Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-10-2010, 10:50 AM   #16
the venturer
the venturer's Avatar
Oddometer: 1,421
Lots of flags are still on the screen when I use WinGDB. Besides, the unit says'' the route shortened''
Just don't want to see the flags on this: http://ul.to/gnzx5y
P.S. Unit: Streetpilot 2820
the venturer is offline   Reply With Quote
Old 06-10-2010, 11:36 AM   #17
Trailryder42
Trailryder42's Avatar
Oddometer: 1,061
What version of WinGdb are you using?
In version 3.50 you can use option 3 and 23 to remove flags.
Make sure the filter option box at the bottom is not checked.
Did you look at your coverted file on your unit to see if it actually had been shorted?
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Trailryder42 is offline   Reply With Quote
Old 06-10-2010, 12:01 PM   #18
the venturer
Oddometer: 1,421
3.55 beta version. It all seems fine on mapsource:
I can see many flags on the unit screen with shortened route.
It's been shortened. The real length of the route is around 30 miles but it shows 2 miles of it. The unit says so. I think it's better to upload it from the unit to the computer to check.
Old 06-19-2012, 07:10 AM   #19
krmn59
krmn59's Avatar
Oddometer: 4
Originally Posted by drewjb7 View Post
http://www.sackman.info/
Convert pretty much anything to pretty much anything else. I use it all the time. It's great.
Drew
Very nice! Easy to use. THANKS!!!!
08 KLR 650, Gold valves in front, Moab shock in rear.
krmn59 is offline   Reply With Quote
Old 09-11-2012, 07:16 AM   #20
katoomon
Rocket Surgeon
katoomon's Avatar
Oddometer: 68
Another Tool
Here is another great tool, DNRGPS
http://www.dnr.state.mn.us/mis/gis/DNRGPS/DNRGPS.html
If using a Garmin, use Save AS in Mapsource or Basecamp and save your Route or Track to a *.gpx format. Import that saved file to DNRGPS.
1. If it is a Track, click the Edit drop down and select Convert Table To in menu selection and Save out as a gpx.
1. If it is a Route, click the Edit drop down and select Convert Table To in menu selection and Save out as a gpx.
Depending on your GPS model, a track will be truncated to 50 points on routable maps if you select "follow road" so use the "off road" navigation choice if you get that message on your screen. You can also import/export this data in other formats; text, shapefile, mapinfo file, google earth, etc.
05 Tiger
04 KTM 625 SXC (with 2 wheelsets for mood swings)
katoomon screwed with this post 09-11-2012 at 07:35 AM Reason: update
katoomon is offline   Reply With Quote
Old 09-11-2012, 11:12 AM   #21
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,978
Or, you could just install BaseCamp and not have to deal with two or three other applications. Select Route, right click, Convert Route to Track. Done. Edit Track if necessary with Track Edit Tools.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 09-11-2012, 06:57 PM   #22
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,811
Have to say I'm real happy with the track to route, route to track conversion tool in BC.
Old 09-13-2012, 05:59 PM   #23
gunnr
optimsm
gunnr's Avatar
Oddometer: 290
Cheers,
That is good to know, I just loaded BC a week ago and haven't had the chance to play with it much. I have used Wingdb but this is a quicker process.
gunnr is offline   Reply With Quote
Times are GMT -7.   It's 07:26 AM.
