Old 09-26-2012, 08:55 AM   #7606
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
Originally Posted by MrsTiggywinkle View Post
I have a 07 XT with about 6200 miles on it. I've started noticing whenever the front end hits a bump there is a really loud "whooshing" noise. I'm assuming it's coming from the fork tubes but alas, I am not at all mechanical although I am trying to learn. Any ideas on what this is and if it is something that needs attention?
My guess is it is just air being forced in and out of the boots on the fork tubes, if you want you can probably grab the front brake while parkes and just compress the suspension a few times and hear it. My aftermarket ones are louder than the stock ones were.
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 09-26-2012, 09:51 AM   #7607
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
I forgot to mention that "loud" is a relative term. The XT forks are a bit wimpy by design and all make some noise over large bumps. (yea, I know..."large" is a relative term too!)
GlennR is offline   Reply With Quote
Old 09-26-2012, 06:32 PM   #7608
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
Originally Posted by a1fa View Post
Who sells the radiator kit?
bump! -- found it.. click on the bump!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 09-26-2012, 09:41 PM   #7609
KingJeff
Oddometer: 54
new tire trouble
I have a 95, and replaced the original rubber with Kenda's,but I can't get the tire to seat correctly all around the rim. I think it's because of the "teeth" on the inside of the rim won't let the rubber slide into place. I've tried over-inflating, sun, riding it, clamps, tons of windex and soapy water. It's really bad at 45mph, but ok faster, and I don't even notice it off road.
I'm on page 164, sorry if it's been covered already, but has anyone else had this problem?
Do all XT's have these types of rims? I'm more used to bicycle work. Is it the rubber?
Thanks,
Jeff
97 KTM 300 EXC
95 XT 225
02 PW 50
04 PW 80
KingJeff is offline   Reply With Quote
Old 09-26-2012, 10:42 PM   #7610
woofer2609
woofer2609's Avatar
Oddometer: 743
Rim issues
I have a 2000 w/ the same non-slip notches on the D.I.D. stock rims, and they have not posed a problem with the 3 different sets of tires I've had on them. I think they are on most MC rims. You've tried windex, which should do the trick. Baby powder on the tube helps too, but you probably tried that as well. You could try inflating it to, or slightly slightly above the max psi of the tire while assuring the bead is seating properly.
What type of of tire is it? Maybe you got a dud tire, or one with a heavy spot, which would explain the wobble at speed. This might be remedied with balancing. With the front wheel off the ground, see if the same spot on the tire rotates noticeably to 6 o'clock when you release the tire.
I just mounted some Shinkos, and to a certain extent, they wobble a bit as well. I notice it more on the front.
woofer2609 is offline   Reply With Quote
Old 09-27-2012, 04:30 AM   #7611
airborndad
airborndad's Avatar
Oddometer: 2,503
if you would have said oil cooler I could have answered that
airborndad is offline   Reply With Quote
Old 09-27-2012, 06:39 AM   #7612
KingJeff
Oddometer: 54
Thanks Woofer. I over-inflated it up to 75psi, and then left it in the sun to try and help it seat, but it didn't work then either. I also had Neduro's thread about changing tires open the whole time. It just seems like the teeth keep one side from seating properly, and I'm pretty sure it's me. I'll check the balance next
97 KTM 300 EXC
95 XT 225
02 PW 50
04 PW 80
Old 09-27-2012, 07:35 AM   #7613
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
I had a tire that wouldn't seat, because I'd stored it with the shipping label taped on which deformed the bead in that one spot.
It was a PITA to seat, but I did the windex HEAVY and repeatedly filled & emptied the air. I may have gone past 75psi, probably so because I ruined a pressure gauge...
It eventually seated.
Old 09-27-2012, 08:08 AM   #7614
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 758
Wow! I would have suggested 65 psi because I have had to use that much to seat the bead on tubeless tires. Those are much harder to seat than the tubed ones. I have never had one as bad as the one you describe. It could be a manufacturing defect. I have never has to go aver 30 psi to seat a tubed tire bead.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 09-27-2012, 08:26 AM   #7615
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,510
Jeff
The "teeth" are not the problem. I realize that this may be against the ADV code, but you might try some tire lube instead of cleaning products.
Use whatever pressure it takes. The tire must be fully seated.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 09-27-2012, 08:30 AM   #7616
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
Check the rim lock. It could be interfering with the tire.
Hate gets you nowhere.
Old 09-27-2012, 10:30 AM   #7617
WayneJ
LFC/CCCCC
WayneJ's Avatar
Oddometer: 5,667
Originally Posted by lamotovita View Post
...but you might try some tire lube instead of cleaning products.
This.
If you mount your own tires, do yourself a favor and go to your local NAPA store and get a gallon of RuGLYDE.
You can thank me later.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
I got a chill standing outside wiggling wieners.. - LadyDraco
There is no odometer when it comes to pie - VACommuter
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 09-27-2012, 10:42 AM   #7618
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
Originally Posted by WayneJ View Post
This.
Sounds like KY-jelly for tires.
Old 09-27-2012, 11:35 AM   #7619
TTRPaul
Oddometer: 39
Kenda
I have had similar problems with Kenda tires. What I have done is use soapy water, where it is not seating pry alittle with a tire spoon (not a screw driver) and re inflate, DONOT use as much pressure as needed as you could pop the tube. Also laying the tire/rim flat helps.Keep working it eventually it will go on the rim all the way around, both sides. It may not make the pop sound. You know it is seated if you deflate and the tire stays seated.
TTRPaul is offline   Reply With Quote
Old 09-27-2012, 12:08 PM   #7620
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
Kenda was the problem tire for me too. Hmmmm?
Think I'll try the Shinko next.
Times are GMT -7.   It's 01:59 PM.
