09-27-2012, 11:08 AM
#7621 |
Dodgin' the Ditches
Oddometer: 1,184
Kenda was the problem tire for me too. Hmmmm?
Think I'll try the Shinko next. |
09-27-2012, 11:26 AM
#7622 |
Oddometer: 243
Yeah, that would probably work pretty well too!
Tire lube?!?! Sacrilege! Any self respecting ADV'er would use butter, snot, slug slime and many other things to try and MacGyver it on before resorting to the proper method of doing it! I was going to suggest over inflation, but figured the safety police would call me on it. I do the same thing. I found my Kenda 760 TMII very tough to get on (rear). In regards to the Shinkos Golden Boys, they mounted easily, and after the obligatory 100km run in, seem to work great. With the rear brake applied, I am JUST able to lock up the rear wheel, but otherwise modulation is excellent. |
09-27-2012, 11:34 AM
#7623 | |
Harvey Mushman
Oddometer: 1,330
"Coffee first..." Next Trip: didn't get enough...Death Valley "it's a dog's life.............and I love it" |
09-27-2012, 01:06 PM
#7624 |
Oddometer: 33
RuGlyde
I bought some RuGLYDE, and going to try the strap as well as soon as I get home. I'm going to get this seated properly if it kills me!
Thanks for your help everyone, Jeff
97 KTM 300 EXC 95 XT 225 02 PW 50 04 PW 80 |
09-27-2012, 01:23 PM
#7625 |
Oddometer: 243
[QUOTE=KingJeff;19693979]I bought some RuGLYDE, and going to try the strap as well as soon as I get home. I'm going to get this seated properly if it kills me!
Try and avoid the latter |
09-27-2012, 01:29 PM
#7626 |
Oddometer: 243
XT225 Cafe racer...ish
Thinking about selling my bike as I bought a wr250x, that being said, I will keep this one until I have committed to the new one. I was putting my old bars back on and had some spare time. Way more comfortable than I would have thought.
09-27-2012, 01:43 PM
#7627 |
Oddometer: 243
Tool Tube
I was trying to find as many storage spaces for tools on the bike as possible, I hate being stuck w/o the correct tools, and dislike riding with anything against my body. I replaced the stock tool kit with a 12" section of 3" PVC piping. Mounted it on some 1" angle iron with 1/4" holes , and mounted it to the stock toolkit mounting brackets. I had a tube of 4 tennis balls in the basement that happened to fit PERFECTLY in the tube, and made it possible to remove the tools in an organized fashion from the PVC tube. Total cost was about $10. It contains an aluminium spray bottle of Windex, 2 tire spoons, 2 tire levers, a bike pump, some zap straps, a spare clutch lever, and a spare brake lever. The carriage bolt fits through holes drilled at the 6 and 12 o'clock location of the tube and lid. Carriage bolt was filed and then a through hole drilled for the retainer clip. I've started using these retainer clips on my castle nuts on my axles as well. The PVC has held up to having the rear tire rub against it during an err, unplanned tip over where my leg forced it against the tire.
09-27-2012, 02:09 PM
#7628 | |
All who wander r not lost
Oddometer: 1,982
I went for a few of these instead. http://www.agrisupply.com/Large-Manu...70/&sid=&eid=/
I've learned to give "impossible" the finger as I pass it by. The only way to get through life is to laugh your way through it! Day by day, nothing seems to change. But pretty soon, everything is different. |
09-27-2012, 02:52 PM
#7629 |
Dodgin' the Ditches
Oddometer: 1,184
Hey Woofer,
Are those different handlebars? They look a lot like the stock ones, upsidedown. It's important to get as low as possible on the XT225 if you're trying to squeeze that last 5 mph out.
09-27-2012, 04:19 PM
#7630 | |
Oddometer: 243
![]() Exactly! That, and to eek out an extra .5 MPG! Yeah, They're the stock ones, I turned them over afterwards, but thought I'd have a little fun. After riding with Renthal 811's, the stock ones were surprisingly comfortable. I took off the oxford heated grips, and Ralli Guards, and without the handlebar brace, all the heated grip wires and brushguards, the bike is refreshingly uncluttered. |
09-27-2012, 06:21 PM
#7631 |
Oddometer: 33
Victory!
The RuGLYDE worked like a charm! WayneJ, if you're ever in CO I owe you a beer.
I now have 2 fully seated tires, and just have to put them back on after the kids go to bed. I might flip the rear brake over too. A huge thanks to eveyone for your help!
09-27-2012, 06:31 PM
#7632 | |
Oddometer: 243
Congrats!+1 on the brake flip over! |
09-27-2012, 07:23 PM
#7633 |
FoolForDirt
Oddometer: 54
What's the rear brake flip-over?
Rich in Patagonia 67? YM-1, 02 FZ1, 04 XT225 |
09-27-2012, 07:41 PM
#7634 |
Oddometer: 4,663
Move the rear brake rod over the top of the swing arm and bend to fit. Gives it a little more ground clearance and less likely to snag.
'01 Kawasaki W650 '05 Yamaha XT225 |
09-28-2012, 02:05 AM
#7635 | |
Oddometer: 2,325
