12-29-2006, 08:05 AM
#136 |
DL650AK7 - K75
Oddometer: 260
One cool thing about the Zumo is that if you're following a route and go through a tunnel, the display continues to update using your tunnel entry speed. If the road through the tunnel is twisty, the position indicator follows the route line on the map.
If the tunnel traffic stalls (like it can be counted on to do in Boston), the Zumo will finally throw up the "lost satellite reception" screen when your predicted egress fails to happen at the predicted time. |
01-02-2007, 12:05 PM
#137 |
I really don't care!
Oddometer: 116
FYI!! Hope this is not 205. I got an email back from Autocom UK. The Autocom Zumo cable part 1299 supports full stereo with mic on the current Autocoms, (Super Pro Avi, and the plus series) in the Aux 2 MP3 phone jack. The 1299 cable will also support mono with mic on the older Autocoms in the phone jack. They expect Top Gear, the Autocom USA importer to have the 1299 cable this month.
motoshane
Yellow '05 R1200GS |
01-02-2007, 07:32 PM
#138 | |
Jammer Jay
Oddometer: 2,054
Nothings possible, until its done! If ya can't afford the fine, take the lead. Pain is weakness leaving the body! If you haven't crashed, you're not riding to potential!.
01-02-2007, 08:44 PM
#139 |
Native Texan
Starcom1 has a cable in test
I received an email from Techstar the maker of Starcom1 that they have a cable in test for the Zumo and hopefully it will be available soon. Thank you Techstar and Laura Metcalf.
Yes Garmin just ignored the major users of their GPS's hoping that they could get the novice part of the market with the Zumo.
--Bo 2002 Titan Silver K1200 LT (ours) 2006 Yamaha Majesty (hers) 2005 Triumph Sprint ST (traded) 2007 (2006 Blue Panels) R1200GS http://www.twtex.com Don't Panic! Achtung! böse Eichhörnchen! |
01-02-2007, 10:29 PM
#140 | |
Nipple boy
Oddometer: 4,101
However.... .... this rumoured big firmware update at end of January needs to deliver most of the additional features discussed. One or two token gesture features could create quite a negative ground swell. BurnieM screwed with this post 01-02-2007 at 10:47 PM |
01-03-2007, 01:40 AM
#141 | |
The Gov
Oddometer: 34,124
01-03-2007, 01:57 AM
#142 | |
The Gov
Oddometer: 34,124
01-05-2007, 03:10 AM
#143 |
Oddometer: 116
FYI. I added a Ground Loop Isolator from Radio Shack to my mic cable from the Zumo to the autocom. I was having a hard time waiting for Autocoms new 1299 cable, which would be mono anyways on the older Autocoms. I eliminated the white wire in the autocom phone cable and added it to one side of the stereo ground loop isolator. I wired the the GLI to the red and ground wire of the autocom phone cable. Works well with the engine running in the garage. Still need to take it on a test ride, but I don't perceive having any problems. The audio is as good as it can be with bluetooth.
The GLI cost me $18 with tax at radio shack for the ground loop isolator. http://www.radioshack.com/search/ind...oop%20isolator Any audio ground loop isolator should work fine. Scosche, Boss, Stinger, and Bose make GLI's. Tons available on eBay. I used the Radio Shack model because it looked like it was the smallest and was convenient to buy. I have the mic-in of the Zumo going to the phone jack of my Autocom Active-7-Sport, and the audio out of the Zumo going to my Autocom stereo music jack. I usually run my vox completely turned off, so I have no loss of audio while talking on the phone. I don't run any GLI for the Zumo audio out. I hear very little if any engine noise as it is. However, if you are hearing engine noise, simply add the same GLI to the autocom audio cable, or run the Autocom isolated stereo cable. This should also work for all other intercom systems connected to the Zumo. This gives me full stereo for XM and MP3 and clean bluetooth phone communications on the older Active-7-Sport Autocom. The new Autocoms support full stereo and mic on Aux 2 with a 4 pole 2.5mm jack with the Autocom 1299 cable. I really didn't want to upgrade my autocom. Hope you all find this useful, motoshane
01-05-2007, 03:33 AM
#144 | |
The Gov
Oddometer: 34,124
01-05-2007, 03:46 AM
#145 | |
Oddometer: 116
motoshane
01-12-2007, 01:08 AM
#146 |
Oddometer: 8
Screen backlight timer: In previous Garmin units (76Cs) there was an option, that after a given time, the screen backlight switched off. There is no option in the Zumo. It is very useful, when you ride your bike in the dark and the unit only distracts you, when you reach a turn.
Satellite page: I'm missing the removed sattelite page too. Avoidance: On the road device without road/area avoidance? Why? Memory card: No SDHC capability. I am also having some problems with routes. I made plans in mapsource for a 2 week journey. 1 route for every day. Then I upload and import. It takes a lot of time. When it finnishes half of the routes are missing and there is a blank route in the list without a name and without any waypoints. If I delete the blank route and I start importing the left out routes one by one i can import all of the routes. But it is very time consuming and very frustrating. |
01-12-2007, 04:45 AM
#147 |
whats a cagiva
Oddometer: 2,454
I dont have the Zumo , still running an old IQ . I am E challanged severly , it seems to me most of the problums are in Garmins basic data base , So far I have only found 1 motorcycle shop in the database and Garmins location was 6 miles from the new location they moved to 5 years ago . in Utah I Brought up Points of intrest and saw a listing for 50 churches , WTF . Maybe if they started with information targeted to motorcycle riders instead of feeding us a bunch of crap that is of no use to us . not to mention the 25% error rate when you get to the high detail maps . SEYA
David H 00 Cagiva GC 04 9 fiddy 05 ST3 duck 07 KTM 450 EXC 86 Goldwing my geezer ride |
01-12-2007, 09:04 AM
#148 | |
Stop being a dick, dick.
Oddometer: 4,895
01-13-2007, 03:20 PM
#149 |
Nipple boy
Oddometer: 4,101
A few postings on the razorbiker zumo forum (http://razorbiker.com/zumo/index.php) with Garmin commenting in support emails about a new firmware release shortly. No substance on what it will contain tho.
My wish list/comments here; http://www.gpsriders.net/zumo_required_features.html |
01-20-2007, 06:53 AM
#150 | |
God Bless Texas
Oddometer: 1,470
Todd R. '78 R80/7 '06 FJR1300A "Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion |
