12-28-2012, 04:43 AM
#8296 | |
Oddometer: 91
12-28-2012, 08:59 AM
#8297 | |
Can I ride it?
Oddometer: 3,513
Per your link the shims are .5mm or just a hair under .02”, (0.01968498”), thick. Oftentimes you don’t want to make much of a change to the needle height. Surprised that you went up 1.5mm. |
12-28-2012, 03:31 PM
#8298 |
Recreation Engineer
Oddometer: 226
Chain stretch
As some may recall in late August @24k miles I replaced the rear sprocket and chain on my 2006 XT225. (The sprocket was 45T stock size but aftermarket brand.)
Instead of another O-ring chain I bought two standard (unsealed) chains. Chain #1 was replaced in late October @26k miles. It measured 60.375" long. Chain #2 new measured 60" long. So it stretched 0.375" or 0.63% in 2k miles. Chain #2 was replaced today (late December) @28k miles. It measured 60.25" so stretch was 0.25" or 0.42% in 2k miles. Caveats: * While mileage was similar between these two intervals road/trail conditions were very different. So this isn't really a "fair" comparison. Still some might be interested in these measurements anyway. * In both cases the "other" chain gets washed in gas (kerosene not readily available). Then after drying soaked in 30W oil for at least a week. Then drip dried before reinstallation. The experiment continues. Going forward I'll keep a close eye on chain and sprocket wear during round #2 for both chains. I can swap sooner (ie, every 1k miles) if needed. Meanwhile, Plan A is to keep playing leap-frog between both chains every 2k miles. Cheers Bob |
12-28-2012, 05:15 PM
#8299 | |
Occasional Partaker
Oddometer: 227
Any surface cleaning or lube between swaps? Any sign of sprocket wear? I will look for updates. Sent from my Galaxy Nexus using Tapatalk 2
2001 XT225 2003 XT225 2005 DL650 - Sold 2002 KLR 703.5 - Sold 1999 Valkyrie IS - Sold |
12-28-2012, 05:52 PM
#8300 | |
Oddometer: 216
I know this'll make me sound like a know it all, but chains don't actually stretch, they develop play between the rivets and the plates. ![]() Now, if only we could turn the rear sprocket over, think of the tooth life! |
12-28-2012, 10:59 PM
#8301 | |
Can I ride it?
Oddometer: 3,513
If you really want kerosene, as chain makers recommend, I believe that you could substitute diesel fuel. Diesel is at most any gas station & nearly the same thing as kerosene. I read that one main difference between kerosene & diesel is that kerosene does not have the lubrication properties that diesel does. Kerosene is added to diesel fuel to winterize the diesel. Last time I cleaned an O-ring chain real good I had a small amount of cleaning solvent in a gallon jug. I mixed some diesel in with it to have enough to submerge the chain & shake it around & so on. As for soaking the chain in oil.... Years ago before they made O-ring chains I would put the chain in a pan of oil & heat it on the stove. Must have read that method in a MC magazine. (X-)Wives love it too.
12-29-2012, 06:15 AM
#8302 |
Wimberley,Texas
Oddometer: 76
WD 40 has changed its formula somewhat thru the years.You use to be able to spray it into the intake almost like some diluted ether and have the bike fire off.
Today's stuff is more tame.My point is: I use wd 40 extensively as a cleaner to keep my o-ring chain clean as to not ever get to a build up.I believe the problem with most chain lubes is they are not wiped clean after application and then tend to attract dirt. So I have gotten to the point since I ride off road often to just use wd-40 liberally and wipe clean after use. Many bikes and many years of WD-40 o-ring use with good results.But you do have to apply twice as often as chain lube. I do not believe todays WD-40 hurts O-ring chains. |
12-29-2012, 07:28 AM
#8303 |
Recreation Engineer
Oddometer: 226
No visible sprocket wear. I don't clean the chain between swaps. I spray teflon/silicon lube into links and rollers whenever it seems prudent.
12-29-2012, 07:36 AM
#8304 | |
Recreation Engineer
Oddometer: 226
I'm skeptical about flipping sprockets over. Offset is an immediate obstacle. Chuckle. I'm okay calling the increase in length of the whole chain stretch. It's measurable. That's the point. Marks on the wheel adjustor give another indication. "If you cannot measure it, you cannot improve it." --Lord Kelvin |
12-29-2012, 08:00 AM
#8305 | |
Recreation Engineer
Oddometer: 226
I considered diesel but that would take another container. Whereas I have a gas can with (full time RVer) and I'm satisfied that's good enough. It's just solvent to break down gunky old oil so dirt particles can be swished out of the works and make way for fresh lube. Once dried gas residuals can't contaminate a bowl of clean oil too badly. That's my thinking anyway. Heck, my "clean room" these days is a picnic table...when dust isn't blowing. LOL |
12-29-2012, 08:04 AM
#8306 |
Recreation Engineer
Oddometer: 226
Posting pix
I'll try to post some pix today. I don't see an "attach" option and my website FTP is down (temporarily I hope). Maybe it's time to set up one of them thare web-pic-share account thingiemajiggers. What do members here prefer - flicker, photo bucket, smug mug, something else?
12-29-2012, 08:28 AM
#8307 |
Dodgin' the Ditches
Oddometer: 1,156
I guess they are all about the same, but I have been using Photobucket. It's simple enough for me.
![]() What is "FTP"? |
12-29-2012, 08:37 AM
#8308 | |
Recreation Engineer
Oddometer: 226
I started exploring Flickr this AM but I'll play with Photobucket too. Thanks! |
12-29-2012, 08:38 AM
#8309 | |
Oddometer: 27
I understand the owner of this site owns smug mug??
Travis28715 screwed with this post 12-29-2012 at 08:43 AM Reason: more info |
12-29-2012, 08:46 AM
#8310 |
Recreation Engineer
Oddometer: 226
Pic test
Let's see if this works...
![]() Woot - since that worked pretty well here's the caption. Left is late Oct 2012 hung from a sign post. Middle is late Dec 2012 hung from a tree. Right follows. Top is new length of Chain #2 (taken Oct). Middle is length after first 2k miles wear on Chain #2 (Oct). Bottom is same for Chain #1 (Dec). KamperBob screwed with this post 12-29-2012 at 10:27 AM Reason: fix |
