12-30-2012, 07:23 AM
#8326 | |
Recreation Engineer
Oddometer: 226
12-30-2012, 08:53 AM
#8327 |
Oddometer: 8
I have a 2005 XT225 Cdn model. It came with a 120 main jet. I went to a 130. Much better for me. Sea level to about 5000 feet. I did open up the airbox and muffler. Shim under the needle and three turns out on the idle screw. Its the way it should have been from the factory.
paco |
12-30-2012, 09:37 AM
#8328 | |
Oddometer: 217
I have stayed completely stock. I haven't had the carb off because I do not want to screw it up, nor have I adjusted it. The original owner told me the same thing; he hadn't touched it! Not tinkering with it is hard for me I am going from a 1996 Yamaha service manual, note that model 4BE3 is the canadian spec.
woofer2609 screwed with this post 12-30-2012 at 10:06 AM |
12-30-2012, 02:26 PM
#8329 |
Oddometer: 30
I find that the engine is screaming and I'm only doing 60mph.
Can someone please let me know what the stock sprocket numbers are so I can determine if my bike is stock or modified? cheers |
12-30-2012, 02:37 PM
#8330 |
Recreation Engineer
Oddometer: 226
15 front, 45 rear
12-30-2012, 05:01 PM
#8331 |
Oddometer: 573
lots go to a 16 front , i did, and like it better for the street. takes about 15mins to swap. i've gone with bigger tires now tho so i might go back down to 15
dirt bikes, vstrom, cruiser, etc. "what hurts, instructs" - ben franklin |
12-30-2012, 06:27 PM
#8332 | |
Recreation Engineer
Oddometer: 226
![]() We'll see if my Murphy Insurance pays off or not. LOL |
12-31-2012, 05:18 AM
#8333 |
Oddometer: 27
Tom S, shims are .5mm or just a hair under .02”, (0.01968498”), thick.
This from the ANSI site: American National Standard ( ANSI) Spenard (SBS) has a pretty good assortment in their bins. They don't have the impressive orange vests but are worth a try. Nominal Size Decimal Equiv. Size Series Inside Diameter Outside Diameter Thickness No. 0 0.060" N 0.0680 0.1250 0.0250 R 0.0680 0.1880 0.0250 W 0.0680 0.2500 0.0250 No. 1 0.073" N 0.0840 0.1560 0.0250 R 0.0840 0.2190 0.0250 W 0.0840 0.2810 0.0320 No. 2 0.086" N 0.0940 0.1880 0.0250 R 0.0940 0.2500 0.0320 W 0.0940 0.3440 0.0320 No. 3 0.099" N 0.1090 0.2190 0.0250 R 0.1090 0.3120 0.0320 W 0.1090 0.4060 0.0400 No. 4 0.112" N 0.1250 0.2500 0.0320 R 0.1250 0.3750 0.0400 W 0.1250 0.4380 0.0400 No. 5 0.125" N 0.1410 0.2810 0.0320 R 0.1410 0.4060 0.0400 W 0.1410 0.5000 0.0400 No. 6 0.138" N 0.1560 0.3120 0.0320 R 0.1560 0.4380 0.0400 W 0.1560 0.5620 0.0400 for those already confused
Travis28715 screwed with this post 12-31-2012 at 08:39 AM |
12-31-2012, 06:44 AM
#8334 | |
Oddometer: 573
from home depot: small med large big hole little hole skinny fatter hey...we are talkin washers, right? not only confused but dont take long before my mind goes elsewhere
12-31-2012, 06:45 AM
#8335 | |
Oddometer: 573
12-31-2012, 06:47 AM
#8336 | |
Oddometer: 4,585
'01 Kawasaki W650 '05 Yamaha XT225 |
12-31-2012, 06:56 AM
#8337 | |
LFC-7!
Oddometer: 2,404
Dodging cagers since 1972 AMA #563452 - AW #6274 / '98 ST-1100 - '01 DRZ-400s MD TOR MD Tag-O-Rama Map MD RTE Thread $5 Smug Mug coupon |
12-31-2012, 07:33 AM
#8338 |
Oddometer: 4,585
Anybody offhand know the diameter in mm of the front and rear axles?
12-31-2012, 08:11 AM
#8339 |
All Hail Seitan!!!
Oddometer: 5,561
I didn't measure mine, but since they take 6202 bearings, it has to be 15mm since that is the i.d. of the bearings.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966 |
12-31-2012, 08:20 AM
#8340 |
Oddometer: 27
PNW wrote: A small diameter hose that runs from a small plastic elbow from the left side of the carb near where the fuel hose attaches to the carb broke off with the tiny plastic nipple in the hose, it must have been very brittle as I didn’t realize that I even bumped it at all. The parts diagram in the manual doesn’t list the function of this hose, maybe a vent? I doubt if the plastic elbow fitting is replaceable, it isn’t listed in the parts diagram. Anyone have any ideas what to do with it?[/SIZE][/FONT]
I believe that to be the overflow hose. Does it come from float bowl area? Travis28715 screwed with this post 12-31-2012 at 09:45 AM |
