10-03-2010, 01:02 PM
#3031 |
Grizzly herder
Oddometer: 1,043
Yesterday & Today's rides
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv |
#3032 | |
Target Fixated
Oddometer: 3,871
10-03-2010, 05:31 PM
#3033 |
Badger tickler
Oddometer: 672
Fall in Wisconsin.
'12 F800GS '00 Bandit 1200 '74 Honda CL360 |
10-03-2010, 05:58 PM
#3034 | |
Ted Simon Acolyte
Oddometer: 208
10-03-2010, 09:22 PM
#3035 |
Oddometer: 273
Front wheel was built by Woodys Wheels Works; Denver, CO, and is an 18" Excel, with a 120/90-18 Dunlop D606.
The 18" front wheel on the KLR is a highly-debated item, particularly on the KLR forums...part of the idea is that the wider footprint allows for a bit more flotation in sand/other soft terrain, as the front of the KLR is steamroller-type heavy. In retrospect, I would probably not put a D606 on the front, but that's hindsight now. The D606's howl terrible on the highway.....Woody's laced up this wheel to the stock KLR hub. No extra vibration, etc., takes a bit more effort to turn on asphalt. Aluminum trunk was purchased from Twisted Throttle, trunk is built by TraX. It's a nice unit, although the locking latches will fail to keep all but the most honest theif out- they can easily be pried apart with a smal screwdriver. A bit disappointing considering the cost. Ultimate set-up requires a new center section for the OEM luggage rack, with a quick-release adapter post which allows the trunk to be installed/removed with just one key. Shot from the rear........
ALL ROADS LEAD TO ZEN MOTO |
10-03-2010, 09:27 PM
#3036 | |
Oddometer: 16
Thanks for the info.
10-04-2010, 10:41 AM
#3037 | |
Oddometer: 569
10-04-2010, 12:50 PM
#3038 |
Enjoying the Journey
Oddometer: 654
Currently on the road
Rocky Mountain National Park
Bonneville Salt Flats Hollister Hills Motocross Track ![]() Yosemite ![]() A mile from the US-Mexico border at Tecate
Motorcycle Mexico DVD - The easy way to prepare for your first motorcycle ride south of the border. New Hampshire to Ushuaia 2009-2010 |
10-04-2010, 06:14 PM
#3039 | |
Badger tickler
Oddometer: 672
Kermit Road in Monroe County.
10-05-2010, 02:11 PM
#3040 |
Oddometer: 42
Today was a beautiful day and I was driving myself crazy being inside, so I just had to get out and enjoy it before all the leaves are gone. I passed a couple cars that were pulled over taking pics; it's weird feeling like a tourist in your own town... Also got to test a new windshield from JC Whitney (eh, it works). On my first attempt, I had to turn back with a leaking carb, which was magically fixed by me taking it apart, not seeing anything wrong, and putting it back together. :shrug:
Anyways, here's some pics, they're from a road aptly named Covered Rd, which I have another picture of in the other thread. ![]() ![]() I took the snowmobile trail home, which had far fewer tourists and lots more sand, rocks, and mud. :yay:
10-06-2010, 04:21 PM
#3041 |
Oddometer: 155
gorgeous fall pictures!
Jon Kohler Colbert, GA 2012 VStrom 650 Adventure IBA# 24562 |
10-07-2010, 07:46 PM
#3042 |
MonkeyButt
Oddometer: 1,756
My KLR likes to lie down and rest every once in a while......
![]() I like my KLR!
Youth is wasted on the young! "Pulling on that bike with all I have, I fear that I will pop a vein in my anus any second." by metaljockey 105 FYCYFF (ForkYouCancerYouForkingFork) Ride On Preston Drew Haun June 17, 1981- August 15, 2010 #1 To achieve anything in this game you must be prepared to dabble in the boundary of disaster. (Sterling Moss) |
10-07-2010, 08:42 PM
#3043 |
Pata de Perro
Oddometer: 1,210
MEXICO
![]() does anyone knows about the improvementes ont the 2011 VS 2008-10 (would still oil thirsty?) arte |
10-07-2010, 08:53 PM
#3044 |
Oddometer: 539
Forever West KLR
Big Sheep Creek Road Idaho
![]() California Trail Marker in the Big Empty Wyoming
'12 Yamaha Super Ténéré (Blue) '08 WR250R I refuse to tiptoe through life only to arrive safely at death THE DEAN OF WESTERN ADVENTURE ROUTES Backcountry Byways Journal |
10-08-2010, 01:22 PM
#3045 | |
Geared up and ready.
Oddometer: 512
"Liquid-cooled, 651cc, DOHC, 4-valve, single cylinder engine features a super broad torque curve for the widely varied uses of a dual sport motorcycle. Double engine balancers keep the engine running smoothly from idle to redline for best rider comfort and less fatigue on long rides. Ratchet-type, automatic camchain tensioner keeps cam timing “spot-on”. Free breathing, 4-valve cylinder head boosts low end torque and provides maximum valve area for optimum flow at highway speeds. Revised cam timing contributes to improved high-rpm performance. New intake porting offers greater low-end torque. New piston rings are thinner and have more tension, resulting in a significant reduction in oil consumption. New, fully transistorized CD Ignition unit replaces the earlier analogue CDI for better ignition performance. New, higher output alternator (14.5 17.0 Amps) meets the electrical accessory needs of touring riders. New regulator offers improved performance. New, one-piece exhaust pipe features smoother bends for improved exhaust efficiency at all rpm. U.S. Forest Service approved spark arrester helps prevent wildfires and allows access to designated public riding areas and. 40mm semi-flat slide Keihin CVK Carburetor precisely meters fuel for good economy and quick throttle response. The addition of a secondary air system helps reduce harmful exhaust emissions. New Denso radiator is thin and lightweight. Fitted with a lightweight and thin cooling fan, the new radiator has a greater cooling area and offers a 20% increase in cooling efficiency. (10% due to more densely packed cores; 10% due to the larger area.) The more even running temperatures achieved with liquid cooling ensures long engine life and no “power fade” on hot days. Smooth-shifting 5-speed transmission has a gear for every situation, from low-speed trails to highway touring use. The transmission features Kawasaki’s exclusive positive neutral finder that makes selecting neutral at stoplights a breeze. At a stop, just lift up on the shifter from first gear and the transmission stops at neutral – every time." So maybe... Do you run it above 4500+ rmp for long periods of time? Mine tends to drink more if I'm above 5k rpm.
Damn I wish all roads were dirt. Current ride : 2011 White F800GS, 9500 km's Past ride : 2006 KLR with 41,000 kms -gone to a good home- Toronto to Maine and back Toronto to Boston -The Long way |
