Old 08-18-2008, 10:10 PM   #271
XT Thumper
Oddometer: 14
Thanks-- found it , shorted red wire going to main switch. Found it by wiggleing wire couplings.
Pure luck. All lights back on.
XT Thumper is offline   Reply With Quote
Old 08-19-2008, 12:09 AM   #272
acupuncture4u
Freedom by knobbies
acupuncture4u's Avatar
Oddometer: 1,372
XT owner again!!! 1986
Got a line on an 86 with 3k miles on it. It's been sitting with a full tank of gas for quite some time and the tank is totally rusted out. I took off the petcock valve and it's pretty much disintegrating the plastic parts of it.
So I've taken the tank to the car wash and high pressure was has taken most of the rust out of the tank. Is there a way to repair the old petcock valve, is it too rusty and should it just be replaced?
What is the best way to remove the remainder of the rust from inside of the tank? Any special additives to help with the rust? What other tanks can I put on an 86?
And since the petcock was left on and the old gas is red and smells like turpentine, what should be done first with the carbs?
Thanks for the input. I once again am about to ride an XT across Colorado.
(((((((((RIDE)))))))))
www.betterthanyoufoundit.org At Least 1 piece!
How is your Heart Health
acupuncture4u is offline   Reply With Quote
Old 08-21-2008, 12:03 AM   #273
acupuncture4u
Freedom by knobbies
Oddometer: 1,372
Well, I thought I would also check to see where I can get a copy of the 1986 manual, how much oil for an oil change?
What sprockets do you ride?
Dustin
Old 08-21-2008, 06:04 AM   #274
Olas
the darkness
Olas's Avatar
Oddometer: 4,023
Yikes, that's alot of rust! Most motorcycle shops should have a product called Kreem (sp?) that you can remove the rust with and then apply a coat to the inside so rust doesn't come back. There are mixed reviews about this but I used it for a while with no problems.
You can also use muriatic acid (for cleaning concrete). The stuff is nasty though, so be careful but it will eat up rust like it's nothing.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 08-21-2008, 06:44 AM   #275
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
you can also remove it by electrolysis
an friend did after I sent him a link on it
lessee if I can find something about it now
back soon
OK read this page
http://www.motorcycleanchor.com/moto..._tankrust.html
talks about POR-15 rust remover/coater
Yamaha's Fuel Tank Rust Remover ($14.95, Part Number ACC-FUELT-CD-KT)
and removing it by electrolysis
http://www.stovebolt.com/techtips/ru..._derusting.htm
http://antique-engines.com/electrol.asp
the electrolysis is faster than acid etching and easier than shaking a tank or sand, BB's and distilled water for hours
read up on it, it's pretty simple, but washing soda is NOT baking soda
Washing soda should be in the laundry section of your grocery store. It comes in a yellow box, made by Arm & Hammer, but it's NOT baking soda. If you're interested, washing soda is Sodium Carbonate or "soda ash"(Na2CO3), baking soda is Sodium Bicarbonate (NaHCO3), and borax is Sodium Tetraborate Decahydrate (Na2B4O7*10H2O), all different chemical compounds.
If you can't find it locally, call Arm & Hammer at this number: 1-800-524-1328 - they should be able to tell you where the closest place is that you can find it.
Or try Soaps Gone Buy at:
http://www.soapsgonebuy.com/"
"...Want to make your own "laundry soda"? Take baking soda, spread it out onto a cookie sheet and bake it in the oven at a little over 300 degrees for an hour or so it will drive away a water and CO2 molecule thus making washing soda.
At temperatures above 300o Fahrenheit (149o Celsius), baking soda decomposes into sodium carbonate, water, and carbon dioxide.
2NaHCO3 -> Na2Co3 + H20 + CO2..."
Have Fun!!!
Oh, by the way DO NOT use a Stainless Steel Anode!!!!!!!!!!!
Stainless contains chromium which is released into the solution
BAD STUFF!!!!!
if the solution turns yellow vs reddish while working DO NOT GET IT ON YOU!!!!!
"...Dumping these on the ground or down the drain is illegal. The compounds can cause severe skin problems and ultimately, cancer. Hexavalent chromate is poisonous. These compounds are not excused from hazardous waste regulations where household wastes are. "
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak screwed with this post 08-21-2008 at 09:02 AM
xtphreak is offline   Reply With Quote
Old 08-21-2008, 07:29 AM   #276
CR_TurboGuy OP
Iowhat?
CR_TurboGuy's Avatar
Oddometer: 478
I've read of nothing but troubles with Kreem. It may work for a while, but if it goes bad, it's a real PITA to get the Kreem out. I'd go w/ xtphreak's suggestion of electrolysis & POR-15.
--JOsh
1990 Yamaha XT600E - Old Faithful
1983 Yamaha CV80 Riva/Beluga Scooter - Scooter Trash
CR_TurboGuy is offline   Reply With Quote
Old 08-21-2008, 08:59 AM   #277
xtphreak
xtphreak's Avatar
Oddometer: 7,963
--JOsh
I've used Kreem over the decades several times with no problem other than several gallons of dirty phosphoric acid to dispose of
my XT600E is coated with it right now, been in there for 6 years and counting, no signs of degradation
that said, I will probably get the POR-15 kit with Kreem remover if it looks like it's coming loose.
