Old 12-05-2014, 04:04 AM   #1
ZCarFan2 OP
Oddometer: 116
FT500 Ascot engine noise
Wanted to see if anyone could tell me what's making a noise in the top end of my FT's engine. It only taps when cold and as it warms up the noise will stop and start again abruptly until it goes away entirely. Once it's hot, it goes away entirely until the next cold start. Listening with a stethoscope, the noise is loudest at the tach drive end of the cam. I bought it earlier this year and the noise was present then so no information available on when it started.
I've had the valve cover off. One rocker is slightly pitted. I have the shop manual and going by that, the cam chain "should" be good as the measurement at the top of the tensioner is toward the "new" end. I didn't see any obvious problems other than the rocker arm pad pitting, which is very minimal. I ran it for about 20 miles and drained the oil looking for metal debris (assuming it was the camchain) and it was perfectly clean. It has 26k miles.
In the video, it starts out quiet then the noise comes in a few times.
http://vid1050.photobucket.com/album...pstwfehuhr.mp4
ZCarFan2 is offline   Reply With Quote
Old 12-05-2014, 04:08 AM   #2
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,893
sounds like a valve. perhaps the compression release is faulty and contacting the exhaust rocker?
350R
plugeye is offline   Reply With Quote
Old 12-05-2014, 06:55 AM   #3
ZCarFan2 OP
Oddometer: 116
no compression release on the FT but could a sticking valve make that noise without affecting the idle?
Old 12-05-2014, 07:07 AM   #4
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,893
try disconnecting the tach cable
350R
Old 12-06-2014, 09:51 PM   #5
redprimo
Oddometer: 514
Have you tried cleaning the oil screen? You have to pull the left side cover to get to it. If there is a lot of crud on the screen it would restrict the oil flow to the top end when the oil is cold, then one the oil warms up more oil would flow through.
redprimo is offline   Reply With Quote
Old 12-09-2014, 06:42 PM   #6
ZCarFan2 OP
Oddometer: 116
I'll try the two ideas this weekend and see if it's one of them. If I don't find something soon, I'm going to pull the engine out for inspection. I'll need to deal with the pitted rocker eventually anyway before it wipes the cam.
Any chance that the cam chain auto-tensioner could be malfunctioning?
Old 01-31-2015, 07:36 AM   #7
ZCarFan2 OP
Oddometer: 116
Finally got back to the Ascot. I replaced the steering head bearings since they were so notchy the bike was nearly unrideable. After a short spin with the new bearings I can say it's a keeper. So light and easy to handle it's like riding a mountain bike. I just bought a CB500X and there is a lot of overlap between the two but I love the motor in the FT.
The top end made the noise again on cold startup this morning. I pulled the tach adapter out and it still made the noise. Drooled oil all over the place too!
I know the one rocker arm is starting to pit so I think at this time I'm just going to pull the motor out ad re-do the top end. It needs a bunch of threads repaired anyway as only half have been heli-coiled so far and that means the other half will fail. Hopefully I can re-use the stock cam as it looked ok without any scoring. Planning on at least hard-facing the rockers, new rings, gaskets and cam chain. The goal is for it to be ready for another 25k of service.
Anybody have a recommendation on a company to rework the rocker arms?
Old 01-31-2015, 11:35 AM   #8
Tim McKittrick
Oddometer: 1,763
I have had good results with Megacycle.
Tim McKittrick is offline   Reply With Quote
Times are GMT -7.   It's 01:28 PM.
