Old 01-15-2007, 09:17 AM   #1
Suppermotodd OP
Tag Thief
Suppermotodd's Avatar
Oddometer: 1,023
Bluhduh PD Speedo Woes
My roof leaked on my leaky speedp and now it's FUBAR!
What's A man to do?
It was half full of rusty water when I took the first ride on it the other night. The odometer works but the needle is sticking and not fuctional.
Anybody ever fixed one of these before.
Man I'm broke as a stick! NoPC-Lance
http://www.motocompound.com
Suppermotodd is offline   Reply With Quote
Old 01-15-2007, 10:28 AM   #2
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,954
Could it have Rusted that "MUCH" from just a roof leak? Looks like it has had some water in it sometime before. Maybe it was that plunge that watered down your tranny fluid?...........Ya Think?
Until we can FIX that *#@!^ing Roof, better break out a camping tarp! If you need one, I have one,....maybe two.
Boojum!
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly"
BMW's: 1999 GS 1100 "Work Horse", 1975 R90/6 "Black Betty", 92 R100 GSPD,
03 XR 650L with Farkles, KLR 250, 72 Honda CL-70
Boojum is offline   Reply With Quote
Old 01-15-2007, 11:10 AM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,291
Try googling up a speedo shop in your neck of the woods. I learned my lesson a long time ago on this one, too many specialised issues involved.
If you just want to get going, put a bike speedo somewhere while you send it off to get fixed.
GreaseMonkey is offline   Reply With Quote
Old 01-15-2007, 12:32 PM   #4
nowhereman
I'm lost -don't follow me
nowhereman's Avatar
Oddometer: 386
Speedo shop
I had these guys fix the bouncing needle in my R100gs motometer speedo. Cost 100, done in one day.
http://www.paspeedo.com/
1990 R100GSPD
1964 LI125S with a 240 MRB kit
nowhereman is offline   Reply With Quote
Old 01-15-2007, 12:52 PM   #5
Straypuss
Oddometer: 69
Try this
I did one a month ago. water seems to run down the trip reset and puddle in the bottom of the case. There is a goretex type breather but it must take forever for the water to evaporate. It looks worse than it is. I used maintenance spray, electrical cleaner and cotton buds to remove the rust. If you remove the three screws holding the head to the cable drive and loosen and rotate the odo drive. You may find that this is the sticky part and a clean and relube works.
Further investigation requires needle removal..hardest bit is getting up the courage..then take out dial screws and it all comes apart easily.
To get the needle off I used a small tack remover with a bit of card to protect the dial. The dismantled resting place of the needle lined up with the line on the outer face of the dial below the needle rest. I also drilled a small hole at the lowest point, when fitted, on the case so that any future ingress will drain quickly. I cannibalised an r45/65 speedo as the glass and odo wheels in mine had been damaged.
Good luck
http://img48.imageshack.us/my.php?image=speedo2pa7.jpg
Straypuss is offline   Reply With Quote
Old 01-16-2007, 11:58 AM   #6
MoMan
PigPen
MoMan's Avatar
Oddometer: 666
http://www.speedometerservice.com/
located in Roswell, GA
Try this shop. They do good work and fixed one of my speedo's.
Hamp Smith, the shop manager is one of our customers.
It could be that the purpose of your life is only to serve as a warning to others.
MoMan is offline   Reply With Quote
Old 01-17-2007, 02:20 PM   #7
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Thumb Thanks!
Thanks for all the input guys! I am going to try and clean it up myself and if that doesn't work off to the speedo shop!
Old 01-17-2007, 02:34 PM   #8
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,488
Good luck at fixing and cleaning yourself. I've always been scared of digging into one of these things. If you need to have it done I just got a /5 speedo/tach restored by North Hollywood Speedometer. It came back last week, beautiful work and it only took 2 weeks. JT
jtwind is offline   Reply With Quote
Old 01-17-2007, 02:45 PM   #9
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Talking I'm A Cheap Bastage
If I were not so poor from Air Head Sickness it would be off to the speedo shop. But I have spent all my money on Parts Parts and More parts. But it will all be worth it in the end!
Old 01-17-2007, 02:59 PM   #10
Troutrider
Vicarious Adventurer
Troutrider's Avatar
Oddometer: 1,152
Hey Todd, I stopped in the Honda shop today by the Compound. They had the Endurance computer for $79.00. $77.00 in the Aerostich catalog. It's got 18 functions. It might do for a while.
Troutrider
'03 DR....Take the gravel road less traveled
'09 KLR Yet another KLR...
'75 MG 850/1k-T "The way the Vee was meant to be"
"Ride like you want to get up and do it again tomorrow"
Troutrider is offline   Reply With Quote
Old 01-17-2007, 03:31 PM   #11
WooPig
Oh Glory!
WooPig's Avatar
Oddometer: 545
another cheap bastage
Not sure it means much, but I've been through two of those Endurance 'puters on my off-road bikes. They went sorta haywire after a while. Admittedly, they got a little rougher treatment than I'd expect on the GS.
I bet someone who can conquer a transmission would do fine with a speedo. Damnthing wasn't all that accurate to begin with, was it?
WooPig is offline   Reply With Quote
Old 01-22-2007, 07:33 AM   #12
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Talking It works
I cleaned and reassembled the Speedo using the products bellow and it works fine now. Getting the rust particles out of the magnetic input bell was the hardest part. I used the wd 40 to remove the water and contact cleaner and compressed air for the rest. The spray polish was used to remove the rust stains from the face plate.
The gasket was shot so i used clear silicone to blue the face back on,
Old 01-22-2007, 08:53 AM   #13
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
if you don't wanna mess with the rubber nipple on the odometer reset, you can simply unscrew the plastic button. Then you can just cover the hole in the glass with black electrical tape and peel it back and reset it with your key each time.
datchew is offline   Reply With Quote
Old 01-22-2007, 09:00 AM   #14
Suppermotodd OP
Tag Thief
Oddometer: 1,023
Thumb Reset Button
Great Idea! I did not know the button would unscrew...
Old 01-22-2007, 12:46 PM   #15
elmoreman
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,767
I look forward to the resurfacing of this thread when your speedo breaks in another few months , and there is nothing any of us can do about it!
Seriously, I'm gonna measure that threaded thing tonight and draw up some plan for a support to take the stress of the nylon. Of course...as soon as I get that sorted out, the speedo will break again, or the needle will bounce, or more water will collect inside, or the speedo will fog up, etc...etc...
airhead aficionado
elmoreman is offline   Reply With Quote
Times are GMT -7.   It's 12:03 AM.
