Old 06-28-2013, 11:51 AM   #271
rehto
Oddometer: 7
I just bought 2007(EUR) Adventure and was going to clean this jet but I'm missing one. Internet tells me that my gearbox should be really clunky and oil pressure low but I can find neutral rather easily when idling and my oil pressure light has never come on during drive. Also, I can stop my rear wheel with my shoe as I run it on stand, 1st gear, clutch engaged.
Has anyone come across any mod or reason why previous owner would have removed the jet altogether?
I'm worried about my oil pressure and will install #60 jet as soon as I receive one but it puzzles me why this machine seems to work just normally without the jet.
rehto is offline   Reply With Quote
Old 06-28-2013, 12:11 PM   #272
Fundy Rider
Where 2?
Oddometer: 245
If you are finding Neutral easy enough I would think that your jet has no blockage.
Once these bikes have gone through some oil changes and the jet has been cleaned there is no where near the debris to clog your jet like it may have just coming from the factory.
Is it possible that you don't realize there is a cap screw you have to remove first to be able to access the jet.
I really can't see anyone wanting to remove this jet as it does aid in cooling your clutch.
Fill your soul everyday
Fundy Rider is offline   Reply With Quote
Old 06-28-2013, 02:21 PM   #273
NKL
Oddometer: 189
The jet has to be there, people have problems with a 0.7mm jet, you would be open to a whole new world of issues with no jet just a massive hole.
NKL is offline   Reply With Quote
Old 06-29-2013, 06:33 AM   #274
rehto
Oddometer: 7
Trust me guys, it's not there. I checked the hole with a mirror and I can see threads for the bolt, inlet hole for the oil, taper and second smaller thread for the jet. I can stick a rod to the hole and it goes deeper than possible if there would be a jet installed.
So please, just give me any ideas why would someone remove this jet and why my engine/gearbox still works. I must say that getting the neutral from 1st is tricky (also when in move) but I get neutral consistently from 2nd. I guess this is somewhat normal with this bike.
Additional clarification: I do have the allen bolt to seal the hole and also there is oil in the whole so it is not completely blocked, just the jet is missing.
rehto screwed with this post 06-29-2013 at 06:39 AM
Old 07-13-2013, 12:24 AM   #275
felixblack1
felixblack1's Avatar
Oddometer: 195
I made a mess of my clutch jet. i was careful but it doesn't want to budge. So I tried cleaning it while it's still in there but no luck there either. I've put a few drops of carb cleaner down there and I still can't seem to unclog with a 10 guitar string. I've read all the clutch jet threads but I've run out of ideas. Any tips to help me out??
felixblack1 is offline   Reply With Quote
Old 07-13-2013, 05:05 AM   #276
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,025
Perhaps get a jewlers drill bit and drill out the blockage. It is going to be a bugger of a job !!
It is so important to use a screw driver that fits very snug into the slot. If you need to get the jet first, file a driver to fit snug, then remove the offender.
rossguzzi is offline   Reply With Quote
Old 07-13-2013, 03:03 PM   #277
felixblack1
Oddometer: 195
Thanks Rossguzzi, those jewellers dril bit look like the right tool for the job but I'm reluctant drill it as if it snaps off I'm f'd. Ill see how i go making up a suitable driver as you suggest. Yeh clearly from the photo I used too short width a bit. That wasn't so clear at the beginning being in such a PITA spot
Mind you gear changes, finding neutral is superb. Well compared to the dr
Old 07-13-2013, 03:12 PM   #278
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,300
I use one of these (obviously not the phillips version) with the appropriate box wrench to apply the torque:
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is online now   Reply With Quote
Old 07-13-2013, 07:29 PM   #279
felixblack1
Oddometer: 195
Thanks Cpt. Ron
Got the f'cker out
Red 6mm on left which did the damage, proper 8mm bit on the right slotted into jet
BTW as others have found the top is solid brass no hole. On the bottom of jet you can see hole.
felixblack1 screwed with this post 07-13-2013 at 07:34 PM
Old 07-13-2013, 07:48 PM   #280
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,300
Thanks Cpt. Ron
Got the f'cker out
Cpt. Ron
Old 07-26-2014, 04:16 PM   #281
PunkRockMonkey
Captain Underpants
PunkRockMonkey's Avatar
Oddometer: 4
Thanks for the help!
Hey,
Long time lurker, first time poster here. I was desperately trying to find the solution to my clutch pushrod seal leak and was referred to this thread by the superduke forum.
With all of the tips in this thread, I was able to successfully remove the oiler jet for the pushrod (using the flathead screwdriver bit/q-tip approach) and cleaned the jet out with a spot of guitar string and some brake cleaner. Next thing I know, there's no more oil leak behind my slave cylinder! (At least for now.)
From the look of how tiny that hole is, I'm probably going to invest in a bit larger jet, because that thing is so miniscule, it has to be practically useless!
Thanks again!
Now, it's time to ride!
PunkRockMonkey screwed with this post 07-26-2014 at 05:15 PM
PunkRockMonkey is offline   Reply With Quote
Old 07-26-2014, 06:46 PM   #282
DirtJack
DirtJack's Avatar
Oddometer: 1,597
Originally Posted by PunkRockMonkey View Post
Hey,
Attachment 322883
Thanks again!
The hole actually looks big to me. What size jet is that. If you go too large, you'll have trouble finding neutral when stopped.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-26-2014, 07:46 PM   #283
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,432
More oil = more drag. It's supposed to be miniscule. Ask Boatman about his early '04 with no hole in that jet...works perfect, has for years, he rides the crap out of it.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 07-26-2014, 10:09 PM   #284
PunkRockMonkey
Captain Underpants
Oddometer: 4
It's the stock jet from the bike, as far as I know. I didn't look until you mentioned it, but in the crappy pics I have, I spotted a "3" on the top of the jet, so is it safe to assume it's the .3 ?
Either way, the bike shifts normally now and I just re-checked the clutch slave to see if there was any seepage (which it usually does after I park it) and there's no oil to be found.
Happy monkey.
Old 07-26-2014, 10:36 PM   #285
Guano11
Am I Trending?
Guano11's Avatar
Oddometer: 1,400
Hey, Long time lurker, first time poster here.
Thanks again!
"Velcome aboart" -- and thanks for posting up. You've resurrected an informative thread of which I was unaware.
Guano11
Time flies like an arrow.
Fruit flies like a banana.
Guano11 is offline   Reply With Quote
Times are GMT -7.   It's 07:49 AM.
