Old 05-14-2008, 09:49 PM   #781
Rainforest Rider
Oddometer: 8
Hanging 4" PVC "tool box"
Bent brackets to the two toolbox bolts and the indicator bolt.
Like so:
I made a wedge shaped piece of 1" poly insulation board shaped to match the full travel of the suspension and attached it to the top of the chainguard, then fitted the 4" poly so they didn't hit.
The brackets were fiddly to get them all lined up - best to make the first ones out of thin metal like alum flashing to get the right shape and bend. The two front tabs are on the inside and the outside.
The larger rear one is on the inside only. Rubber then fender washer on the inside of the PVC pipe to distribute the bolt loads.
1/8" 6061-T6 aluminum sheet works well, if not bent too tightly
Peter
Rainforest Rider screwed with this post 05-18-2008 at 02:24 PM Reason: Add picture
Rainforest Rider is offline   Reply With Quote
Old 05-15-2008, 04:18 AM   #782
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,833
Originally Posted by Rainforest Rider
I'm a new owner, bought this 2004 XT225 to carry on the back of my Motorhome, particularly to the SW deserts in the winter.
I made the carrier out of 1/8" aluminum sheet, ready rods and alum. square bars. It feels very solid. The pool noodle is for the passengers tailbone !
The white on top is rubber.
The tool box is a piece of 4": PVC pipe - looks ok unpainted on this color scheme. Some care in installation needed to avoid the chain guard hitting it on big bumps.
The folding brackets are cut out of nesting alum square tube, with plastic washers between the two parts. With the bolt snug, they have just the right amount of resistance when moved.
I believe all I used were a bandsaw, hole saws, drill press and a sander.
If anyone would like a few more details, just ask
Peter
Peter,
Nice job on the carrier and folding blinkers.
Vince @ SWFL or WNC
2015 Ural cT 2001 Kawasaki W650
Bar None is online now   Reply With Quote
Old 05-15-2008, 06:44 PM   #783
norvegicus
waiting for spring...
norvegicus's Avatar
Oddometer: 220
Took some pictures on my commute today. I live in Marquette, MI, on the south shore of Lake Superior. I stopped by the bicycle shop on the way home to celebrate Bike to Work Week!
200? XR100/1985 CB700s/1982 CT110 (in pieces)/1982 C70/1979 CT90/1969 CB350
norvegicus is offline   Reply With Quote
Old 05-18-2008, 02:41 PM   #784
Rainforest Rider
Oddometer: 8
Nanaimo logging Roads
Went on my first local trail ride yesterday. Started at a logging road I knew of and eventually emerged back to the highway miles away.
It was not all logged, there was some nice older forest and most of the roads were quite good. Passed only one Quad.
This is a logging bridge over Haslam Creek.
Upon looking at Google Maps later I find they show all the roads VERY well in Satellite view - including some apparently accessible small lakes to be explored.
Was pleased with the bike - not tiring to ride and does manage 60 mph on the highway without too much fuss - about 1/2 throttle methinks. Front wheel seemed quite skittish on loose gravel - more so than the little Chinese Honda Trail Bike Clone I was using, but it had smaller and fatter tires.
Peter
Old 05-20-2008, 06:48 PM   #785
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,262
So i bought my little XT for commuting and to learn how to ride dirt with. I saw the Berkshire Trail Riders Three State Ride thread and we got a NYC clan together for it.
I have a bone-stock 01 225 and I had ordered some tires and hand guards for it for this ride but because of an idiot parts guy friend they did not arrive so i rode it with half worn stock Cheng Shin's and had no rel problem. I wrote a ride report but have no pictures of me but one of me fixing a bent brake lever a friend took. I wrapped it against a rock or root at one point and bent it pretty bad. But the stock tires were up to some of the hell that was the heroes sections.
We had two XT's in our group. i wrote a ride report here
Notice the two XT's in the bed of my truck that towed two X-Challenges
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is online now   Reply With Quote
Old 05-20-2008, 06:56 PM   #786
MBreinin
Oddometer: 4
Here is mine. '06 Husky 450SMR. Love it, LOVE IT!
Mike
MBreinin is offline   Reply With Quote
Old 05-21-2008, 04:54 AM   #787
CDG
CDG's Avatar
Oddometer: 215
That's one serious looking XT225 mate.
It almost looks like a 450 Husky
2000 R1150GS
2007 GSXR 1000
1999 XTZ660
1998 TTR600
CDG is offline   Reply With Quote
Old 05-21-2008, 01:17 PM   #788
MBreinin
Oddometer: 4
Oops!
Better go post this one in the correct place.
Old 05-26-2008, 09:01 PM   #789
NDVR
Ben
Oddometer: 53
torque wrenches
I downloaded the service manual from xt225.com, and it seems that the torque settings for various fasteners have a wide range, from around 2 ft. lbs. to 61 ft. lbs. Am I right in thinking that I need to buy at least two wrenches? One for 0-20ish ft. lbs. and another for the higher settings? I've been on the Precision Instruments site....whoooo. Pricey.
NDVR is offline   Reply With Quote
Old 05-27-2008, 07:29 PM   #790
norvegicus
norvegicus's Avatar
Oddometer: 220
Correct.
I have two Craftsman torque wrenches. I'm pretty happy with them.
Old 05-30-2008, 08:08 AM   #791
HokieDNA01
Dirty Sport Girl!
HokieDNA01's Avatar
Oddometer: 183
Any recommendations on assemblies I can use to upgrade from the rear drum brake to a disk brake? I have tried searching and found some people machined their own assemblies. Is there any easy swap that can be made.
XX>XY
Fast and Dirty Toys Aren't Just For Boys!!
Myspace
2007 Suzuki GSX-r 750
2004 Kawasaki Ninja 250
2000 Yamaha XT225
HokieDNA01 is offline   Reply With Quote
Old 05-30-2008, 08:38 AM   #792
braindead0
Head Fisherman
braindead0's Avatar
Oddometer: 585
Any reason why? On a bike this light, a drum is fine really... Unless you're having problems with fading, or ride in a lot of sandy water/mud and junk gets in there...
Just seems like a lot of money for something that provides little benefit... Although there's always the farkle aspect... I'd understand that ;-)
'09 Sprint ST, '09 Bonneville SE
DoD #2223
braindead0 is offline   Reply With Quote
Old 05-30-2008, 09:22 AM   #793
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,833
Hokie,
Some of the XTers at http://www.xt225.com/ have done the conversion but I agree with braindead about the necessity unless you are packing it with mud. I assume that you know that the new to the USA XT250 has a rear disk.
Vince @ SWFL or WNC
Old 05-30-2008, 09:26 AM   #794
HokieDNA01
Dirty Sport Girl!
HokieDNA01's Avatar
Oddometer: 183
I'm not interested in making the upgrade on my bike. It is for a fellow rider that wants to buy a small DS but isn't considering the XT because of the brake. I was thinking their was a mod available. Thanks for the advice.
PS. I like my XT just the way she is!
XX>XY
Myspace
2000 Yamaha XT225
Old 05-30-2008, 09:31 AM   #795
braindead0
Head Fisherman
braindead0's Avatar
Oddometer: 585
Get him on here... we'll fix 'em ;-)..
Drum brakes are fine in most cases, my wife can easily lock up the rear... that's plenty...
Perhaps he's got farkelitis or something... Heck, I just made custom leather tank panniers for my wife's XT, probably $30 worth of leather and I know I spent far to many hours making them (redesigning and stuff) ;-).. Keep meaning to post pics, they ain't pretty but they work.
DoD #2223
Times are GMT -7.   It's 03:36 PM.
