Old 01-14-2007, 07:42 AM   #1
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
Clean the oil jet for clutch lubrication.
How's everybody? I see in the 2006 950 Adventure Owner's Manual,... under Periodic Maintenance Scheadule, beside engine checks "Clean the oil jet for clutch lubrication." Does anyone have a Factory Maintenance Manual pictures of this process? I have seen the recall thread on oil jets, but as I understand reading that recall,... those jets are specific to the engine itself (ie: rotating assembly lubrication). Any help here would be much appreciated.
KTRMN8R is offline   Reply With Quote
Old 01-14-2007, 12:39 PM   #2
K2m
....58....
K2m's Avatar
Oddometer: 2,238
That will be the oil jet above the clutch slave- chain guard. A tiny little jet. mine was blocked. After unscrewing use a vacuum to remove it.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 01-14-2007, 12:42 PM   #3
scottr
scottr's Avatar
Location: Pedernales R., Tx Hill Country (Ihadthisavatar1st)
Oddometer: 1,768
scottr is offline   Reply With Quote
Old 01-14-2007, 01:49 PM   #4
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,675
Thats the first I have heard about this!! How often should one do this?
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
Originally Posted by Beefeater Steve View Post
✧The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
KTMSER is offline   Reply With Quote
Old 01-14-2007, 02:05 PM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,200
The oil return jet.
You should be refering to part No 600.38.029.000. In order to pull it out though you could use a screwstarter for flat screws, or the vac cleaner as mentioned above!! I wonder if increasing the hole to a 0,5mm would be a good idea? More oil and less prone to blocking.
There is always a reason!!
Old 01-14-2007, 03:40 PM   #6
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
So, if I am understanding this correctly; you are saying,... an Oil Jet in KTM language is refering to the bleeder screw on top of the clutch slave cylinder??? If so,... mine has a small grey protective "rubber booty" on it and it is clean inside. For some reason I was thinking that this"oil jet was internal, as it follows the clutch lining inspection and clutch pressure booster system checks on the '06 model PMS?
Old 01-14-2007, 03:43 PM   #7
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
According to the '06 Owners manual, under PMS on page 20, 1st service after 1,000km and every 15,000km or every two years.
Old 01-14-2007, 04:17 PM   #8
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
Hey Gefr, how goes it? any pics of said part?
Old 01-14-2007, 04:22 PM   #9
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
Old 01-14-2007, 04:26 PM   #10
figurehead
Bring It On
figurehead's Avatar
Oddometer: 34
The oil jet IS internal and you have to take off the slave cylinder to get to it (as well as removing the chain/case guard).
The part number given above is correct and it is shown on the “engine case” page in the engine parts manual as #29.
'09 KX450F
XR "100" dirt tracker
figurehead is offline   Reply With Quote
Old 01-14-2007, 04:50 PM   #11
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,101
Here's a photo of the clutch oil jet location from a TB (Fig. 2). This is different from the engine oil jets refered to in an '05 TB, if that isn't apparent to anyone.
-cp
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 01-14-2007, 05:37 PM   #12
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,675
Dam I am calling my dealer in the morning they did not do that at the first service or the second when I had it in for the valve check. I sat and watched both times.........sonsabitches~~~ I do see that it is in the owners manual on pg 29 for the 07 950SE. I overlooked that damit!!!! After looking at the maintenance schedule they only performed 4 out of 16 things that it says to check at the first maintenance. I'll do my homework next time and take a list with me!!!
Thanks for bringing this to my attention KTRMN8R
Old 01-14-2007, 06:24 PM   #13
Motobee
Oddometer: 73
I did my own 600 mile service on my bike. Checked the oil jet and it was blocked with a little piece of gasket sealant. I guess that there is a good reason for them to have you check it.
Motobee is offline   Reply With Quote
Old 01-14-2007, 06:53 PM   #14
KTRMN8R OP
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
Figurehead, CP,... you fuckers rock !!!!!!!!!!!!!!!!!!!!!!!
Thanx Mucho, gotta go clean my shiznitt!
L8r
Old 01-14-2007, 08:39 PM   #15
scottr
scottr's Avatar
Oddometer: 1,768
I thought about starting a poll but don't really want that high a profile on this subject. I wonder how many 950 owners really trust their dealer? Do they trust their dealer's mechanics? Do they have faith that that critical part they can't see once the machine is buttoned up ... was checked or fixed or replaced? Do you believe that the mechanic working on your bike actually knows how to measure a valve shim and raise or lower your buckets a few thousandths of an inch?
Times are GMT -7.   It's 05:18 PM.
