Old 03-04-2011, 07:56 AM   #2371
ccbilgin
Oddometer: 13
Crank bearing change XT 600
I disassembly my piston engine my crank bearing is 2 X KOYO 6307 HS (High Speed) . But I couldnt find same bearring in market. FAG 6307 C3 or FAG 6307 is suitable for me. C3 mean more space in bearring but rpm is higher than other. Which one do i choose?
Thanks in advance
ccbilgin is offline   Reply With Quote
Old 03-04-2011, 08:52 AM   #2372
patrick2wd
pop-pop-pop-pop-etc.
patrick2wd's Avatar
Oddometer: 162
cam's
does anyone has experience with (some type of) camshafts, not standard one's but stage 1, 2, 3?
dynochart, good bad experience.. runs beter, goes faster (slower) more/ less torque.. etc etc..
there is little or no information about this, in Holland there is a discussion which one should be used..
and for what Ive heard, hotcams should be avoided,,, (?)
anyway..
who could help with info,
Thanks,
Patrick
www.fastsailing.nl
patrick2wd is offline   Reply With Quote
Old 03-04-2011, 04:22 PM   #2373
Mezo
Oddometer: 2,129
dynochart, good bad experience.. runs beter, goes faster (slower) more/ less torque.. etc etc.who could help with info,
For that type of info Patrick Google "XT600 motard camshaft" its mainly them guys who trick there motors, Adventure riders tend to want reliability from there bikes.
Here`s an example of a TT600 motard using a XT600 frame (google translate) what a weapon.
Mezo.
Mezo is offline   Reply With Quote
Old 03-04-2011, 06:39 PM   #2374
DustyJohn
DustyJohn's Avatar
Oddometer: 63
Originally Posted by Mezo View Post
There is some talk on XT600.de about this, here.
Mezo.
Anyone know the dimensions of this piece so I can make one??
DustyJohn is offline   Reply With Quote
Old 03-05-2011, 05:40 AM   #2375
TheRadBaron
Oddometer: 474
Thanks in advance
My understanding is that most of the bearings found in Japanese motorcycle engines are C3 clearance. For a while I was considering going to a bearing supplier for replacement engine/tranny bearings, but I decided to go with Yamaha parts. It's more expensive, but that way I know that what I have is correct.
If I was to use a commercial bearing, my semi-educated opinion would be to use the C3.
The desire for safety stands against every great and noble enterprise. -Tacitus
TheRadBaron is offline   Reply With Quote
Old 03-05-2011, 06:50 AM   #2376
doxbike
Oddometer: 282
Originally Posted by bendiebandielegs View Post
There is a box between the carb and the motor on the XT 600E. Mine has a crack and is sucking in air which kills the engen. I need ideas as to how the best way to fix it?
I have tried silicone, but it dosent agree with the heat off the engen.
Rescue tape-used it to repair radiator hose on my dodge ram. Forgot to buy a new hose. Still there when I traded it in 5 years later.
http://www.rescuetape.com/?gclid=COi...FQE2gwodCAz8Bg
Home Depot has a knock off
doxbike is offline   Reply With Quote
Old 03-05-2011, 07:21 AM   #2377
snowjob
snowjob's Avatar
Oddometer: 602
Frame reinforcement for aftermarket exhaust.
I don't recommend going to this trouble. I made a completely straight link and it worked fine. Just measure the distance and use tubing. I then squished the tubing flat on the ends, ground it to remove the corners and drilled the holes. Can post a pic if you want to see, but it is essentially just a straight bar, not sure why they have a bent one.
snowjob is offline   Reply With Quote
Old 03-05-2011, 08:43 AM   #2378
pondman
Vortex Traveler
pondman's Avatar
Oddometer: 15
Sure Rosco there yours!
All Paid job's absorb & degrade the mind: Do what you love...well
pondman is offline   Reply With Quote
Old 03-05-2011, 08:43 AM   #2379
pondman
Vortex Traveler
pondman's Avatar
Oddometer: 15
Originally Posted by RoscoOz View Post
I'm interested in the emblems & will email you
Rosco
you gottem there yours
Old 03-05-2011, 10:06 AM   #2380
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
here's a pic of the one I got with my SuperTrapp IDS2 on my 1995 XT600E (well it's a 1990 frame now so......)
just a straight pc of tubing same size as the frame with reinforced attachment pads.
bike is in SC right now so no actual measurements available
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 03-05-2011, 10:09 AM   #2381
xtphreak
xtphreak's Avatar
Oddometer: 7,963
Robert A. Heinlen
1999 Tiger 885
1995 XT600E
Old 03-05-2011, 10:58 AM   #2382
threadbare
threadbare's Avatar
Oddometer: 32
27 cm.centre to centre. mine is same as xtphreak
Don't Believe Everything You Think.
threadbare is offline   Reply With Quote
Old 03-05-2011, 03:39 PM   #2383
DustyJohn
DustyJohn's Avatar
Oddometer: 63
Thanks Snow Dave, XTPhreak and Dirty Adam for your help
Old 03-05-2011, 08:53 PM   #2384
pondman
Vortex Traveler
pondman's Avatar
Oddometer: 15
Originally Posted by yamalama View Post
I upgraded my wheels (to aluminum; Excel). Ordered the spokes/rims through Buchanan. Went to an 18 on the back.
No redrilling, etc. They have worked out perfectly.
Please share the details, wheel widths and spoke gauges, did Buchanan lace then up for you? Please share
I'll follow in suit... Thx lama
Old 03-06-2011, 08:19 AM   #2385
patrick2wd
patrick2wd's Avatar
Oddometer: 162
does anybody has an idea how to get the old stickers of the tank & fairing? and where to get new stickers, Ive seen a page, somewhere with models for a sticker company to cut new one's... but cant remember where..
thanks...
www.fastsailing.nl
Times are GMT -7.   It's 08:00 AM.
