Old 02-21-2009, 06:18 AM   #61
rivercreep
Oddometer: 3,243
I stayed at a Holiday Inn last night...........
But I'm still too dense for all this to sink in!
Sure did appreciate all the hard work though!
YOU ROCK!
rivercreep is offline   Reply With Quote
Old 03-01-2009, 06:08 PM   #62
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,033
Luke, can you explain this further to me?
Ive got mine apart, cleaned up, and contemplating starting to wind the missing posts on the core it self.
It appears I can get 3 windings, of 5 posts each, not sure about the 120 degrees apart deal though, am I missing something else?
From Drop Box
Originally Posted by Luke
If you want to convert from two to three phase, you'll need a different stator core or flywheel. The number of phases is determined by the position of the magnets relative to the poles on the core.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake screwed with this post 03-01-2009 at 06:59 PM
mouthfulloflake is offline   Reply With Quote
Old 03-01-2009, 09:25 PM   #63
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
Hey, that's pretty neat. I sure didn't expect to see anything like that.
120* is describing the electrical signal, not the physical construction of the poles, exactly. If the flywheel had only one N and S magnet, then it would. If you have more than one N and S magnet, then divide 120* by the number of magnets to get the number of physical degrees separation of the stator winding poles.
So in this case, the poles are 20* apart, if the core is meant for three phases, there should be 6 N and 6 S poles on the flywheel magnets, so a piece of steel should stick to 12 places.
I'm a bit shaky on all that, so please try it and see if that's right before counting on it.
By all means, go ahead and try winding it. Get the same number of turns on each winding. It matters which way all the windings get connected together. There should be some sort of guide online to getting it right based on the direction of the windings. I remember seeing one but don't remember where it was.
Luke is offline   Reply With Quote
Old 03-01-2009, 09:28 PM   #64
mouthfulloflake
Not afraid
Oddometer: 17,033
right, thanks.
I plan to leave the stock in place, and wind the 2 others as closely as I can in guage and length.
then wire it in the delta config, likely externally, so I have options if one phase goes south on me.
Ill ask one of the engineers at work tommorow about this too.
Old 03-02-2009, 02:03 PM   #65
mouthfulloflake
Not afraid
Oddometer: 17,033
I will be trying to determine the configuration of the magnets in the flywheel this evening, using this device as loaned to me from one of my engineer co-workers.
Old 03-02-2009, 03:16 PM   #66
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Double checking to see if I got it right.
OK, so reading from the first page, I should be able to figure out the voltage output of my stock stator (at idle) by unplugging it and while running the engine at idle checking the voltage (i'm assuming DC) difference across the terminals with my meter?
I'd like to know what the stock output is since I haven't been able to find any info on it and the previous owner threw some extra lights on it but I'm not sure the stock stator puts out enough to keep the battery charged with them on.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 03-02-2009, 04:47 PM   #67
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,172
No, the stator voltage is designed for the load it is driving. For any 12V system, the unloaded stator voltage should be somewhere around 15-25VAC at idle. So unless the stator has been rewound or damaged you would expect to see about the same voltage regardless of the rated power output of the stator. Stator voltage is what you would check to figure out if the stator has the right number of coils on it.
You can calculate stator output with all the formulas I posted by measuring the voltage with different known loads attached, but if you just want to see if the stator is good enough for your application, it's overly complicated.
In your case, I'd just measure the battery directly. Set the voltmeter to VDC, and clip its leads directly to the battery terminals. Without starting the bike, turn the headlight on for 15 seconds or so. Turn it off, and note the battery voltage. Start the bike. If the battery voltage is a few tenths of a volt above the noted voltage, you know it is charging. If at or below, it is discharging.
Old 03-02-2009, 05:19 PM   #68
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,106
Originally Posted by Nomadmax
Good gawd ! Dude, if I knew half of what you know, my head would explode !
rickypanecatyl is offline   Reply With Quote
Old 03-02-2009, 10:06 PM   #69
mouthfulloflake
Not afraid
Oddometer: 17,033
12 magnet pulses inside my flywheel Luke.
and it appears that the are north/south ( repeating).
so it appears my idea of a pseudo 3 phase generator will work, ill start wiring it up in the next day or so.
Old 03-03-2009, 04:13 PM   #70
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Old 03-03-2009, 07:03 PM   #71
sgopher185
sgopher185's Avatar
Oddometer: 115
I definitely need to watch this as I have a dirt DR350 that I want to dual sport. I just got an S stator and regulator and was going to go this route, but I might try the rewind route instead. Take GOOD pictures
Current Ride:
2009 BMW F800GS (the Dewalt special)
1990 DR350
2004 TTR125 (son's bike)
Past Rides:
2004 950 S GO!!!! (Incredible bike that I really miss)
1995 VFR 750 (love the v-4 sound !)
1987 Hurricane 1000
1988 Hurricane 600
1985 VF500F
sgopher185 is offline   Reply With Quote
Old 03-05-2009, 09:36 AM   #72
mouthfulloflake
Not afraid
Oddometer: 17,033
I wrapped it last night, need to drip some resin on it, and poke the wires thru the grommet and test it out!
Old 11-15-2009, 10:21 AM   #73
Exile
The Mundane and The Magic
Exile's Avatar
Oddometer: 216
I have posted a write up based off of this thread and procycle's page on Thumpertalk, and once I can make sure I didn't make any mistakes I will post it on here as well.
http://www.thumpertalk.com/forum/sho...=846401&page=2
If anyone sees something I did wrong please let me know right away before I put it back together. Thanks.
06 Ducati 999 | 66 Ducati 250 | 03 Suzuki DR650 | 88 Honda NT650 Hawk
My Site
TAT 2010 | Rocky Mountain Loop 2014
DR650 Stator Rewire
Exile is offline   Reply With Quote
Old 11-15-2009, 03:52 PM   #74
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,916
Question
How do you wind a 3 phase stator in Delta configuration?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-15-2009, 04:21 PM   #75
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,465
I always thought you were better off to go with smaller diameter wire when making your stator windings. The other side that I didn't see mentioned in this thread is the strength of the magnets. If you could build a flywheel up that uses rare earth magnets or whatever the strongest magnets you can get in combination with a rewound stator then your should have optimal output.....at a loss of engine power of course.
Seth S
Seth S is offline   Reply With Quote
Times are GMT -7.   It's 07:13 AM.
