Old 01-15-2007, 07:03 AM   #1
Lil Earle OP
Sweatin, not scared
Lil Earle's Avatar
Oddometer: 95
Parts cleaner
What is the best stuff to clean parts with. I have found either it doesn't do nothing or is so caustic it eats up aluminum or paint. I have posted this here because you can't own an old bike and ride it unless you work on it.
Thanks in advance
One more repossession and I'll be out of debt.
Lil Earle is offline   Reply With Quote
Old 01-15-2007, 07:22 AM   #2
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,450
There's been few threads on this here so do a search. On my airheads some parts that easily remove, I've had bead blasted. Not perfect but looks pretty good. When it's a part that doesn't come off easily, I've used a citrus cleaner that I've bought in bicycle shops and green scotchbrite pads. I sometimes have to go over it a number of of times but it works and does start to bring back the very unigue original look of airhead aluminum castings. JT
jtwind screwed with this post 01-15-2007 at 09:45 AM
jtwind is offline   Reply With Quote
Old 01-15-2007, 08:58 AM   #3
comes naturally
renewed hope
comes naturally's Avatar
Oddometer: 1,893
The whole bike?? Simple green cut a little more that 2 to1. Greasy parts? I like mineral spirits.
comes naturally is offline   Reply With Quote
Old 01-15-2007, 09:25 AM   #4
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 12,890
Depends what you are cleaning. Castrol makes a good degreaser/cleaner, and Simple Green is good stuff and reasonably priced.
Remodeling. Please check again later.
Mista Vern is offline   Reply With Quote
Old 01-15-2007, 10:03 AM   #5
kz1
kz1's Avatar
Oddometer: 780
Simichrome
I like Simichrome or Mothers with 000 steelwool.
kz1 is offline   Reply With Quote
Old 01-15-2007, 10:17 AM   #6
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,787
Don't forget to use the car wash if the bike drives, be careful to keep the spray away from stickers though.
GreaseMonkey is online now   Reply With Quote
Times are GMT -7.   It's 12:37 AM.
