Old 08-01-2008, 10:47 PM   #931
rakad
Oddometer: 274
Where to buy smaller rear sprocket for XT225?
I'm looking for a smaller-than-stock rear sprocket for my XT225. Stock size is 45 teeth. I'd like 42 teeth or smaller, but can't find one for sale anywhere. ThumperTalk has a couple part numbers for 42s, but don't sell the part.
Any suggestions?
By the way, I already have the larger 16-tooth countershaft sprocket. I want to run it with a smaller rear sprocket to get my highway rpms down further. Thanks y'all.
rakad is offline   Reply With Quote
Old 08-02-2008, 06:17 AM   #932
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,541
I have never heard of anyone going with a smaller rear sprocket on the XT225 since the front is much easier to change out.
Sprocket Specialists http://www.sprocketspecialists.com/S...?txtSearch=502
has 17-22 front sprockets but I have never fitted a larger than 16 tooth so don't know about problems with the larger sizes. The stock chain might be too short for a 17.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 08-02-2008, 09:26 AM   #933
Rainforest Rider
Oddometer: 8
Valve Noise
Originally Posted by mel brooks
I shot a quick video of the bike idling. This is from a cold start, with choke. The bike makes this noise while idling and while underway. Again, valves have been checked and re-checked.
Is this normal engine noise for the XT?
Thanks guys....
As has been stated this sure sounds like valve noise. I have just adjusted the valves on my 2004 for the first time, and it wasn't all that obvious when the "timing mark" was lined up with the "arrow", AND the engine was at TDC. I used the old trick. Stick a finger in the plug hole and listen for the hiss of air as the piston comes up on the compression stroke, then use a piece of wire in the plug hole and contacting the top of the piston to jog the engine till the piston is right at the top. Sure enough, the marks were right on AND I knew I was at TDC not one revolution out.
Based on my experience it would have been possible to adjust the valves on the exhaust stroke without this check.
Rainforest Rider is offline   Reply With Quote
Old 08-02-2008, 11:11 AM   #934
40cu.in.of.furey
40cu.in.of.furey's Avatar
Oddometer: 223
How hard was it to put the TTR225 rear fender on?
Originally Posted by Squall Line
Here are a few pictures of my bike reposted from xt225.com. The only disappointment on this bike is the rear wheel/ brake assembly. Mods are : TTR225 rear fender with a WR taillight assembly; Promoto rack; FMF slip on; Renthal YZ bend bars; Cycra probends with triple tree mounts; rejetted with a 130 main and 42.5 pilot with 2.5 turns on the screw... It runs like a champ for its size.
07 DR650SE w/ FCR MX carb
01 Honda VFR800FI
73 Honda SL125
40cu.in.of.furey is offline   Reply With Quote
Old 08-02-2008, 02:49 PM   #935
Hatch
PAR OG
Hatch's Avatar
Oddometer: 3,196
hey man, did you send those to Muniac on xt225.com? hes lookin for cool xt shots, and youve got a few!
"No man ever steps in the same river twice, for it's not the same river and he's not the same man."
Hatch is offline   Reply With Quote
Old 08-02-2008, 03:15 PM   #936
rakad
Oddometer: 274
How to remove the XT225 brake pedal?
I need to pull off my right side engine housing in order to take a look at the clutch plates & springs. The only thing stopping me is the brake pedal. How does it come off? It seems that there might be a circlip on the inside end of the pedal's pivot, but I can't tell for sure because I can't see it. I don't feel anyplace to grab it with circlip pliers.
How do I get the pedal off?
Old 08-02-2008, 03:21 PM   #937
Jolly705
Jolly705's Avatar
Oddometer: 2,445
Buzz
The jets are in and they shipped on Friday
Originally Posted by Buzztail
Anyplace else? Scott is out of stock, and the dealer can only get a 40 because that is what was stock
Jolly705 is offline   Reply With Quote
Old 08-02-2008, 06:14 PM   #938
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,230
It is a circlip and I was able to get it by spinning it so the C faced forward and pushing it a bit with a small pair of pliers. I then spun the bolt and using some small angled needle nosed pliers pulled the clip off and then unbolted it.
If you remove the brake rod I wonder if it moves enough though?
RichBeBe is offline   Reply With Quote
Old 08-02-2008, 08:31 PM   #939
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
We picked up my wife's new to us XT225.
Bike has 700 miles on it. We paid $2650. Nae a scratch nor blemish... was ridden by an old feller with his wife on a matching bike.
But if you want to get technical, we only paid $850 for the bike..
Registration and insurance on Monday. Learning the wife monday evening in a nice cushy field.
LaOutbackTrail is offline   Reply With Quote
Old 08-05-2008, 06:39 AM   #940
Trust
I'll fix that
Trust's Avatar
Oddometer: 1,390
Originally Posted by LaOutbackTrail
.... Learning the wife monday evening in a nice cushy field...
Props on the learning - picked this'n up last night! Roommates will learn in a cushy field... now to just find that field....
Buy my DR350 ...and... Got any Pink gear for sale?
Originally Posted by focallength View Post
If you dont remember, sky, ground,sky,ground,sky, ground, treeeeeee! You passed out.
Originally Posted by SkidMarx View Post
Herding drunk cats drunk. That takes it up a notch.
Give me riding.
Trust is offline   Reply With Quote
Old 08-05-2008, 01:07 PM   #941
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
We just got the XT225 for my wife. I am trying to decide which luggage rack option to go with. I want a tail and side racks.
I like Dirt-Bagz, but they dont make the kit for the XT. Brackets wouldnt be that hard to make for the XT... Why doesnt Dirt-bagz make them?
I have the means of making a bracket to keep bags off the exhaust and chain side... but then i'm not sure which bags to get. My wife would be carrying the lighter stuff, clothes, sleeping bags, tent, etc.
Anyone know where lists of XT225 accessories are?
Old 08-05-2008, 07:31 PM   #942
Hatch
PAR OG
Hatch's Avatar
Oddometer: 3,196
Laoutback, check xt225.com - theres all kindsa stuff on there
my question:
has anyone had any experience with JT sprockets 16 tooth front sprocket? I ordered an AFAM from thumpertalk, but it was backordered a month so they said they could get one from JT, but it might not fit. thoughts?
Old 08-05-2008, 08:15 PM   #943
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,541
laoutback,
Turbo City at http://www.turbocity.com/default.php?cPath=69_85
makes a tail and side rack.
Vince @ SWFL or WNC
2001 Kawasaki W650
2015 Ural cT
Old 08-06-2008, 07:30 AM   #944
Trust
I'll fix that
Trust's Avatar
Oddometer: 1,390
Originally Posted by Barnone
laoutback,
Engine guard good from them? And the skid plate, worth it to upgrade from stock? (I definitely think the engine guards would be good.... tell me why not...)
Give me riding.
Old 08-06-2008, 08:03 AM   #945
Trust
I'll fix that
Trust's Avatar
Oddometer: 1,390
Originally Posted by LusterBroil
Here is a bad cell phone pic of my 04 12,000 miles young
Luster, is that a rack from a DR(650)?
Give me riding.
Times are GMT -7.   It's 12:28 PM.
