Old 12-30-2006, 12:07 PM   #1
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
newer airhead front wheel bearing removal
So I was all ready to do this yesterday. Got the wheel off and pulled off the brake rotor, etc.
The bearings are nothing i'm able to get ahold of. There's very little space between them and the spacer.
I thought I could simply use a drift to pound it out from one side, but even with the drift BENT at an angle I can't get a catch. It's a full 3" +/- from the hole opening to the beginning of the opposite inner race. Even if it caught, most likely it'd pop off the inner race and i'd still have the outer to deal with.
The autozone tools don't seem to have anything to do it and the local bike wrench (read: bike hacker) said "just press the whole thing out with a hammer, spacer and all".
Ed Korn's tool only does the tapered bearings and JTWIND tipped me off to this monster:
http://www.zelenda.com/Kukko/21.html
JT said "The dealer list is $71.00, it's $81.60 from Samstag Sales"
Since this will probably only need to be done hardly ever, I'm just gonna run by the dealer and take the wheel in and ask them to do it. If they use anything but the special tool, I'll let you guys know how it goes.
this won't happen until i'm over in Tampa next month for school, so if you guys get any genius ideas before then, let me know.
Happy new year!
datchew is offline   Reply With Quote
Old 12-30-2006, 12:09 PM   #2
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
here's the pics
Old 12-30-2006, 12:32 PM   #3
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Ideally you need a blind bearing puller. Don't think you can buy just one and a kit I'm sure would run over $150. So yeah, take it to the shop.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 12-30-2006, 12:55 PM   #4
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Well to top it all off, I went to put the brake rotor back on.
My manual is 45 miles away from me right now. So i figured "hey, just use the torque wrench on some low setting like 35 ft-lbs".
So I did. And I stripped one of the bolts. I'm so pissed right now I can hardly type. Shit.
Old 12-30-2006, 12:56 PM   #5
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Old 12-30-2006, 01:18 PM   #6
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Sell the GS....buy the Honda NOW!
Old 12-30-2006, 01:40 PM   #7
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
The only problem is that none of the jap bikes have any class. Or I would.
At least the carb balancing yesterday was a piece of cake. My mirrors now present a crystal clear image at any rpm.
Old 12-30-2006, 02:11 PM   #8
jdiaz
Oddometer: 32,182
?? Doesn't the bolt go all the way thru the wheel and have a nut on the other end? How did that strip out?
jdiaz is offline   Reply With Quote
Old 12-30-2006, 02:17 PM   #9
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
The correct torque is 24 ft-lbs. I hate when that shit happens.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 12-30-2006, 02:20 PM   #10
Renegade6
Renegade6's Avatar
Oddometer: 820
Take a look at the f650 site, may have a good way of removing the bearing using an expandable anchor.
http://faq.f650.com/FAQs/FrontWheelB...acementFAQ.htm
Brandon
1993 BMW R100GS
Renegade6 is offline   Reply With Quote
Old 12-30-2006, 02:37 PM   #11
Renegade6
Renegade6's Avatar
Oddometer: 820
Here's another idea:
http://www.boxerworks.com/phorum/rea...56756&t=156751
Brandon
1993 BMW R100GS
Old 12-30-2006, 02:39 PM   #12
Team Dennis
Certified Troublemaker
Team Dennis's Avatar
Oddometer: 4,539
Try here
Team Dennis is offline   Reply With Quote
Old 12-31-2006, 08:00 AM   #13
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
HA! I'm cooled off now. On one side is the normal nylon-lined nut and the other end of the bolt is a recessed allen head.
It was the threads of the bolt where they contact the nut that stripped.
I'm gonna replace it with an appropriate sized bolt from the hardware store until I can get another one.
No real harm done. At least I didn't crack the aluminum wheel hub or something. Just frustrating.
Old 01-05-2007, 02:24 PM   #14
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,550
not alone
dont fell bad, the same thing happned when I had my friends wheels powder coated.
ancient adventurer
bajaburro is offline   Reply With Quote
Old 01-05-2007, 04:05 PM   #15
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,759
Just so you know....
Every wheel bearing I've replaced has that inner tube, I have always used a drift and hammer,and I hate it every time, but it works, persistance is the key. However, if you end up buying a puller, you'll be everybodys friend!
And also, there is a Jap bike with class, its a Honda NT650, and I own one.
'twas ever thus
dfc is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
