the chain often to slow down rust. Even a glorious O ring chain, so it's value is limited. (O rings may work against spray lube getting where it's needed.) If I have to replace one or two chains a season, I'd rather sacrifice standard not premium ones. If replaced when kinking first started and before stretching follows, hopefully that'd spare the sprocket teeth from abuse. Alternating two chains dovetails that thinking. Any flaw in the logic? |
08-15-2012, 05:35 AM
#7379 |
Dodgin' the Ditches
Oddometer: 1,158
Bob,
You might as well go ahead and try it. It won't cost much to try, and maybe you will like it. If you don't like it the experiment was cheap, and you gained the knowledge. Otherwise you'll keep on wondering.... Now, if you really want to do an experiment.... Get an O-ring "and" a regular chain, and make a 50/50 hybrid chain made of 1/2 a length of each. Then you can test both of them at the same time, and under the exact same conditions. ![]() That's what ol' Ben Franklin would'a done, if he was a biker. |
08-15-2012, 06:48 AM
#7380 | |
Recreation Engineer
Oddometer: 226
Ole BF was a frugalitarian. Surely he would've appreciated the XT225. KamperBob screwed with this post 08-15-2012 at 06:49 AM Reason: typo |
