08-08-2008, 09:17 AM
#256 |
Oddometer: 494
Ive got Pirelli Scorpions on mine that ive been pretty happy with. theyre lasting really well and have decent traction for when i want to go offroad.
Ill have to get back to you on the sizes.
2000 Suzuki TLR; 2012 Yamaha Super Tenere, 2005 XT660R 1993 TDM850; 1977 Kawi KE175 |
08-09-2008, 02:40 AM
#257 | |
motomaniac
Oddometer: 1,351
Peace Claudio
Everything happens for a reason! |
08-09-2008, 09:35 AM
#258 |
Iowhat?
Oddometer: 478
Tires
I'm running the Mefo Explorers on my 90 XT. Got them from http://www.klr650.com/MEFO%20Sport%20Trail.html , 90/90-21 I think on the front and 130/80-17 on the rear. So far I've got about 2k on the back and still wearing nicely. Some people are reporting up to 7k out of a set. They are much more street friendly than my previous MT21's and are wearing much better. Still hold up decent in the gravel & made it up a muddy, rocky b-level road a few weeks ago.
--JOsh
1990 Yamaha XT600E - Old Faithful 1983 Yamaha CV80 Riva/Beluga Scooter - Scooter Trash |
08-12-2008, 08:03 PM
#259 |
Oddometer: 14
'86 xt600 light problems
Hey guys-- hope someone can shed some light here-- no pun.
I was riding my '86 xt600 when I came around a corner and there was a car. I switched my brights off and ALL my lights quit working(headlights brake lights turn signals ect). I checked the fuse over the battery-- not tripped. Headlight appears blown, but the elect. schematics seem to indicate this wouldn't cause all the lights to go out. Any ideas-- Thanks
08-12-2008, 09:05 PM
#260 |
Ride more, BS less!
Oddometer: 8,452
Okay... while you are all pondering the answer to XT Thumpers question maybe you can answer mine also. I need to mount some rally lighting on my '88,,, how much power do I have to play with??? I was thinking of replacing the stock H4 bulb with an HID and then a pair of PIAA's at 75w each. Yea or POOF???
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
08-13-2008, 11:15 PM
#261 | |
Oddometer: 380
1992 Yamaha TDM 850 1980 Honda CX500 1977 Honda Goldwing GL 1000 |
08-14-2008, 09:28 AM
#262 | |
from B4 "adventure bikes"
Oddometer: 7,658
do you have a DMM or VOM? comfortable with using it? start checking at the fuse, does it look ok or did you check to see either voltage on the side away from the battery or 0 ohms across the fuse (out of the holder)? I'd try voltage first, it'll show you what's cruddy/high resistance/open. if you don't have one, try Harbor Freight, they have a small digital meter on sale for $2.99 this week (includes battery and has a back light and leads) #90899 ... well in the flyer I got it was, looks like it's $4.99 online ![]() looking at the schematic, the headlights, high beam indicator bulb and the speedo backlight are fed from the same circuit (Brown wire out of main switch) as the starter relay / solenoid / igniter on the E models. The tail light / brake light / flashers are fed off another circuit (Blue wire out of main switch). the power source is common until the ignition switch, I'd suspect a problem in that section if as you said, the flashers, tail / brake light lost power with the headlights. but be sure of your initial "facts". Is the headlight truely "blown"? pull the plug and see if there's voltage at the plug stabs. pull the bulb and measure the resistance across all 3 contacts, there should be 2 combinations with continuity, one without. need more help ... post or PM me
Do one thing every day that scares you. Baz Luhrmann Women and cats will do as they please, and men and dogs should relax and get used to the idea. Robert A. Heinlen Adventure is discomfort recounted at leisure. Flash / GSWayne Chrome don't get ya home. Rob Nye Stamp Out Hoplophobia in Our lifetimes. 1999 Tiger 885 1995 XT600E
xtphreak screwed with this post 08-14-2008 at 12:25 PM |
08-14-2008, 01:11 PM
#263 | |||
Oddometer: 7,658
what wattage (load, not light output) is the HID you have/are considering? I'll guess 35w, is it a moveable HID capsule or is there a HID Low Beam with an Haleogen High beam??? minus 35w for the headlight = 154w minus 75w for ONE aux light = 79w now right here you're at the same load as alexk243 Quote:
you'll get more light for the power load of one Hella, probably cheaper too, but I haven't looked. 2 HIDs = 60w 189w-60w= 139w 139w- 55w (stock headlight) = 84w for "house load" as described above
08-14-2008, 08:31 PM
#264 | |
Ride more, BS less!
Oddometer: 8,452
Hey,, thanks for the info,,, sorry I didn't read though all of the old posts.
I'm setting the bike up for RallyMoto at Black River Stages in Sept. There are night stages and although I don't think I can out ride the stock light, that is deer, moose and bear country so I'd like some more light. I already have the PIAA's on my GS and it's like some one turned on the switch to the sun when I power them up. OK on the GS but I wasn't sure the XT would handle them. Plus I only need the lighting for this one time so I don't want to spend a ton if I don't need to. This, http://www.futurevisionhid.com/9003-...kit-p-130.html is the kit I'm thinking of for the stock headlight. 35W, solenoid actuated high/low. I just double checked my PIAA's and they are 55W not 75W each. So if I read you correctly I have 189W to play with excluding my stock headlight. That would be okay then I guess..... HID head light 35 PIAA's 110 TOTAL 145 So 44W to spare. Quote:
08-16-2008, 09:24 AM
#265 |
the darkness
Oddometer: 3,588
Different models.
Anyone know what the difference is betweent a 92 XT600ED and EDC?
08-17-2008, 07:46 AM
#266 | |
Iowhat?
Oddometer: 478
--JOsh
08-18-2008, 10:12 AM
#267 | |
Oddometer: 7,658
08-18-2008, 04:13 PM
#268 |
Oddometer: 12
Need advise, found a 84 XT600 for a project bike. The guy said that it runs? Going to look at it on Tues. My question ..is there still parts avaliable for these old thumpers or should I look for a newer model. I should be able to pick it up for a about $200 bucks..............thanks
08-18-2008, 04:55 PM
#269 | |
Oddometer: 7,658
flip thru thru the parts lists and see how many parts are grayed out. those are the ones that they can't get from yamahaha other than that, your local dealer can still get most parts, usually as cheap as internet pricing plus shipping
08-18-2008, 05:44 PM
#270 |
Oddometer: 12
xtphreak, thanks for the help. The bike is looking better already.
