Old 01-19-2007, 06:08 PM   #31
Bartman
SnowDog
Bartman's Avatar
Oddometer: 153
Originally Posted by KTMSER
If I pull the clutch slave cyl off to get to the clutch oil jet will it loose fluid? Will I need to refill & bleed? Thanks in advance!!!!
Nope. Its a sealed system.
Bartman is offline   Reply With Quote
Old 01-19-2007, 06:44 PM   #32
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,758
Originally Posted by tkorpi
The clutch slave cylinder is a sealed unit. You shouldn't lose any fluid and you shouldn't need to bleed it.
THANK YOU !!!!!!
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 01-20-2007, 07:50 AM   #33
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,216
what does this oil jet do? What happens when it's clogged?
thanks
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-20-2007, 08:01 AM   #34
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,069
Lubricates the clutch disks.
The wet clutch needs to have the disks lubricated in order to cool them. If the clutch is starved from oil the disks will overheat. Side effects are distortion of the metal disks,which can afect the operation of the clutch. The disks have friction with the clutch lever pressed, developing dragging and difficult gear changes (god forbid).
gefr screwed with this post 02-08-2009 at 08:45 AM
Old 01-20-2007, 08:03 AM   #35
Critic
More or less!
Critic's Avatar
Oddometer: 1,292
KTM tech - 2 cents
Just read through this thread, interesting. So, I went to KTM service site for a look around and found this on service training, Orange Level. US wise, finding a dealer with said training, would, could, should give confidence to those dealers service.
http://www.ktmusa.com/Detail.223.20....ash=c7235c1a39
It is always something! Rosann Rosanadana!
Moto's: 300xcw,500exc,990Baja
Moto's past-BigBear250,T100cs,Savage250s,TS185,DT175,GT550,TY250,XR200/350/250,R75/7,Ft500,RD350,YZ125,KDX175,SP500,K1000rs,DR250,883,S1,ST2,KLX650,KE100,GS1000,Monster,Vstr om1000&650,950adv,625sxc,250SSherpa,530exc,990adv, 690e
Critic is offline   Reply With Quote
Old 01-20-2007, 12:47 PM   #36
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,758
Originally Posted by gefr
I just think it is good to keep my clutch well lubricated without affecting too much the oil pressure in the circuit. So I let it be at 0.5mm.
Is this the size the stock jet is 0.5mm? or did you drill to this size? I removed mine today. Before removing said jet I could see something shiny blocking it a small piece of metal debris. Getting it out of the hole with a shop vac reduced to a 3/8 hose it pulled right out. That is sure a small hole in the jet it wont take much to plug it. The question is to drill or not to drill any ideas?
Old 01-20-2007, 02:01 PM   #37
K2m
....58....
K2m's Avatar
Oddometer: 2,238
1 mm will be to big. Jets are cheep and available
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 01-20-2007, 02:43 PM   #38
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,069
The OEM is 0.30mm. I drilled it to 0.50mm.
In my country jets are not available at the specific size. And the OEM are too expensive for what they are. I think 0.50mm is not going to harm the oil pressure cirquit (lowering overall oil pressure). I 've drilled it trying to fix the dragging clutch problem. So I let it be!
gefr screwed with this post 01-20-2007 at 10:22 PM
Old 01-25-2007, 05:58 PM   #39
tkorpi
Oddometer: 130
How tight is this jet supposed to be?
I just slapped a 16t on my 950 SM and figured I'd clean out that oil jet by the clutch. How tight is it supposed to be? I gave it a bit of force and it didn't budge and I didn't want to go overboard. Is there a secret to this thing?
2006 KTM 950SM
tkorpi is offline   Reply With Quote
Old 01-26-2007, 08:48 AM   #40
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,069
It is a slotted screw, made of bronze...
with a deep cut. Good luck.
gefr screwed with this post 02-08-2009 at 08:46 AM
Old 01-26-2007, 11:25 PM   #41
tkorpi
Oddometer: 130
Bobby ping extractor
I finally worked up enough nerve to give it a nice, strong twist with the screwdriver. It came out, but I was pretty surprised by how tight it was . Anyway, instead of a shop vac, I used a bobby pin to extract it. I cut off the curved tips of a large bobby pin and bent the 'legs' outward. I basically made reverse action tweezers. Worked like a charm!
2006 KTM 950SM
Old 01-27-2007, 10:41 AM   #42
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
This is what I use to remove/replace (after broken loose) this type of jet:
-cp
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 01-27-2007, 04:53 PM   #43
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,069
Could we see some photos?
I used cpmodem's method with the screwstarter, but the problem is it dents the middle of the screwslot! Can we have a photo of the bobby pin method please? Thnx!
Old 01-27-2007, 06:31 PM   #44
tkorpi
Oddometer: 130
Sure!
I used another bolt for simulation purposes.
2006 KTM 950SM
Old 01-27-2007, 10:00 PM   #45
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Brilliant!
-cp
Times are GMT -7.   It's 05:33 AM.
