Old 01-14-2007, 09:54 PM   #16
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,098
Originally Posted by scottr
I thought about starting a poll but don't really want that high a profile on this subject. I wonder how many 950 owners really trust their dealer? Do they trust their dealer's mechanics? Do they have faith that that critical part they can't see once the machine is buttoned up ... was checked or fixed or replaced? Do you believe that the mechanic working on your bike actually knows how to measure a valve shim and raise or lower your buckets a few thousandths of an inch?
My mech knows how ... It's me
My dealer is an arrogant knucklehead
-cp
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 01-14-2007, 11:52 PM   #17
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,126
Your list would be interesting to share
Originally Posted by KTMSER
I'll do my homework next time and take a list with me!!!
MN8R
When you prepare it.
There is always a reason!!
Old 01-15-2007, 05:27 AM   #18
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by gefr
You should be refering to part No 600.38.029.000. In order to pull it out though you could use a screwstarter for flat screws, or the vac cleaner as mentioned above!! I wonder if increasing the hole to a 0,5mm would be a good idea? More oil and less prone to blocking.
No. Never do this...... You will not be able to get it in to neutral with the engine running !!!!!!!
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 01-15-2007, 06:21 AM   #19
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,458
Nothing could be truer unless you do it yourself, which, I can't.
If you delaer lets you watch, then thats a different story perhaps, if they dont, you'll never know what they did or didnt do except charge you.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is online now   Reply With Quote
Old 01-15-2007, 07:47 AM   #20
Pyndon
Pyndon's Avatar
Oddometer: 2,233
Question is.......do you trust yours
Pyn
2013 Dakar swag available here, your support is hugely appreciated: http://www.lyndonposkittracing.com/support-lyndon/support-packages/
Please visit my web-site / blog www.lyndonposkittracing.com
You can also look me up on Facebook or Twitter.
Pyndon is offline   Reply With Quote
Old 01-15-2007, 11:14 AM   #21
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,126
I am actually running it with the 0.5mm hole.
Neutral is O.K. The problem on mine has never been too much oil. I guess there was too litle oil until the TSB was carried out and so the damage was already done. Anyway after my clutch steel (?) disks and lining disks have been replaced, under warranty, together with the clutch booster, everything works as never before.
Old 01-15-2007, 12:43 PM   #22
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,098
I forget gefr. Was your's one of the early one's with a plug instead of a jet?
-cp
-cp
Old 01-15-2007, 12:58 PM   #23
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I drilled mine to about 1.5 mm Not a good idea
Old 01-15-2007, 01:55 PM   #24
Pyndon
Pyndon's Avatar
Oddometer: 2,233
You should'nt be owning up to things like that!!
Pyn
Old 01-15-2007, 02:40 PM   #25
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,126
It is an early model, Dec '03 with the pleague!
-cp
That's right cpmodem.
K2m
You 've gone too far IMHO. Do you still have problems? How is your clutch nowadays? Have you installed the OEM reduction jet?
gefr screwed with this post 01-15-2007 at 03:29 PM
Old 01-16-2007, 05:50 AM   #26
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I have done worse...... The most stupid thing I have done was not to check that the foam I modeled my side tanks with would, when the time came, DISOLVE! Of course I panicked. One friend suggested setting fire to the foam So I cut the back off and dug it out Still that is all behind me now.
Old 01-16-2007, 05:54 AM   #27
K2m
....58....
K2m's Avatar
Oddometer: 2,238
K2m
Two days later I had a new jet .5mm you say That would stop it from blocking
Old 01-16-2007, 03:13 PM   #28
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,126
I don't know man!
I just think it is good to keep my clutch well lubricated without affecting too much the oil pressure in the circuit. So I let it be at 0.5mm.
Old 01-19-2007, 05:32 PM   #29
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,668
Question
If I pull the clutch slave cyl off to get to the clutch oil jet will it loose fluid? Will I need to refill & bleed? Thanks in advance!!!!
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
Originally Posted by Beefeater Steve View Post
✧The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
KTMSER is offline   Reply With Quote
Old 01-19-2007, 06:08 PM   #30
tkorpi
Oddometer: 130
Nope.
The clutch slave cylinder is a sealed unit. You shouldn't lose any fluid and you shouldn't need to bleed it.
2006 KTM 950SM
tkorpi is offline   Reply With Quote
Times are GMT -7.   It's 11:18 PM.
