Old 09-17-2012, 12:50 PM   #7576
gbacque
gbacque's Avatar
Oddometer: 76
accessories relay
I don't want my accessories to drain the battery when I forget to turn them off so I ran two blade type fuses through a relay so when the bike is off so are the electronics. But where to get the on signal? I can tell you now, nothing off the starter relay works. That will either keep the starter spinning or tun everything off unless in neutral or the clutch is pulled. To prevent the same mistake three times I put the bike in gear and found a hot wire that was cold when the key is off. What I didn't count on is the wire I chose did satisfy this condition but also turned off when the bike was in neutral.
Annoying at first, this turned out the be really handy. My GPS beeps when it looses power so any time I would accidentally shift into neutral it would beep at me. Saved me several times this weekend riding around on trails. Never did I twist the throttle expecting power when I was in neutral. Then the GPS would beep again when I found a gear.
gbacque is offline   Reply With Quote
Old 09-17-2012, 02:59 PM   #7577
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
Originally Posted by Drtyfun View Post
During my rear tire change, the brake side rear bearing just fell out of the hub. It feels rough when rolled, and appears to have spun in the hub. The new bearing drops right in, with just a little slop.
Any options other than buying a new hub? Could I use Locktite and have it staked to buy me one more tire change? Do bearings have the same inside I.D. and different outside diameter that I can have the hub machined?
Anybody run into this before? Please give me your thoughts or suggestions.
(Any suggestions will be a short term repair. A rear wheel rebuild is in my future. )
I would stake it and use loctite green. I have done this on cars and it works great.
Hate gets you nowhere.
Old 09-17-2012, 04:49 PM   #7578
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
This is what I went with yesterday. Rode to work today, and will pull the rear wheel this weekend to see if it is holding. I am going to do some research on the rear wheel/disc brake conversion before I order the new hub. Thanks for the suggestions everyone.
Drtyfun is offline   Reply With Quote
Old 09-17-2012, 06:39 PM   #7579
jspringator
Oddometer: 462
Originally Posted by BlueLghtning View Post
I have had a Russel Day Long on all 5 of my Vstrom's and now has over 100k miles on that seat and I absolutely love it. No other seat comes close in comfort. I've never really thought of putting one on a DS although it certainly will be comfy! You even got the double Russell! Do you really go 2up that much on your XT?
It cost a little over $500, plus shipping. I need the 2 up capability. I don't know how much I will use it.
Rode it the other day. Seat was very comfy, but I still wanted to slide forward. It is probably the bars. I have a hard time touching the ground. I think I will need to wear my ST disco boots. I've ordered a set of Turbo City windshield bars and Madstad brackets and windshield.
I have some first generation ST1100 Helibars that are infinitely adjustable that I don't use on my ST. I think I'm going to see how they will work. I think If they came back a little bit I wouldn't be sliding forward. The seat isn't canted forward at all. I only use the bike for street riding.
Next, radial tires
2006 Yamaha XT225 (TM33,Wiseco 10.25 to 1 piston, Webcams 89A cam, beehive racing springs, RDL seat)
2000 ST1100 ABS, RDL seat
jspringator is offline   Reply With Quote
Old 09-18-2012, 09:00 PM   #7580
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
Loctite and stake so far is holding. I am ordering a new hub and spokes Saturday anyway. I will take it apart again Friday and check again, if it has moved, I was thinking of putting it back with JB Weld until parts arrive. What do you think?
Old 09-18-2012, 11:18 PM   #7581
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,544
... What do you think?
I think Iíd have tried to shim it all around with something real thin & just run it. You can buy very thin stainless steel shim material in different thicknesses. Hell, you could probably still try it. Might even start out with a cut up aluminum beer can. You can cut that stuff with scissors. 0.0035Ē thick.
Probably way too thick since it most likely was not all that loose & will work just fine as is. You would need 0.007Ē of total clearance.
