Old 12-04-2012, 10:18 PM   #8056
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,718
Originally Posted by Dirt2Street View Post
Anybody out there know the specs of the stock handlebars? I want to upgrade to get better control offroad. I don't have an owners manual so I can't just look it up..Great bike and great deal just urks me he didnt have it. I'll be buying that first, I suppose.
Don't know that the specs will be in the owner's manual, but you should be able to take some measurements and find a ProTaper SE (Seven-Eights, as in 7/8" diameter) that works. You can view/download a non-printing pdf version of the owner's manual by going here:
http://www.yamaha-motor.com/sport/se...t_manuals.aspx
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is online now   Reply With Quote
Old 12-05-2012, 03:14 AM   #8057
kewlbyme
Occasional Partaker
kewlbyme's Avatar
Oddometer: 228
I really like these.
Tusk Mini High Bend Bars - Awesome, make standing excellent. Ordered Here
Tusk Hand Guards - Excellent product! Ordered HERE
Progrip 714 Grips - Ordered HERE . They are good. I also like Progrip 737's, found HERE , which I have used many times and might actually prefer.
Write up and pictures for bars and guards in THIS thread. I am DSCR over there.
Larger pegs from DMO - Pricey but no alternative and an excellent product. Ordered HERE
These made off road MUCH better.
I like'em a lot.
2001 XT225
2003 XT225
2005 DL650 - Sold
2002 KLR 703.5 - Sold
1999 Valkyrie IS - Sold
kewlbyme screwed with this post 12-05-2012 at 03:26 AM
kewlbyme is offline   Reply With Quote
Old 12-05-2012, 09:38 AM   #8058
gbacque
gbacque's Avatar
Oddometer: 75
Originally Posted by TwilightZone View Post
The hard part on the carb is the f'n screws holding the float bowl on. Odds are you will strip a screw,
(I did)... and will need a dremel tool to grind the head off the screw. When you put it back together,
buy some stainless allen head screws hold the float bowl on. Note that 1 of the screws is a bit longer
than the others, it holds a wire bracket.
Once the bolts are off the carb, the jet conversion/cleaning whatever is very simple.
That is because there are no phillips screws on Japanese bikes. They use JIS screws.
Very similar but if you use use a phillips screw driver on the JIS screw you can see from the image above that it would not seat all the way to the bottom. If you grip just the lip of the fastener then it will strip out very easily. An undersized phillips fits much better but then you are giving up surface area and still risk stripping it. Finding a quality JIS screwdriver in the states can be a bit of a challenge. For some reasons most places don't carry them. So you might need to order it online.
On that bowl though, they have pan heads on them so there is just enough meat to grab that thing with some vice grips.
gbacque is offline   Reply With Quote
Old 12-05-2012, 12:21 PM   #8059
greasespot
Oddometer: 44
Wheels?
Hey, which wheels are direct bolt-ons to the xt? Someone mentioned TTR225 wheels. True? Any others?
TIA,
Greasespot
greasespot is offline   Reply With Quote
Old 12-05-2012, 03:09 PM   #8060
DominoTree
EX250 Warrior
DominoTree's Avatar
Oddometer: 95
Any options for a center stand since it looks like Cigar Mike is out of the game?
"At each stop, fill up the oil, and make sure to check the gas."
2006 Yamaha XT225
Gone but not forgotten:
1990 Kawasaki ZX6D, 1990 Honda VFR750F, 2008 Kawasaki EX250J, 2005 BMW F650GS (Single)
DominoTree is offline   Reply With Quote
Old 12-05-2012, 03:23 PM   #8061
nuggets
Fries with that?
nuggets's Avatar
Oddometer: 1,809
TIA,
Greasespot
My research indicates that the ttr225 wheel can be bolted on, but you need the ttr brake assembly also, and will have to modify it slightly. The ttr hub is larger in diameter, so the rear brake is not a direct swap. I have not confirmed this with the parts in hand, just via parts fiche and google searches.
My rear wheel is currently disassembled. I have ordered a new rim, and a set of thicker straight gauge spokes. I considered switching to a ttr wheel, but I can get the spokes and rim for $130 less, and I don't mind lacing and truing up the wheel myself.
2001 400 EXC "Punkin" | 2005 Sherco 290 "Tree Climber" | OSET 16.0 | OSET 16.0 hard tail
nuggets is online now   Reply With Quote
Old 12-05-2012, 07:16 PM   #8062
KamperBob
Recreation Engineer
KamperBob's Avatar
Oddometer: 254
Originally Posted by woofer2609 View Post
This bike is pretty much perfect IMHO stock, apart from farkles. To each their own.
