Old 01-08-2007, 02:07 AM   #16
Joerg
Joerg's Avatar
Oddometer: 1,356
Hi,
(and Happy New year, btw ;-)
Originally Posted by datchew
I guess i'm torn on that method. You not only keep the metal bits out, you keep the fresh fluid out also.
The issue of "sealed" vs "non-sealed" is a long story ... but first, don't forget that that even the so-called "sealed" bearings do not offer a hermetic closure; it's more a plastic lip that covers the bearings' sides. One technical reason is probably that the "closed" bearings were supposed to keep their oil over a longer time, however the old /7 gearboxes reportedly did not use this "mix" of bearings.
Can you give more info on the shim stack thickness?
Here you are, including a spreadsheet to calculate what you need: http://homepage.sunrise.ch/mysunrise...box.htm#adjust ... the whole process is difficult to visualize from a description, but once you are presented with an open gearbox it all becomes sooo obvious
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 01-08-2007, 06:28 AM   #17
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
You're the man Joerg. Either i'm blind or you've updated your site, or you have stuff hiding from me.
I missed that on your site somehow. Thanks.
datchew is offline   Reply With Quote
Old 01-08-2007, 07:42 AM   #18
Joerg
Joerg's Avatar
Oddometer: 1,356
Last update of the gearbox page was 2006-11-26, which could mean that a visit to the optician might be due
- Joerg
Old 01-08-2007, 07:44 AM   #19
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Could you just start typing in a larger font?
The average age of the bmw owner is like 50-something right? he he he.
Old 01-08-2007, 08:40 AM   #20
Middleweightboxer
Middleweightboxer
Middleweightboxer's Avatar
Oddometer: 680
The link to the web site is great. That is the way it is done.
We have a local mechanic that will assist home rebuilders with measuring and getting the shims correct for a small donation.
I believe Ed Korn sells some clay that can be placed between the bearings and the cover. You bake the transmission to cure clay then remove the cover and measure the cured clay to establish the existing clearances. If you don't have a measuring plate available this is a fall back procedure. Here is Ed's listing:
MOLD-A-GAUGE
Non stick, non shrink, heat cured material, used to measure the end play of the input, intermediate, and output shafts on the /2 /5 /6 /7 R26 R27 and probably other BMW transmissions. Has to be heated to 275F (135C) for 25 minutes (oven). You will need a caliper (preferably dial) to measure the thickness of the cured MOLD-A GAUGE. Replaces Matra numbers 504 5061 and BMW 23 3 650. Enough for at least 4 transmissions......$7 (0.1 lb)
This is a good method for the home rebuilder. Good luck.
Bill
Tiger 800XC, R1, FZ1, RD400, CB400F
R80ST, R90S, Monster S2R, Penton 125 JPS, T25T
Middleweightboxer is offline   Reply With Quote
Old 01-08-2007, 11:05 AM   #21
Suppermotodd OP
Tag Thief
Suppermotodd's Avatar
Oddometer: 1,023
Double Sealed Bearing
I removed the new 6304 non sealed bearing and replaced it with a new sealed bearing. The later paralever gearboxes came this way from the factory so I am going to keep it that way. The expert at the bearing supply place said it is normal to see sealed bearing next to the shaft seal. This helps control fluid from leaking around the output seal.
Man I'm broke as a stick! NoPC-Lance
http://www.motocompound.com
Suppermotodd is offline   Reply With Quote
Old 01-08-2007, 11:13 AM   #22
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
That's an interesting thing to say. Maybe he thinks you're dealing with a tranny with a pump in it. these are splash type lube unless I really missed something.
hey, the blue sure looks purty!
Old 01-08-2007, 03:29 PM   #23
Mr_Wilson
Oddometer: 122
I changed the sealed (and failed) output shaft bearing on my GS to an open type on my recent rebuild. Had 72,000 miles on the clock.
Mr_Wilson is offline   Reply With Quote
Old 01-08-2007, 04:01 PM   #24
GSPD750
GSPD750's Avatar
Oddometer: 1,454
Just curious, but who makes the bearing (blue seal) you just installed?
Is it Japanese?
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 01-08-2007, 06:34 PM   #25
GSPD750
GSPD750's Avatar
Oddometer: 1,454
Is it Japanese?
Reason I'm asking is because a local car tranny shop where I was sourcing
my bearings tried to sell me a Chinese bearing (6304) which was sealed and if I remember correctly it had blue seals as in your pic. Found out later it was for an electrical motor installation and I later returned it. A Chinese bearing in my GS gearbox is sub-standard IMO. I ended up buying Fag and Koyo.
Old 01-09-2007, 06:37 AM   #26
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,962
Where's the pics, Todd? When I talked to you last night, you were cooking a Transmission! How did it come out?
Boojum!
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is online now   Reply With Quote
Old 01-17-2007, 01:12 PM   #27
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Thumb Pics
It is done and here are the pics.
Replaced the roller with a k bike stainless steel one.
Mold a Gage then bake or SMOKE at 275.
Taste Like Chicken!
Measure and shim it up.
Install in PD.
Suppermotodd screwed with this post 01-17-2007 at 01:17 PM
Old 01-17-2007, 02:32 PM   #28
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Awesome. Great pics. Did you use one of the Ed Korn videos or did you just do this from the book?
Old 01-17-2007, 03:14 PM   #29
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Thumb Video
I got the Ed Corn video. It is most informative...
Old 01-18-2007, 07:14 AM   #30
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
i love that you found a way to work your smoker into a transmission repair. i just hope your next bird doesn't taste like transmission.
bmwblake is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
