10-08-2012, 08:40 AM
#7741 |
All who wander r not lost
Oddometer: 1,982
Yeah, I will give that a try just as soon as the XT can keep on front of them in the easy stuff.
I've learned to give "impossible" the finger as I pass it by. The only way to get through life is to laugh your way through it! Day by day, nothing seems to change. But pretty soon, everything is different. |
10-08-2012, 08:58 AM
#7742 | |
Dodgin' the Ditches
Oddometer: 1,184
You have a Hp disadvantage, but a height & weight advantage. They shine on the gravel roads, and the XT shines in the trails. That's why I said you need to get them to follow you into the tricky stuff.
10-08-2012, 09:22 AM
#7743 |
Oddometer: 1,982
Yeah and they do... The rare times that the tricky stuff doesn't start after more then about 1/4 mile of gravel.
10-08-2012, 10:20 AM
#7744 |
Oddometer: 70
if you are bottoming out on gravel roads then your shock is defiantly shot.
10-08-2012, 11:03 AM
#7745 |
Oddometer: 1,982
On the flats it is fine... It's mostly diving through the ditches onto trails and going up hill over medium rocks etc that I am bottoming out....
10-08-2012, 02:42 PM
#7746 |
Oddometer: 70
Just giving you a hard time.
By the looks of that bottom out bumper (or whatever it's called) you need to at least re-build that shock with a stiffer spring. It's seeing way to much action. You could give Progressive a call and ask them what they have in the lines of springs. They might have that bumper too. Not sure about the rest of the components (if needed) though. |
10-08-2012, 06:01 PM
#7747 |
Occasional Partaker
Oddometer: 227
Nice Clean Carb, Fuel Bottles & Jet Question...
I have made some progress toward getting my new to me 2003 XT225 pretty well sorted out. The latest big event was a through carb cleaning yesterday.
It had never run like it should and all indicators so far have been that there was massive neglect during the 3900 mile life since 2003 at a minimum, with a high chance that the bike had been under water at some point. So, per all you folks, a carb cleaning was in order. I will let some pictures do the talking. ![]() ![]() ![]() ![]() ![]() ![]() I didnt take pics, but the low speed $expensive$ black plastic thingie on the side was just as dirty inside, and the loop part of the small diaphragm was out of place and probably leaking air. The difference in starting, choke/warm up time, low end power, roll on power, throttle response smoothness and every aspect of running is 100% better. I can not over state the results. Here are the stock jets. I did not scar up the jet. Obviously, someone has been in here before and did not help things. ![]() ![]() I think I will take the main up one notch to 127.5 and see how that colors the plug. I like the stock pipe, air filter and airbox so stock might be better. So, after looking at Thumper Talk since they will sell onesies, can y'all confirm which type jet to order? It looks like the large round to me. What do y'all think? Or know? ![]() ![]() In addition, I added a tool tube to the stock tool tube location. ![]() I made sure it would hold a 33 oz fuel bottle. ![]() So, between these 3 fuel bottles, I can easily carry the 33 oz while riding light, and can add the 2 23 oz bottles to my givi case on the tail when i pack a little more. So, short filling to 30, 20 and 20 oz, I can easily carry 70 oz of extra fuel. ![]() So, I suggest everyone that hasn't to clean your carb, and a tool tube and fuel bottles are worthy mods, IMHO. Thanks to everyone that posts all this good stuff for me to copy!
2001 XT225 2003 XT225 2005 DL650 - Sold 2002 KLR 703.5 - Sold 1999 Valkyrie IS - Sold |
10-08-2012, 06:45 PM
#7748 | |
Oddometer: 565
Joyce can fix you up , for $120. Get a 7.2 kgf/mm shock spring from Cogent Dynamics. Sets it up about an 1" higher too. She can also sell you a set of front springs to match. Joyce Tannenbaum ~ Cogent Dynamics Customer Support Cogent Dynamics, Inc. ~ 33 Meadow Brook Drive ~ Fletcher, NC 28732 T +1 828-628-9025 ~ F +1 828-628-0328 raceparts@motocd.com www.motocd.com
dirt bikes, vstrom, cruiser, etc. "what hurts, instructs" - ben franklin |
10-08-2012, 07:03 PM
#7749 |
Dodgin' the Ditches
Oddometer: 1,184
kewlbyme,
Good job on the carb. I don't know much about the jets, but aren't there numbers stamped on them to indicate the size and the type? It looks like the large round type to me too. |
10-08-2012, 07:13 PM
#7750 | |
Occasional Partaker
Oddometer: 227
They are stamped with the size (stock), but I didn't see any reference to "type". When I had them out, I didn't know there were a'la carte options. I should have paid better attention prior to buttoning'er up.
10-08-2012, 08:10 PM
#7751 | |
Befuddled Adventurer
Oddometer: 260
Stiffer rear shock spring...
dav_dman is absolutely correct on this and not blowing smoke in the least. Talk to Joyce or Rick at Cogent Dynamics and have them send you this spring; you won't regret spending the $120 once you experience how big of a difference it makes. It will allow you to set the pre-load properly (instead of jacked to-the-max) and makes it much easier (IMHO) to get the rebound dampening set where it's most effective.
I've had the Moto CD 7.2kgf/mm spring on the back of my XT for about 2000 miles, and to say the difference is night and day would be an understatement. I weigh about 175-180 all geared up and have ridden in the rough with an additional 50lbs. of camping gear, saddlebags, rack etc. on the back... no bottoming out to speak of... it just works. Definitely consider the .42kg springs and Race Tech cartridge emulators for the front forks as well... The customer service from Joyce and Rick is amazing to boot! Quote:
"Remember, you may have to grow old, but you don't have to mature." - Red Green |
10-08-2012, 08:22 PM
#7752 | |
Oddometer: 242
If I hit a ditch with the rebound knob at it's softest/ quickest setting, I can get it to bottom out with my 170 pounds of rider and gear. woofer2609 screwed with this post 10-08-2012 at 08:28 PM |
10-08-2012, 08:53 PM
#7753 |
Misadventurer
Oddometer: 342
XT225 in the best of company
Flip through a few of the pics here. There's some real nice vintage Brit iron here.
http://www.flickr.com/photos/drewgra...7631722986412/ -- alonzo
2006 Suzuki DR650SE 1978 BMW R80/7 2009 BMW F650GS (do you think a new BMW every 30 years is too much?) 2006 Yamaha XT225 1970 Triumph Bonneville T120R "The difference between genius and stupidity is that genius has limits." Ąsǝʞıq ʇɹıp ɟo ɟɟo ʎɐʇs pןnoɥs noʎ ǝqʎɐɯ uǝɥʇ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı |
10-08-2012, 10:12 PM
#7754 |
Oddometer: 260
Low-buck GPS for your XT
It may not be a Garmin Zumo, but it is adjustable for declination
The turn-by-turn directions are a bit slow though... ![]()
10-08-2012, 10:16 PM
#7755 |
Oddometer: 2,609
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. |
