Old 01-10-2007, 01:45 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,483
R100gs Fork Oil/maintenance ???
Going to refresh my fork oil.
Couple of questions. The manual sez to :
Question #1
"...bleed shock absorbers by compressing and releasing 5-10 times until full damping is felt...."
Does this mean to just bounce the front end after it's all buttoned up?
Question #2
From one of the links I found it sez R100GSPD uses
410cc on the Left leg and 440cc on the right.
Is this correct?
Question #3
I haven't been able to find any 7.5w oil locally, only 5,7,or, 10.
Who makes it? I see that Belray makes a 7.5w, but I thoght there may be a special sooperGSguy oil...
your opinions are golden brothers
Rapid Dog screwed with this post 12-03-2010 at 10:39 AM
Rapid Dog is offline   Reply With Quote
Old 01-10-2007, 01:46 PM   #2
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,483
cc's
ceecee's
Old 01-10-2007, 01:53 PM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,491
I do know that the r100g s takes different levels in each fork leg. Someone can confirm if those are the correct volumes. When I can't find 7.5 weight I buy 5 and 10 and mix them in equal amounts. JT
jtwind is offline   Reply With Quote
Old 01-10-2007, 02:07 PM   #4
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,900
I'm running 15 wt, and am a svelt 175lbs.... 7.5 wt sucked IMHO...
Then I got some Racer Tech "gold valves"
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 01-10-2007, 02:11 PM   #5
Joerg
Joerg's Avatar
Oddometer: 1,356
Question #1 - Yes.
Question #2 - Yes. The reason ist that both fork parts have different functions (compression damping is entirely controlled by the left fork, while rebound damping is controlled by the right fork), and if you do a "standard" oil change not all of it comes out.
Question #3 - As JT said, mix it. The fork oil recommended by BMW, for the GS fork in its original state, is "Esso Komfort", which is SAE 10W. You can also use different viscosities in the two compartments; recommendations are generally SAE 7.5 (or 7.5W-15) for the left and SAE 10 (or 10W-20) for the right fork.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 01-10-2007, 02:59 PM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I"m glad you asked this question R-Dog.
Cause i'm planning this soon as well. If you replace your fork gaters, don't pay 40-something bucks apiece. Go here:
http://www.advrider.com/forums/showp...8&postcount=22
Or go neoprene like the dirt bike people.
BMW dealers will carry the 7.5 weight, but a thread I read long ago (and made notes from) but don't have marked said the best combination is as follows:
L/H fork 410cc 20W
R/H fork 440cc 15W
Local squid bike shops carry multiple weight fork oils for me but 3/3 bmw dealers i called only carry 7.5w bmw brand fork oil.
Jorge had something on his website about doing this as I recall. he used a ratchet strap or something to compress the forks all the way.
Please do post if you encounter anything mysterious cause I'll need to know. Also, please tell if you end up needing some special tool like this fork drain tool in the upper left of this page:
http://www.culayer.com/Joes_tools.htm
Cause i have access to a welder and will just make one.
Thx.
datchew is offline   Reply With Quote
Old 01-10-2007, 03:18 PM   #7
Renegade6
Renegade6's Avatar
Oddometer: 820
I just replaced seals, oil and installed a race tech cartridge in mine a short time ago. In addition, if you are anywhere above 200 pounds go with more than 7.5 weight. For the fork caps, I just used a socket that I ground the chamfered edge off of on the top.
Brandon
1993 BMW R100GS
Renegade6 is offline   Reply With Quote
Old 01-10-2007, 03:30 PM   #8
Renegade6
Renegade6's Avatar
Oddometer: 820
I forgot to add that when I did mine the compression and rebound sides were backwards. Also, make sure you take good notes if you take them completely apart...
Brandon
1993 BMW R100GS
Old 01-10-2007, 03:46 PM   #9
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,483
all good
I'll just be changing fluids to start.
back in the day, we use to sit ato[ the tank to compress the forks while filling them...I assume this isn't nceessary.
Guess I'll just go 10wt on both sides from consensus since I'm 170 bars-ass-nekkid...
Old 01-11-2007, 06:06 AM   #10
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I'm bout 175 after a big sandwich so lemme know how it feels. Haven't bought the fork oil yet.
Old 01-11-2007, 07:33 AM   #11
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
what are the lightweights running for oil? this is on my list to do shortly.
i'm about 150 geared up and soaking wet.
bmwblake is offline   Reply With Quote
Old 01-11-2007, 07:14 PM   #12
cpatstone
N00b, obviously.
cpatstone's Avatar
Oddometer: 347
this is still about fork oil, right?
Just have to chime in. I used 10-wt, and it's fine for me.
Of course, I'm about 380 lbs with my wife on my shoulders, my dog in my arms, the dog needs to pee and so do I, the wind is blowing from the southwest, and the scale reads 2 lbs when nothing's on it.
'88 BumbleBeemer
"Minds Awaken on roads less Taken" -- Magic Hat bottle cap inscription
cpatstone is offline   Reply With Quote
Old 01-26-2007, 01:22 PM   #13
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,483
fork gaters
...anyone know the fork gaters size? I think I'll go neoprene if I can find some at Cycle Gear or wherever...
Old 02-25-2007, 11:20 AM   #14
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,483
Question dive
So, I did the 7.5 mix in both sides...don't know what it had before.
It seems to have more dive on braking now.
Maybe I should bump up the viscosity on the compression side (left)?...or both sides?
Your thoughts...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Old 02-25-2007, 12:04 PM   #15
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
Your thoughts...
I use 15wt on the compression side and 10wt on the rebound. It works OK for me.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
