Old 12-04-2012, 01:01 AM   #8041
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 1,982
Okay, figured out the differences... It is the mounting style... Anyone know off hand which one is right for the XT? On a business trip and want to order before I will be with the bike again.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 12-04-2012, 05:34 AM   #8042
SpokePlanter
Oddometer: 3
16 tooth sprocket
I purchased this one a few weeks ago and so far really like it:
http://www.ebay.com/itm/JT-Front-Spr...-/320559214919
SpokePlanter is offline   Reply With Quote
Old 12-04-2012, 01:48 PM   #8043
OldGypsy
FoolForDirt
Oddometer: 54
[QUOTE=woofer2609;20171173]Thanks for the info, I'm curious where you mounted the slider, is it on the side or top of the airbox?
Possible to see pics?
+1
Bring on the pictures, and exactly what you bought from Thunder Products.
Rich in Patagonia
67? YM-1, 02 FZ1, 04 XT225
OldGypsy is offline   Reply With Quote
Old 12-04-2012, 04:04 PM   #8044
Dirt2Street
Oddometer: 43
Originally Posted by kewlbyme View Post
If you get that carb clean and sorted out, you will be starting out in 2nd gear on the street like I do. 1st is pretty much my "woods" gear. Stock 15 cs.
I already start out in second just because 1st annoys me. I was more wondering what the real difference is between the 15 and 16?
Dirt2Street is offline   Reply With Quote
Old 12-04-2012, 04:23 PM   #8045
woofer2609
woofer2609's Avatar
Oddometer: 217
1 tooth.
The xt engine doesn't develop enough rpm, therefore HP, in 6th at about 55MPH to handle a (small) hill, so you'll be switching back and forth more between 5th and 6th. This bike is pretty much perfect IMHO stock, apart from farkles. To each their own. First is low enough with either 15 or 16t.
woofer2609 is offline   Reply With Quote
Old 12-04-2012, 05:10 PM   #8046
carlclaflin
Oddometer: 88
Originally Posted by nuggets View Post
Your service manual should tell you the oil change intervals. You have one?
PM me if you need one.
Anyway, yeah it is time to change your fork oil.
It sounds like your carb might need to be cleaned(google carb 101 and carb 102 for instructions).
Also your mixture screw should be adjusted if it hasn't been done.
Good luck.
Nuggets.
alright. i'm very hesitant about messing around with the carb. never done that before. i shall check it out on google. thanks
carlclaflin is offline   Reply With Quote
Old 12-04-2012, 05:27 PM   #8047
Dirt2Street
Oddometer: 43
Originally Posted by GI_JO_NATHAN View Post
I was trying to find the ones I bought for mine on ebay and ran across these.
Other than the white, I like the look.
I feel like if these were the same blue as my bike, they'd look dope! Or even Black. I'm not a big fan of the white either.
Old 12-04-2012, 05:30 PM   #8048
Dirt2Street
Oddometer: 43
Originally Posted by woofer2609 View Post
1 tooth.
Well I've heard 4th gear turns ridiculously good after making the swap. I only weigh 140lbs and have never had to downshift to keep speed up! probably cuz I don't weigh anything. I've also had my bike up to and holding about 75 without it whining...probably because I weigh nothing. lol.
Old 12-04-2012, 05:42 PM   #8049
redninja
Will ride 4 scenery
redninja's Avatar
Oddometer: 351
Aha - I just happen to have the side panel off, since I cleaned the air filter and am waiting for it to dry.
So, I took this pic just now, in the dark using the flash, and I'll be darned if the flash didn't make my bike look really dirty..... Anyway, it is called a TPI valve. In the picture, it is without the little piece of foam filter that fits in; I had taken it out to clean it (it just pulls right out through the "window"), and forgot I hadn't put it back in.
My airbox cover isn't totally flat ('97), so I had to put some shims in at the top, since the "window" needs to be flat to open and close properly. When the side panel is on, it covers it up about halfway, but the open/close part is exposed so it can be opened and closed easily. You can see the "slider" is mostly open here.
ADV relay rider CO/NM
redninja is offline   Reply With Quote
Old 12-04-2012, 06:09 PM   #8050
nuggets
Commutator
nuggets's Avatar
Oddometer: 1,175
It isn't too hard, but it isn't for everyone. You have to be careful not to do more harm than good as there are small and delicate parts in there. Maybe you can find someone who will help you out.
Does your bike idle well? If it does, your jets may be clean. The pilot jet has the smallest orifice, and is prone to clog first. Often, a bike that will run on choke, but not idle when warmed up is indicative of a dirty carb.
Drilling out the mixture screw cap and adjusting it easy. You don't have to pull the carb off the bike. The procedure is spelled out in this thread and on xt225.com. A search for "mixture screw" should find it.
2007 xt225
2004 KX250 - Soil Sampler
Nuggets' free bike tech clinic.
nuggets is offline   Reply With Quote
Old 12-04-2012, 06:10 PM   #8051
redninja
Will ride 4 scenery
redninja's Avatar
Oddometer: 351
AHA! again...just remembered I have a brand new TPI valve for another bike which I have not yet installed:
Here, the little foam filter is visible:
Old 12-04-2012, 06:16 PM   #8052
woofer2609
woofer2609's Avatar
Oddometer: 217
Cool! Thanks so much! I was wondering if you'd be able to move the slider without taking off a side panel. The ability to adjust the mixture while riding will be much appreciated. Gotta get me one!
Old 12-04-2012, 06:48 PM   #8053
TwilightZone
Oddometer: 1,950
>"alright. i'm very hesitant about messing around with the carb. never done that before. i shall check it out on google. thanks "
I took the carb off the bike... to remove it you need to loosen the airbox (only a couple fasteners) and 'fool around' a bit with the carb to get it to come out.
The hard part on the carb is the f'n screws holding the float bowl on. Odds are you will strip a screw,
(I did)... and will need a dremel tool to grind the head off the screw. When you put it back together,
buy some stainless allen head screws hold the float bowl on. Note that 1 of the screws is a bit longer
than the others, it holds a wire bracket.
Once the bolts are off the carb, the jet conversion/cleaning whatever is very simple.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga!
TwilightZone is offline   Reply With Quote
Old 12-04-2012, 08:43 PM   #8054
Dirt2Street
Oddometer: 43
Pissed Handlebar upgrade!
Anybody out there know the specs of the stock handlebars? I want to upgrade to get better control offroad. I don't have an owners manual so I can't just look it up..Great bike and great deal just urks me he didnt have it. I'll be buying that first, I suppose.
"Live for nothing or die for something...your choice." -Sylvester Stallone
Old 12-04-2012, 08:59 PM   #8055
OldGypsy
FoolForDirt
Oddometer: 54
TPI Slider
Thanks for posting the pics. Hope this thing will be a cure for the sputtering and coughing at 8-11k' feet - the only problems I had last summer on the GDR when trying to keep it going +50mph.
Rich in Patagonia
Times are GMT -7.   It's 06:08 AM.
