Go Back   ADVrider > Riding > Regional Forums > Southeast, The Lair of the Dragon - The Blue Ridge and Smoky Mountains
Old 03-01-2012, 08:33 AM   #23221
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,356
Originally Posted by Farmer829 View Post
I have a little over 4600 miles on my KLR stock tire and have found a bald tire less than ideal for sandy/gravel-y??? roads. I got my next tire picked out but the local shop in Macon is charging $65 bucks to spend 5 minutes to change the tire! I don't quite trust myself yet and would most likely have to by a new rim if I did it myself. Is it simpler than it looks?
Everything you ever needed to know about tire changing.
http://www.advrider.com/forums/showthread.php?t=50717
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 03-01-2012, 08:42 AM   #23222
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,406
Originally Posted by ABuck99 View Post
Dan- Looks like FUN- Would Love to join you guys- Cant get away from the shop till after 3pm- so maybe another time. Have a good ride, and watch out for those cavernous ruts in south GA.
I'm planning on another run of this in the future with a more "aggressive" group and probably on a Sun-Mon as the couple guys I have in mind work Sat's also.
I'll keep you in mind when I organize that.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 03-01-2012, 08:54 AM   #23223
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,487
Ken's is Woodstock was attempted once:
Put my tire on backwards
Wouldn't set the tire pressure
Wouldn't wait 5 minutes past closing to fix my backwards tire
Oh and tried calling me a girl for asking for 36psi to start with until I got home
If you don't buy a tire from him, don't expect to be a human in his eyes.
All I see is rv storage and such at his pace instead of Motorcycles.
Don't be afraid to try it yourself. Happy to help if you were closer.
$65 is almost a 244 mounted...
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 03-01-2012, 09:23 AM   #23224
Dr.Z
6Sigma Knuckle Shflr
Dr.Z's Avatar
Oddometer: 10,445
Easy is an understatement when you check out this vid...
Stay half-assed, my friends. -- Mike West
He's got some of the basics down, but, in the end, that just has to create a bigger clusterfuck in that chinese fire drill of a cognitive thought he brought to the dog and pony show of his new found awareness. - Jack Goff
Dr.Z is offline   Reply With Quote
Old 03-01-2012, 09:29 AM   #23225
ABuck99
0.0
ABuck99's Avatar
Oddometer: 651
Id be up for that! Keep me posted-
Have a good ride
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-01-2012, 11:54 AM   #23226
Fireman1000
Fireman1000's Avatar
Oddometer: 2,720
If you take the tire off the bike, the local shop you speak of charges $19.50. Changing a tubed tire isn't that bad with proper tire tools. I believe you can get a set at Harbor Freight on Eisenhower Pkwy fairly cheap. You just have to be careful not to pinch the tube.
Fireman1000 is online now   Reply With Quote
Old 03-01-2012, 01:21 PM   #23227
Farmer829
Green horn
Oddometer: 55
Have a good ride
I'm 20 minutes from Butler. I'd love to connect with you all next time around!
Farmer829 is offline   Reply With Quote
Old 03-01-2012, 01:46 PM   #23228
BlueLghtning
Oddometer: 5,406
Yeah definitely!
Old 03-01-2012, 02:29 PM   #23229
Farmer829
Green horn
Oddometer: 55
Tires and Irons
Just bought a new tire and a set of irons and will have them here by Tuesday. Thank you all for the input and guidance. I don't care what all those other guys say about y'all. You seem alright to me.
Old 03-01-2012, 03:44 PM   #23230
drsmiley
drsmiley's Avatar
Oddometer: 277
You need to learn to do it at home first where it's easier and you can take your time, that way if you ever have a flat out on the road or trail you"ll know what to do.
drsmiley is offline   Reply With Quote
Old 03-01-2012, 03:51 PM   #23231
RichardU
Let's Ride
Oddometer: 903
The key is to realize what is happening with the bead on the opposite side of the tire. You need to "be the bead." If you're struggling, that means you're doing it wrong.
RichardU is offline   Reply With Quote
Old 03-01-2012, 04:37 PM   #23232
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,356
Breaking the bead can be the toughest part. If you are a home a big C clamp from Home Depot is the easiest thing to use. If you are on the road then a kickstand from another bike. There is a trick using two tire irons to break the bead that works as well but it is easier to show than explain.
Be sure and back up the rim with a block of wood if you are using a C clamp. I like to have a few wood wedges as well to keep the bead down in the deep part of the rim when installing the new tire. If you do not have a stand then put the new tire on the floor and use it as the stand and then use the old tire as the stand when installing the new tire. Tire lube works best but I have used everything from windex to WD-40 for lube. Just make sure to clean the brake when done.
Take note how all the spacers are located as you take everything apart. One thing to watch out for is the cush bushings fall out of the hub when you are flipping the tire over.
Old 03-01-2012, 05:17 PM   #23233
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Originally Posted by DirtDabber View Post
Breaking the bead can be..... bushings fall out of the hub when you are flipping the tire over.
Sounds like you really know what you're doing. Wanna come over and do a few demonstrations
F800GS Grin Machine
KTM690E Grrr Machine
XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA
www.hoofrehab.com
SlowRide13 is offline   Reply With Quote
Old 03-01-2012, 05:25 PM   #23234
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,356
School of hard knocks.......
I got a butt chewing when my boss found a cush drive in the tire changing barrel/trash can.....
Had to drive to Marietta to the customers work and reinstal the wheel. Yep, learned my lesson. Made sure the cush drives went to the bottom of the trash after that......
Old 03-01-2012, 05:35 PM   #23235
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Somehow I left a piece of broken "micro tire tool" inside a mountain bike tire one time... made it waaaay out in the boonies before it cut down the tube.
F800GS Grin Machine
www.hoofrehab.com
Times are GMT -7.   It's 06:08 PM.
