02-25-2011, 09:13 AM
#2356 | |
Oddometer: 1,592
1) how did you get a hold of the pipe? was it off a wreck or did you order it new? 2) how did you rotate it? Did you cut it, then re-weld it?
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service |
02-25-2011, 07:22 PM
#2357 |
Oddometer: 533
Shock Spring Options
Turns out options for improved rear spring on a 1990 XT600e in the US are pretty light. I took extensive measurements of the stock shock and made lots of inquiries on ways to improve it, but I am not entirely satisfied with what I found.
RaceTech will sell me a 550 lb/in spring for $120, but say I need a $30 collar. And a new bottom-out bumper would be $46! Works Performance says I can get a 550 lb/in spring for $130. Sadly, neither would take much time to work with me and really figure out the best solution. Works talked down to me (in spite of the fact that I am a Mechanical Engineer and know Mass-Spring-Damper systems pretty damn well) and RaceTech took forever responding to me. I guess I could buy a Hagon shock for $400, but since the bike originally cost $800, I think I will just put the shock back on and live with it until I can afford something with better parts availability in the US. One final note, the spring can easily be replaced. Going any further would be a real PITA for a do-it-yourselfer and it would be better to simply replace the whole shock. |
02-25-2011, 08:09 PM
#2358 | |
Oddometer: 190
Spring
Have you inquired of a local spring builder? We had one in the town I used to live in. It could be a viable option. I don't really have a problem with comp or rebound. Just my big butt plus gear is almost too much for the stocker. I'd drop 90-100 buck for a stiffer spring. After you tested it of course
You seem to be suffering from the 1st world problem of having too much time on your hands. - viverrid |
02-25-2011, 08:54 PM
#2359 |
I smell premix
Oddometer: 1,487
mint 94 xt600e w/hardbags just up on ebay -LA, california
Not mine and not sure if its aok to post link, like new 94 xt600 on ebay now, is sweet. Only 3,569 miles.
02-26-2011, 12:27 AM
#2360 |
Oddometer: 2,129
02-26-2011, 03:23 AM
#2361 |
Oddometer: 691
Late to the party, NEW 87 XT600 owner......
JUSt picked up an 87 model XT600 for a cool $850 up here in Alaska. Where the picking isn't quite as plentiful for decent used bikes as in the lower 48. It is in pretty decent shape, with an original shop manual, and reciepts from when ity was new!! It's got quite a bunch of new parts installed by the last owner; signals, mirrors, fork rebuild, brakes, tires, chain & sprokets, rear fender flap, welded frame for ammo can panniers, and probably more.
WHAT IT NEEDS: A new clutch and decompression cables and possibly a valve adjustment. But overall a decent, still street legal and currently registered fun bike for my 15 mile commute to work. My place of work is on a gravel road so NO MORE worring about dust and dirt getting all over my 92 Fatboy!! AND the ability to explore more of ALASKA on 2 wheels...........I won't be able to pick it up for a few days yet but here is the add on craigslist. Pics to follow. http://anchorage.craigslist.org/mcy/2228784778.html Alaskajeff screwed with this post 02-26-2011 at 05:45 AM |
02-26-2011, 11:42 AM
#2362 |
b00b
Oddometer: 88
RB,
Do you have any updates on your project? Did you get the rims replaced? I had a set of 17" sumo style Excel rims laced, after blasting and painting the stock hubs of course. My local race shop spec'd and ordered the installation from Buchanan's who live around about Los Angeles. Because of their relationship with Buch they were able to ship the hubs and rims down, along with return shipping for about US $20, round trip via Golden State Overnight. That may not be an option from IL but it's worth a check. The total bill was under $300 and included the "thick" stainless spokes and nipples (36 ea x 2 rims), drilling the rims for correct angle, then lacing, centering, and tightening. I was surprised at how good the alignment was considering they weren't working on their own personal gear. The end product uses minimal lead for balancing from the tire guys. Hope that helps. Justin |
02-26-2011, 11:56 AM
#2363 |
b00b
Oddometer: 88
Not sure how many miles are on your front forks but they might be due for new fork oil. Mine came out looking like espresso and was likely contaminated with moisture due to outside storage. I also went with a heavier weight and new springs. The "dive" issue never went away completely for me but with new springs and fork oil it is good enough. As far as emulators, I asked a Racetek rep at the IMS show in California about the XT. He said they install a generic kit that works on any conventional 41mm oil-dampening fork. I plan to approach them before hitting the track again. ADD: By the way, what make rotor did you go with? Justin |
02-26-2011, 01:35 PM
#2364 |
Oddometer: 2,129
02-26-2011, 02:48 PM
#2365 |
Adventure Rider
Oddometer: 2
Hi guys,
I'm new here, just to subscribe to this thread, i ride XT600 2kf from 1988. Curently working on XT600 1988=2012 look project... Regards. |
02-26-2011, 03:24 PM
#2366 |
Oddometer: 691
02-26-2011, 03:45 PM
#2367 | |
Oddometer: 152
Yoshi Pipe
Found on ebay with an interstate dealer clearing inventory. Sticker price $1098. My price....$202. Totally stoked. Was new in original packaging w instructions and all the hardware. I had to cut the front mount off the midpipe which is near where the midpipe joins the header. I then removed the springs that hold the midpipe to the muffler and simply rotated the midpipe to fit. The springs no longer line up but the bracket to frame prevent any movement. I have since replaced the ugly al frame mount bracket with a P clamp (hardly visible). ![]() Hope this helps and good luck By the way, Great thread guys. Lots of good knowledge here. |
02-26-2011, 03:51 PM
#2368 |
Oddometer: 152
Another Tip - Chain Guard
Mine was missing the chain guard. Found a DT200 (water cooled 2 stroke) chain guard. $10... ebay... fits perfect.
02-26-2011, 08:05 PM
#2369 |
Oddometer: 691
Parts interchangability between years?
What year parts will fit my newly aquired 87 XT600? I need a clutch and decompression/start cable. There are a few on EVILbay but not sure what will fit? Also there is a nice new seat cover for a TT600, will it fit my seat pan? Thanks.
02-27-2011, 10:31 PM
#2370 | |
Oddometer: 152
How about a pic? |
