Old 12-26-2006, 11:09 AM   #16
wintonio
last of the Dum Dum Daze
wintonio's Avatar
Oddometer: 1,654
RapidDog: are you saying that one pair is a black/black , and the other is a green/red (with black tape over the red)?
wintonio is offline   Reply With Quote
Old 12-26-2006, 11:16 AM   #17
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,658
black and red
Originally Posted by Rapid Dog
...and what about these 2? one is red wire, other has 2 black wires, both spade type...
One female spade has a red wire and then other has 2 black wires entering the spade female
Rapid Dog is offline   Reply With Quote
Old 12-26-2006, 12:06 PM   #18
GSPD750
GSPD750's Avatar
Oddometer: 1,468
As BMWRich already mentioned I assumed they were for the optional clock when I had found them on my '93 gspd euro model awhile back. I determined the brown and the violet/blue went to the switched side of the ignition and was a perfect connection for my Dyna Charge Monitor.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 12-26-2006, 02:25 PM   #19
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 3,010
a plug came off on the side of my gs below the seat near the battery cover and it made the neutral light not come on any more.
camgregus is offline   Reply With Quote
Old 12-27-2006, 02:25 PM   #20
Perryhill
Perryhill's Avatar
Oddometer: 20
1991 R100GS
Found these plugs buried in my wire loom.
Any clue what they are for?
these have flat spade connectors inside...
Give me a hint where you found them, I want a switched wire to trigger a relay for some additional lights on my 93 GSPD
Perryhill is offline   Reply With Quote
Old 12-27-2006, 09:14 PM   #21
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,658
They are just under the front frame tube in the bundle...sitting idly I might add...
Old 12-28-2006, 07:54 AM   #22
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,041
If it's a solid red wire and it's on a German vehicle, it's a direct-to-battery connection, hot all the time.
Ignition-switched "hot" wires will be green + often a stripe.
Brown (earth) is a ground.
It's the Bosch standard.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 12-28-2006, 08:38 AM   #23
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,658
color fool
Well, take another look, I may be wrong about the color, I'm a little Red/Green blind...
Rapid Dog screwed with this post 12-03-2010 at 10:39 AM
Old 12-29-2006, 08:05 AM   #24
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,658
Laugh Doh!
Ha!
You dummies are as flakey as I am!
Those last two plugs (pic above) were for the coil/ignition!
I just figure that out last night when I installed my Dyna!!!
Old 01-21-2013, 02:05 PM   #25
wayne
Global MotoTourer
wayne's Avatar
Oddometer: 102
Just wanted to say thanks to everyone on this thread - this weekend I hooked up the Dyna Charge Monitor to the unused clock port on the R100GSPD wiring harness. Worked like a charm!
DYNA - R100GS
Black - Brown
Red - Grey/Blue
n/a - Red
Did it right with the soldering iron and rubber shrink tubing & heat gun. Looks & works great. Thanks for the idea guys.
Wayne
'92 BMW R100GSPD
Stamford, CT
wayne is offline   Reply With Quote
Times are GMT -7.   It's 05:39 PM.