Ron
Robert A. Heinlen
1999 Tiger 885
1995 XT600E
Old 08-21-2008, 09:48 AM   #278
acupuncture4u
Freedom by knobbies
Oddometer: 1,372
I've done the Creem stuff, acids, coatings, voodoo chants and ended up with a half assed job. The coatings let loose. I didn't get all the rust. It still had a leak after I sealed the hell out of the tank. Then I learned my lesson. I now take the tank down to the radiator shop and ask then to boil it out and re line it. About $60.00 for a very large tank. [7.5 Gallon] No fuss, no muss, and IF there is a failure, I can take it back for a re-do. I used to buy / sell Goldwings, old carb models. Most had set a while before I got them. The biggest headache / expense was going through the carbs. At the time, most shops wanted the value of the bike to rebuild the carbs. Made no sense to lay out for the carb rebuilds and have the tank contaminate them again. Boil 'em, seal 'em and ride. Petcocks are another issue. Replace every part in the region if you can. They will fail / collapse / leak / cause mental anguish if not addressed. Also check the tech bullitens on most of the tank sealants out there for DIY. Most state that they are deadly to the wrong user. Want that sitting around for your kid or dog to get into? Get out the yellow pages and make buddies with the guy at the radiator shop.
I made another thread while waiting for a response on this thread and got the above reply. Has anyone tried this radiator technique?
Thanks,
Dustin
Old 08-21-2008, 03:53 PM   #279
Tallboy
hiding in the tallgrass
Tallboy's Avatar
Oddometer: 12,404
As I said in your other thread - Clarke makes a plastic 4 gal tank (1.1 gal over stock), you will have to get a new petcock from a dealer as it uses the stock one.
I've been fighting my SR500 tank as one of the previous owners Kreem'd the tank and it has leaked after many years, so I bought the POR-15 kit, which didn't strip all the liner off (did a bang up job on the paint ), so I had to buy more stripper. still haven't finished it yet.
I'm thinking of putting the Clarke tank on next year and trying to turn the bike into more of an agressive adv bike for the backroads.
Good luck!
If worms had daggers, birds wouldn't fuck with them.
Todd Snider
Tallboy is offline   Reply With Quote
Old 08-23-2008, 09:08 AM   #280
acupuncture4u
Freedom by knobbies
Oddometer: 1,372
Ok new issue, I need a carb rebuild kit. I have an 86 XT and can't seem to find anyone who makes a kit. Suggestions??? Maybe someone can read I think it's dutch?
http://cgi.ebay.at/XT600,-XT-600--Ke...ayphotohosting
Thanks in advance,
Dustin
http://www.motorcyclecarbs.com/CARBU...AMAHA_C697.cfm
acupuncture4u screwed with this post 08-23-2008 at 09:35 AM
Old 08-23-2008, 10:10 AM   #281
CR_TurboGuy OP
Iowhat?
Oddometer: 478
Thanks in advance,
Dustin
Try this. Otherwise, based off the Dutch auction, I'd try to locate someone who sells Keyster Carb Kits & give them that k-840yk number from the box in the picture to see if they can locate you one.
http://cgi.ebay.com/ebaymotors/YAMAH...52848299QQrdZ1
--JOsh
Old 08-23-2008, 11:14 PM   #282
ztaj
jatz
ztaj's Avatar
Oddometer: 962
Just picked it up
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Got this for mrs ztaj, she's wanted one since she first saw one when they were released, (she had an xt125 @ the time)
Seems to go good, it's been rebuilt top to bottom, front to back by a retired mechanic although the tank could do with a tidy up, bit dented and scratched, still being run in on the trip home.
I've just done about 450 k's (280 odd miles) bringing it home in heavy rain at times and it seemed really easy to ride (small compared to my bike,DR 750)
I have a question, Where is the oil filler/level indicator, I've looked but can't see it in the obvious places.
ztaj is online now   Reply With Quote
Old 08-24-2008, 12:51 AM   #283
acupuncture4u
Freedom by knobbies
Oddometer: 1,372
Couple of new links, hope they can supply...
http://www.siriusconinc.com/default.asp
http://www.cscpowersports.com/
Old 08-24-2008, 12:43 PM   #284
kmikec
Oddometer: 12
1984 XT 600. My question is can you remove the airbox with out removing the rear shock? Whats the secret. ..........thanks
kmikec is offline   Reply With Quote
Old 08-24-2008, 02:01 PM   #285
alexk243
alexk243's Avatar
Oddometer: 398
Take all the sides of the airbox off and just wiggle it out, turn it sideways and stuff. It is definatly possible.
1992 Yamaha TDM 850
1980 Honda CX500
1977 Honda Goldwing GL 1000
alexk243 is offline   Reply With Quote
Times are GMT -7.   It's 01:25 AM.