I wouldnít try the JB Weld. If you do that it will most likely be stuck in there for good, or you, or someone else, would play hell getting it out & never have the chance to fix it in another, better, way.
Itís your money.
Tom S is offline   Reply With Quote
Old 09-19-2012, 03:20 AM   #7582
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
Itís your money.
I like the beer can shim idea better, Thanks! As far as the hub, I am ordering a new one this weekend, probably will take a week or so to get it. I am just trying to buy time if the loctite fails to hold it. Thanks again.
Old 09-19-2012, 02:38 PM   #7583
woofer2609
woofer2609's Avatar
Oddometer: 812
+1 for the beer can shim. Even if you know it won't work before you start, the worst thing you've done is enjoy a beer
woofer2609 is offline   Reply With Quote
Old 09-20-2012, 09:33 AM   #7584
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,405
Hey, I can't get the exhaust tip off on my father in laws 2001 XT225. We drilled out the rusted frozen bolt on the underside but I can't get the tip off the end. We have sprayed WD40 all over the lip and let it sit for a few days to no avail with a big rubber mallet. Afraid of damaging it by hitting it harder.
Any tricks? Is there something else holding it on?
n16ht5 is offline   Reply With Quote
Old 09-20-2012, 11:06 AM   #7585
Reposado1800
Juicy J fan!
Oddometer: 5,798
That loctite green is seriously strong stuff. If it can hold a bearing in on a 69 oldsmobile that weighs like 6,000 lbs an XT225 is nothing.
Old 09-20-2012, 02:39 PM   #7586
TTRPaul
Oddometer: 39
insert
@n16ht5 The same thing happened to me. I drilled out the screw but in so doing damaged the thing enoough to want to still hold the insert in place. What I did was take 3 screw drivers and GENTLY pryed the insert in three places at once. My two hands and my neighbors one. It didn't take much to get it moving. After doing the hole in the muffler I spot welded the insert in place. (I made sure it ran better first).
TTRPaul is offline   Reply With Quote
Old 09-20-2012, 06:04 PM   #7587
J5k
Oddometer: 60
Ttr225 gas tank?
Does anyone know if the ttr225 gas tank bolts up to the xt225? I noticed some rust in my carb bowl when I did the jets. I know there's the Clarke tank but I don't need capacity, I'm more looking to get rid of the rust, be a hair lighter and a bit more dent resistant. If not the ttr, any info on other (cheap) plastic tanks anyone has fitted would be great.
J5k screwed with this post 09-20-2012 at 06:07 PM Reason: My phone sucks at posting
J5k is offline   Reply With Quote
Old 09-20-2012, 06:14 PM   #7588
J5k
Oddometer: 60
Have you tried heat? If you can find a short piece of steel pipe (thicker wall the better) that fits snug in the end of the exhaust, you should be able to heat the exhaust and pop the end cap right out. The pipe should soak up the heat and allow the exhaust to expand. Just don't set your bike on fire! (ps, no idea if this will work as I've never done it for this particular application)
Old 09-20-2012, 06:26 PM   #7589
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,544
I donít think it is that unusual to find very small particles of what may appear to be rust in the bottom of float bowls. Seen it many times. But I donít think it is necessarily always rust. The important thing is what it looks like inside your tank. Drain it out & take a real good look in there. I have rarely added filters but maybe thatís all you need. A small in line filter.
Old 09-20-2012, 07:09 PM   #7590
J5k
Oddometer: 60
An inline filter is on its way. What I was told by the po was that he bought it for his wife in 06 for her to learn on. That didn't happen. Every spring he drained the gas (put it in his lawn mower), rode it to get inspected and filled it back up only to sit in the garage the rest of the year. I'll pull the tank again and take a look, but I still would like to know if a plastic tank exists that will bolt up with minimal modification (preferably to the tank not the bike).
Times are GMT -7.   It's 06:07 PM.