+1
My 2006 still runs great with stock tuning. Going on 28k miles. Haven't been above 10,000' yet. I'm currently at -200' (Death Valley). Judging from posts here I must be lucky not to have a problem that needs fixing. Yamaha got mine right anyway.
Kamper Bob
(read about Half Pint's adventures at Recreation Engineer)
KamperBob is offline   Reply With Quote
Old 12-06-2012, 10:20 AM   #8063
woofer2609
woofer2609's Avatar
Oddometer: 740
TIA,
Greasespot
I own a ttr225 wheel that I use on my xt. It requires some mods discussed here:
http://advrider.com/forums/showthrea...78968&page=478
Post #7168
The big brake is
Easy, fast swap.
FWIW, I got my wheel for under $120 WITH a tire and tube, make sure you get the brake assembly, however. I love having two wheels. The hard part is the drilling of the sprocket, but it isn't too bad for someone w/ a drill press.
woofer2609 is online now   Reply With Quote
Old 12-06-2012, 02:22 PM   #8064
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Any chance that you have a pic of the TTR backing plate?
Preferably unmounted.
The same 110/130 swap can be done to the TW. Slightly different hardware, but the backing plate is key.
Help a cousin out.
Lizrdbrth screwed with this post 12-06-2012 at 03:47 PM
Lizrdbrth is offline   Reply With Quote
Old 12-06-2012, 02:57 PM   #8065
GlennF33
Oddometer: 112
I have one of the last ones he made. I haven't put it on yet as I can raise my bike on a platform floor jack to do any service requiring elevation. Nice workmanship. I would like to sell it.
GlennF33 is offline   Reply With Quote
Old 12-06-2012, 03:00 PM   #8066
Dirt2Street
Oddometer: 53
I like'em a lot.
So 7/8 is what you went with? I'm looking at renthals right now because I'm a young kid, (17) so lets face it, this thing will be layed down a time or two..hopefully not anytime soon though. :l Dreading that day. But anyways, I need something that'll hold up and these renthals i'm looking at are on sale and are a REALLY good deal for the brand. All my friends, even a few that race(d) MX had and have Renthal and say they're the best..
How do the tusks do on pavement? I'm up for suggestions.. All
"Live for nothing or die for something...your choice." -Sylvester Stallone
Dirt2Street is offline   Reply With Quote
Old 12-06-2012, 03:37 PM   #8067
kewlbyme
Occasional Partaker
kewlbyme's Avatar
Oddometer: 228
7/8 is standard size. If you go with the 1 1/8 bars dont forget the adapter. They are only thicker at the center clamping area. They too, are 7/8 at the grips. I went with standard 7/8. My son in law dumped the bike and wacked the guards pretty hard and twisted the forks. The bars were unmolested.
The Tusk is great on the road or off. My second XT was acquired with a Renthal bar and risers. They are fine too, just wider. The Renthal/riser combo raises the height about the same as the Tusk Mini High's. I have Moose guards on the Renthals.
I personally like the Tusk Mini High Bend better because of the inherent height without risers. The Renthals are fine bars regardless.
I show pictures of both in the thread I posted above.
2001 XT225
2003 XT225
2005 DL650 - Sold
Old 12-06-2012, 05:37 PM   #8068
Roadrunner
(Negativus Supersonicus)
Roadrunner's Avatar
Oddometer: 23,334
Originally Posted by 150ron View Post
You are hanging out in the wrong place
http://advrider.com/forums/showthread.php?t=403156
Wow! All this time I was in here, because when I joined there was no 250 thread.
Thank you!
"System change is not for the conceptually or interpersonally fainthearted." - Sarason
Roadrunner is offline   Reply With Quote
Old 12-07-2012, 04:16 PM   #8069
inroads
Wimberley,Texas
Oddometer: 228
Anyone here who could shed some light on my shock conversion? I was under the impression that the TTR 225/230 rear shock would bolt onto the 225. I just received my shock off Ebay and there are 2 things that are different.
The bottom yoke that bolts to the swingarm is a lot more narrow than the 225.2nd problem is the top mounting bolt is smaller than the 225. Any help appreciated!
inroads is offline   Reply With Quote
Old 12-07-2012, 04:44 PM   #8070
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,226
Can't say the the 235 and 230 shock are the same. But the TTR225 is a 100% bolt up match with the XT225. I have done this swap myself.
Either the TTR 225 and 230 are different or you got the wrong shock.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Times are GMT -7.   It's 07:12 PM.
