Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 03-04-2008, 04:08 PM   #16
BigX
n00b - Yeah, right
BigX's Avatar
Oddometer: 609
Originally Posted by pixellman
SanDisk extreme III 4 GB working perfect on my zumo 550
+1
BigX is offline   Reply With Quote
Old 03-04-2008, 04:49 PM   #17
ok.computer
Oddometer: 1
SanDisk 8 GIG SDHC working fine with mine.
ok.computer is offline   Reply With Quote
Old 04-01-2008, 03:57 PM   #18
Punditbywords
n00b apprentice
Punditbywords's Avatar
Oddometer: 1
16GB SD card works
Out of curiosity, I bought a 16GB SD card and slapped it in my Zumo 550. At first the unit would not read the card. I reduced the number of songs on the card to below 1,000 and it works just fine.
Note: I had to power down the Zumo and then turn it back on before it would recognized the SD card.
Final note: Garmin states that the Zumo has a 1,000 song Playlist limit. I originally thought that I could have multiple Playlists on a single SD card -- with no more than 1,000 songs in each Playlist. In fact, what Garmin should have said is that the Zumo has a 1,000 song Library limit.
NB: Based on what I've found, I'd have to agree with JSTCRASHNTHRU -- there's not much reason to get an SD card bigger than 8 GB because, even at the highest bit rates, 1,000 songs is only going to need ~ 6-8GB.
Punditbywords is offline   Reply With Quote
Old 04-03-2008, 08:45 AM   #19
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,030
Originally Posted by PotatoHead
I'm using an 8GB card also, with no problems...
+1
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 04-04-2008, 06:04 AM   #20
ECM
ECM's Avatar
Oddometer: 161
Very true, unless you also want to add some additional maps (500 models) and/or topo maps, together with your juke box.
(Taking 2 cards with you works just fine as well ;-)
ECM is offline   Reply With Quote
Old 02-27-2013, 10:52 AM   #21
ixab
just Aaron, really
ixab's Avatar
Oddometer: 376
file count
Man, am I an archeologist or what?
Thought I'd throw this in, since this is nearly the first result of you Google the Zumo 550 SD capacity. If you're on a Mac, or have Cygwin on your Windows computers, you can easily count the number of songs you have on an SD card using terminal
- Open Terminal.app
- Put your SD card into your computer
- Type this: 'ls -l /Volumes
- look at the output and find the name you've given your SD card
- Type "find /Volumes/YOUR_SD_CARD_NAME_HERE/music/ -name "*.mp3" | wc -l"
The output will be the count of mp3 files in the 'music' directory of the SD card.
Example from my 4GB SD card has 3.6GB of songs on it, mostly 128hz bitrate, the typical bitrate for ripped or purchased songs). Doing "find /Volumes/5504GB2/music/ -name "*.mp3" | wc -l" will output "648". Given that, I think an 8mb is about the max if you're interest is just having room for music. If you're keeping your stash of Jayme Langford photos on your Zumo , just keep in mind you'll max out the 1000 song limit somewhere around 6-7GB.
For windows it would be something like 'dir /a-d /s /b music | find /c ":" from the command line (once you had used 'cd' to get to the right directory on the SD card). For you Windows users without command line experience, I think using the UI you can get the properties of a folder, and it shows a recursive file count there.
Youtube - Death, Death, Everywhere!
ixab is offline   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
