Old 01-20-2012, 10:48 AM   #3136
Maroog
Maroog's Avatar
Oddometer: 8
Originally Posted by c00l3r View Post
Maroog with what did you start? An A4 piece of plexiglass? Or was it bigger? I'll try to make my own :) Also what holds the plexiglass to the crawling/headlight? 3 screws? Maybe you could post a close-up picture of how the windscreen is attached.
A3 I think, but I measure accurately and send you a details with more pictures. Second question answer: you right! 3 plastic screws.
Take a look at this video recorded three month ago before SOPA remove it (music copyright violation).
Maroog screwed with this post 01-20-2012 at 01:48 PM
Maroog is offline   Reply With Quote
Old 01-20-2012, 01:13 PM   #3137
JensEskildsen
Oddometer: 1,031
I love my acerbis tank aswell, heres an old pic:
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 01-20-2012, 10:27 PM   #3138
bendiebandielegs
bendiebandielegs's Avatar
Oddometer: 33
What tyres are those?
Opinions are like assholes, everyone has one.
bendiebandielegs is online now   Reply With Quote
Old 01-21-2012, 12:31 AM   #3139
TheBaldReverend
Oddometer: 17
Some more tank pics. Very easy to fit and provides some good crash protection apparently.
TheBaldReverend is offline   Reply With Quote
Old 01-21-2012, 06:50 AM   #3140
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
Looking at the Acerbis tank on justgastanks.com and it states that it fits 95-02 XT600s. Do you think it would also fit a '90 model XTE? I thought '90-'95 had no changes in the frame? I could be wrong though.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 01-21-2012, 01:07 PM   #3141
JensEskildsen
Oddometer: 1,031
Olas, no it wont. Theres a little difference in the frame, but the killer is the older design plastic, so you need to chan the following to a post 1996 model: Seat, sidecovers and rear fender together wint the gastank. Otherwise it wont work, so no easy way.
Bendiebendielegs:
Front: Heidenau K69 90/90x21
Rear: Mefo-sport mfc12 "stonemaster" 140/80x17
Old 01-21-2012, 01:15 PM   #3142
Olas
the darkness
Olas's Avatar
Oddometer: 4,024
Thanks, Jens.
That's a bummer. I'd like to find a plastic tank for my '90...I thought they made them. Did they stop production on these?
Rebuild threads:
Old 01-22-2012, 03:57 AM   #3143
JensEskildsen
Oddometer: 1,031
Hi, yeb I think so.....Perhaps they didnt make many, there's hardly any used ones for sale (as you might know)
Old 01-23-2012, 07:54 AM   #3144
preppypyro
preppypyro's Avatar
Oddometer: 576
For you guys that have painted your engines, I was wondering what kind of paint you guys used. I started a thread in the garage but thought Id ask here. Im thinking I want to keep heat disapation in mind. I dont care if its from a rattlecan, or if I have to spray it with a gun. Im going to paint the complete engine, if I figure I can get some good paint for it, any advice/help is welcome. I would like some decent quality paint, but not looking for top quality, unless the price is right.
I do live in Canada as well, so I have to be able to get it up here as well.
preppypyro is offline   Reply With Quote
Old 01-23-2012, 09:30 PM   #3145
bendiebandielegs
Oddometer: 33
Bendiebendielegs:
Thanks.
Old 01-26-2012, 11:50 AM   #3146
bosley1980
Oddometer: 162
Question Help
Anyone pls HELP ME
Is this shock adjustable? (LEFT)
It is from yamaha XT600 1986 - there's something missing, or it can add air (valve on top).
bosley1980 screwed with this post 05-04-2012 at 09:30 AM
bosley1980 is offline   Reply With Quote
Old 01-26-2012, 08:07 PM   #3147
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,244
XT, or TT Shock?
Originally Posted by bosley1980 View Post
Anyone pls HELP ME
My XT 600 has no place for a valve. The 2nd shock is off a TT600. The TT 600 shock has a remote res. on it. Thump-On!!
BIG ED XT FAN is offline   Reply With Quote
Old 01-26-2012, 08:57 PM   #3148
Pawlie
Oddometer: 87
Hello bosley,
The shock on the left appears to be a stock XT600 shock that has been modified with a Schrader valve added at the top of the resivoir. This valve allows the shock to be refilled with nitrogen when needed. This shock also can be adjusted for preload (currently in the stiffest position of three). Preload is adjusted by moving the upper spring collar which is held in place with a large C clip (see other groves on shock body). At the bottom there is a damping adjuster which can be turned.
As Big Ed has previously pointed out the shock on the right looks like a TT unit. I have no personal experience with the TT shock but from seeing other peoples pictures I would say it's a TT unit & Big ED knows his stuff!
All the best,
Pawlie
Pawlie screwed with this post 01-26-2012 at 09:03 PM
Pawlie is offline   Reply With Quote
Old 01-26-2012, 09:30 PM   #3149
Pawlie
Oddometer: 87
Hello Preppypyro,
FWIW:
I am no paint pro but here is what I did to paint my XT engine and it seems to be holding up quite well.
Parts that were blasted clean (to bare alu) at machine shop:
Cleaned and scrubbed with solution of water and "Sprayclean" household cleaner. Thoroughly dryed. Wiped with Pro Form final wipe solvent, Lightly primed with etch primer. Painted with black and then clear coated for finish (number of coats and sanding inbetween, up to you).
Parts with remaining old paint:
Surface thoroughly scuffed, repeat cleaning/drying as above, then black, then clear.
I used Plasti-kote engine enamel # 203 universal black and# 229 clear. Proform final wipe
I would say the clear has yellowed/darkened a little but frankly this is not very noticable.
Many will say to leave the head unpainted for best heat dissipation.
I suspect the respray paint I put on the head will not last too long. There was no stock paint left on the head at the time of rebuild. It was long gone due to heat.
I am in Canada too, these paints are at Lordco auto parts and probably others!
Good luck
Pawlie
Pawlie screwed with this post 01-26-2012 at 09:36 PM
Old 01-27-2012, 08:04 AM   #3150
bosley1980
Oddometer: 162
But seller write it's the Yamaha XT600 shock. Why no place for valve (frame?).
Not working on my xt600e 98???
oh nooo I ordered...
Times are GMT -7.   It's 04:25 AM.
