Old 07-03-2008, 04:44 PM   #871
braindead0
Head Fisherman
braindead0's Avatar
Oddometer: 585
Originally Posted by NJ-Bill
A few months ago, I richened up the jetting (pilot and main) and the bike ran much better. I think I went a little too rich as I got a slight bog when opening the throttle while lugging the engine. I prefer to run a little rich as opposed to lean. Today, I decided to try the bike without the snorkel. The result was amazing. The bike pulls harder through the entire RPM range, especially off the bottom. I am very pleased. There is a slight increase in intake noise, a deeper growl, but it is not offensive.
What you running for the jetting? We're actually selling ours, and it's jetted pretty well.. but I'd just like to know ;-)
'09 Sprint ST, '09 Bonneville SE
DoD #2223
braindead0 is offline   Reply With Quote
Old 07-03-2008, 06:58 PM   #872
NJ-Bill
Life is good
NJ-Bill's Avatar
Oddometer: 571
130 main, 42.5 pilot, idle jet screw 2.5 turns out, Z1 mod, Uni air filter
Cabot Trail Summer 2014
NJ-Bill is offline   Reply With Quote
Old 07-04-2008, 08:22 AM   #873
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Were is the best place to find pilot jets? Local Stealership just looked at me funny and said they only order as needed, but they'll get me one for 16 bucks plus shipping.
Bike already has a 130 main, a UNI filter, and the Z1 mod done. While I'm in there, I figured I'd do the shim, and 42.5 pilot to round out the basic mods.
Carb is in the Ultrasonic. I'm adjusting the valves. Cleaning a little gunk out of the tank. New tires, brakes, etc... you know the drill
Buzztail is offline   Reply With Quote
Old 07-04-2008, 09:18 AM   #874
_SMF_
_SMF_'s Avatar
Oddometer: 144
Try calling the Thumpertalk OEM store. Should be cheaper than that.
_SMF_ is offline   Reply With Quote
Old 07-04-2008, 09:59 AM   #875
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Thumb
HERE is where I purchased XT225 jets.
Old 07-08-2008, 09:03 AM   #876
reddogguy1
Flying Under The Radar
reddogguy1's Avatar
Oddometer: 442
Fender Eliminator
I have read most of the thread, not all. Does anyone have a sugestion on, or where to get a less clunky tail light/blinker/license plate configuration? Sorry if this is 205.
It is hard to soar like an Eagle when you nest with buzzards. <<<< Jollyrogers
reddogguy1 is offline   Reply With Quote
Old 07-08-2008, 07:48 PM   #877
Jiminy Cricket
Jiminy Cricket's Avatar
Oddometer: 535
Try searching for an Acerbis Baja fender. Gnarly Parts USA : Acerbis Baja Rear Fender White W/Taillight Pretty universal fit and good coverage.
Jiminy Cricket is offline   Reply With Quote
Old 07-09-2008, 01:15 PM   #878
procycle
procycle's Avatar
Oddometer: 2,306
Anybody here running the Mikuni TM33 pumper carb setup?
Can you tell me what your jetting setup is?
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 07-14-2008, 12:42 PM   #879
Jolly705
Jolly705's Avatar
Oddometer: 2,449
I may be purchasing an XT225 for my girlfriend this week. If I go look at one is there anything to look out for? What are the top 5 must do mods to a stock XT? Thanks
Jolly705 is offline   Reply With Quote
Old 07-14-2008, 12:50 PM   #880
braindead0
Head Fisherman
braindead0's Avatar
Oddometer: 585
Wanna drive to northeast Ohio? We're selling my wife's (she upgraded to a DR650) ;-).
Okay, as for your question. I think the top mod in my book is sorting out the jetting for best running. What other mods depend a lot on intended use. If you plan on doing a lot of riding at 60+mph I'd recommend going up one tooth on the front sprocket and a windscreen (we used a Turbo City which my wife simply loved, ended up moving it to the DR650).
If travel is planned, a rear rack would be really nice to have.
Change oil, fill with gas... ride...ride...ride...repeat. As far as I can tell the XT is pretty well sorted out from the get go. Perhaps others can chime in on some weak points, but I have yet to find any worth noting.
DoD #2223
Old 07-14-2008, 03:19 PM   #881
TomJoad
TomJoad's Avatar
Oddometer: 66
handlebars with risers
I bent the stock bars this weekend. Anyone put on 1 inch risers and add an aluminum handlebar? Any suggestions on which handlebar? I do not want the bar to sweep back too close to my body.
Eminence front....it's a put on.
TomJoad is offline   Reply With Quote
Old 07-14-2008, 07:32 PM   #882
Jolly705
Jolly705's Avatar
Oddometer: 2,449
Thanks for the tips, here she is, just picked her up an hour ago.
Old 07-14-2008, 07:50 PM   #883
Jiminy Cricket
Oddometer: 535
Yes, Protaper SE CR high and 1" risers. Make a huge difference in standing riding. Together they are maybe 2 1/2" higher, only slightly more sweep, but wow, what an improvement. I don't know what Yamaha was thinking with that low bar.
Old 07-14-2008, 08:14 PM   #884
Jiminy Cricket
Oddometer: 535
Compare the height of the bars with Jolly's posted above. Sweep is slightly more, maybe a 3/4" if i remember right.
Old 07-15-2008, 07:16 AM   #885
Jolly705
Jolly705's Avatar
Oddometer: 2,449
Bill
Thanks for the tips. I will look into it on xt225.com
1. turn the fuel screw out 3 turns
2. Z1 mod
3. 42.5 pilot, 130 main
4. pull the snorkel
5. Devilman's pegs
All of these mods are described in detail at XT225.com.
Times are GMT -7.   It's 03:50 PM.
