12-27-2012, 09:17 AM
#8281 | |
Can I ride it?
Oddometer: 3,518
All I’ve done so far is the 3 turns & took a hole saw to the pipe. Runs fine here at lower the elevations but will probably do some intake mods to open it up more & bigger jets eventually. |
12-27-2012, 09:23 AM
#8282 | |
Bronze Age Fall Guy
Oddometer: 5,125
Hate gets you nowhere. |
12-27-2012, 09:51 AM
#8283 |
Can I ride it?
Oddometer: 3,518
12-27-2012, 09:53 AM
#8284 |
Can I ride it?
Oddometer: 3,518
One more ...
#8285 | |
Occasional Partaker
Oddometer: 227
2001 XT225 2003 XT225 2005 DL650 - Sold 2002 KLR 703.5 - Sold 1999 Valkyrie IS - Sold |
12-27-2012, 10:10 AM
#8286 |
Can I ride it?
Oddometer: 3,518
12-27-2012, 11:20 AM
#8287 |
Oddometer: 103
Thanks to all for your input on putting my bike back to stock. Should receive the carb soon(Sat.) Will post with results next week after install. Has anybody used the Keintech adjustable Pilot Screw? How did it work for you?
12-27-2012, 11:25 AM
#8288 | |
Occasional Partaker
Oddometer: 227
Sent from my Galaxy Nexus using Tapatalk 2
12-27-2012, 11:28 AM
#8289 |
Occasional Partaker
Oddometer: 227
They are pretty thin. Proportional to the diameter, if you will. I have to lick my finger to get the washer to stick to it to pick it up from a flat surface. That thin.
12-27-2012, 11:36 AM
#8290 |
Can I ride it?
Oddometer: 3,518
12-27-2012, 04:17 PM
#8291 |
Oddometer: 564
yeah i got two inch riser and i dont recall if any slack after that...but two inch worked great, big diff.
dirt bikes, vstrom, cruiser, etc. "what hurts, instructs" - ben franklin |
12-27-2012, 07:42 PM
#8292 |
Oddometer: 30
12-27-2012, 08:25 PM
#8293 |
Oddometer: 30
I was really surprised at how capable my new (used 2001) XT225 is at climbing really steep terrain.
So far I've made every single hill I've attempted. The picture does not do it justice at just how steep that hill was. ![]() No slipping, sliding, rear tire just grips and pushes. ![]() I have the Kenda 270's front and rear.
12-27-2012, 08:59 PM
#8294 | |
Oddometer: 125
You can probably find suitable small washers at a hardware store- take a micrometer or caliper with you to check thickness. Or you could order them here: http://www.motorcyclecarbs.com/Jet_N...12__P10478.cfm Cheers, Dave
1999 DR350SE- Mine 1992 XT225- Queenbee's 2007 CRF150F- Princessbee's |
12-28-2012, 04:36 AM
#8295 |
Oddometer: 91
GlennR, I'm running renthal Atv bars on my xt and I ran into a problem with the bar ends... I'm not sure if all Atv bars are this way, but mine had the reinforcing inner sleeve (or thicker diameter tube) extend into the area where the bark buster expansion bolt would normally go. This took a lot of modifying but I finally got the bars to work. As for height, I love the way it allows me to comfortably stand. The problem with going to high will be modifying the cable lengths for throttle, brake, clutch...
