Old 10-03-2012, 03:57 PM   #7681
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Originally Posted by BrandonR View Post
450 would be for a whole replacement shock. I bought both front and rear springs for our XT225 for ~220 or so. You'll need spring compressors to install the rear spring, I used a bunch of zip ties.. it would have been a lot easier with the proper tools.
Yeah apparently they have some more budget items, not listed online...
Email from them.
Thank you for contacting us.
We have helped quite a few XT225 customers out and would love to help you.
How much do you weigh without gear? Are you riding two-up?
We do have heavier springs available for the forks and the shock. Fork springs @ $119 and Shock spring @ $135. Also, available is the Race Tech Emulators Valve Kit @ $149. We are out of stock at the moment on custom springs, but would be able to have those in our hands in about +/- two weeks after ordering.
We welcome Visa, MasterCard or Discover.
Thank you again and please do not hesitate to ask any questions.
Have a good day.
Best,
Joyce Tannenbaum ~ Cogent Dynamics Customer Support
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 10-03-2012, 04:01 PM   #7682
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
Email from them.
Have a good day.
Best,
I would love to do the front end over. I want a seat first though.
Some random stuff for sale
http://www.advrider.com/forums/showthread.php?t=988511
moterbiker is offline   Reply With Quote
Old 10-03-2012, 04:04 PM   #7683
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
So I finally got a rack big enough to actually camp off the XT and Clarke tank... Well load it all up, put my fat self on the seat and the suspension that was barely adequate before is now overwhelmed. So any budget suspension upgrades out there?
Close to those weights myself, bike goes fine with the mods i made
Old 10-03-2012, 04:06 PM   #7684
Crazy Canadian
Oddometer: 2,028
And seeing as we used to go drinking together in my NC days, why have you never filled me in on these mods before?
Old 10-03-2012, 04:48 PM   #7685
moterbiker
Gypsy diver
moterbiker's Avatar
Oddometer: 1,475
When the hell did you buy it and where you riding it out there?
Old 10-03-2012, 05:23 PM   #7686
Crazy Canadian
Oddometer: 2,028
I bought it in Garner so I had it there and I am pretty sure you saw it at Flying Saucer at least once!
Old 10-03-2012, 07:29 PM   #7687
woofer2609
woofer2609's Avatar
Oddometer: 743
Originally Posted by gbacque View Post
Also check the counter-shaft oil seal behind the sprocket. We talked about it a few pages back but it seams like this is going out on a lot of our bikes.
Thanks, I will definately try that. I took off the CS cover and cleaned in there before the last ride, so, I'll see what it looks like now!
woofer2609 is offline   Reply With Quote
Old 10-03-2012, 07:35 PM   #7688
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
my brakes suck -- plenty of meat but no stopping power.. i flipped the shoes around and cleaned up the area, including the walls... while there, i did the brakeline mod, routing the brakeline above the swing arm. anyway, plenty of meat, no stopping. i had to adjust to maximum to get any stopping power. tomorrow, I'll move the lever further back, but this thing should be stopping
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 10-03-2012, 07:41 PM   #7689
woofer2609
woofer2609's Avatar
Oddometer: 743
I wonder if there are inconsistencies in these shocks, as I have made numerous trips 2-up with camping gear. The only thing I do is preload the spring using the two rings to the minimum recommended height, and turning the rebound clicker underneath all the way counterclockwise and then back 1 or 2 clicks (saying to myself "It's 'hard' to go back in time" helps me remember which is soft,and which is the firm setting looking down from the top of the bike.
The only issue I've had is when I was loaded up to about 380lbs and the swingarm activated the above swingarm brake actuator rod, which in turn actuated the rear brake slightly, leading me to have an EXTREMELY hot rear drum. I would watch out for that! Speaking of which, I should probably check my wheel bearings...
Anyhooters, the bike is rated for 408 lbs luggage et al, so it should take it. Not that it will be a rocket, and not that it will be able to start on a hill w/ a 16t front counter sprocket ( don't ask)
You're adjusting both the preload and the rebound?
Old 10-03-2012, 07:45 PM   #7690
woofer2609
woofer2609's Avatar
Oddometer: 743
New shoes, maybe old ones contaminated? I found the first time I did the over swing-arm brake actuator rod, i had too many kinks in it, and all my pedal travel went into straightening the rod, with absolutely NO rear brake power. Was the actuator rod straight when it was underneath the swingarm?
I have found the rear brakes to be strong enough to skid any tires I've had on there, and actually like their modulation better than the rear discs on my wr250x.
Old 10-03-2012, 09:21 PM   #7691
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
maybe contaminated.. that's what i was thinking. i'll just order a set to be sure.
Old 10-03-2012, 10:15 PM   #7692
Crazy Canadian
Oddometer: 2,028
I am going to play some more tomorrow and see what I can figure out. Sounds like I missed something.
Old 10-04-2012, 12:40 AM   #7693
Crazy Canadian
Oddometer: 2,028
My XT with it's new tank and rack... I bought the rack off ebay and have no idea who made it, it's huge though and I have had two people ask me where they can get one like it. Any ideas? I lucked out and only paid $35 for it. Was expecting something half this size but am certainly not complaining.
Old 10-04-2012, 04:17 AM   #7694
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,969
Looks like the one from Cycleracks.com. Great find for only $35.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 10-04-2012, 05:36 AM   #7695
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,107
CC,
That was a heck of a deal on the rack. It is huge.
I was wondering what rear tire you have? It looks pretty beefy. I just ordered a Shinko 244 yesterday, but keep thinking a knobby would be fun to try sometime.
GlennR is offline   Reply With Quote
Times are GMT -7.   It's 01:23 AM.
