Old 08-21-2012, 06:58 AM   #3616
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 522
Originally Posted by vudu View Post
Sounds like slap to me. Or low oil.
XT600 engines are built with a rather large piston clearance, so some piston slap on XT600s would be considered NORMAL, even desired.
Having said that, the noise on your video IS way too excessive. To me it sounds like someone (you) might have seriously messed up the valve clearances due to not correctly following procedure.
A-Wind is offline   Reply With Quote
Old 08-21-2012, 07:06 AM   #3617
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 203
or cam chain tensioner ?
webmonstro is offline   Reply With Quote
Old 08-21-2012, 11:12 AM   #3618
bosley1980
Rider
bosley1980's Avatar
Oddometer: 106
Originally Posted by pappito View Post
Bosley, you dowg!! :) Lucky bastard :)
But where are your pegs, mate?
This is a photo from 2009 (bike and my girl with pink bikini), with footpegs I started in May 2012.
I still bought and changed for other than I made those with whom I would be satisfied.
What I make NOW is MARK V. in preparation is the MARK VII now.
MARK VII
MARK VI is ugly :-)
HERE MAP OF MY FOOTPEGS USERS
bosley1980 is offline   Reply With Quote
Old 08-21-2012, 09:41 PM   #3619
yamahaman
wannabe bike builder
yamahaman's Avatar
Oddometer: 214
sleeve could be loose
I have heard of a few with the liner coming loose and causing a exessive rattle.
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Old 08-22-2012, 10:51 AM   #3620
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,132
I once had a sleeve that was pressed in too low or a bad resleeve that allowed it to be loose which resulted in head gasket leak. The bike still ran but took an outside observer to see the blowing fumes past the head gasket. bike had a fried head at first, possibly from that escaping gas overheating it. Resulted a loud popping sounding like a head exhaust leak when revved.
What I'm getting at is that it seems the sleeve would settle into a high or low position if loose.
I've also improperly honed a cylinder resulting in piston slap.
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 08-22-2012, 11:46 AM   #3621
ORMoto
Oddometer: 6
It made the same sound before and after i did the valve clearances. Which makes me think its something else, I was reading some more online, and alot of people say the cam belt tightens (or is spos to rather, if its not totally slacked out) when you rev the bike, so the noise could go away if it was the cam belt.
Watching these video's someone posted, but they are not great for telling which bolts to remove ect, so i think i'll take it to a local small time shop, and have them there into it for me.
ORMoto is offline   Reply With Quote
Old 08-22-2012, 02:56 PM   #3622
damo2010
damo
damo2010's Avatar
Oddometer: 394
Just asking what might be a silly Q
I though cam chain noise would be different to valve clearance and piston slap
If I'm hearing correctly on the video, it is a distinct ping type sound that continues when revved
I'm no expert but I'd be interested to know the outcome if this
Damo
Yamaha Tenere XTZ660 4UX
http://share.findmespot.com/shared/f...rbiW8y1XLQCMtY
damo2010 is offline   Reply With Quote
Old 08-22-2012, 06:36 PM   #3623
ORMoto
Oddometer: 6
This is where i'm confused Also... I really wanna Tear into it, it would be the 1st time I ever Opened up a 4stroke motor... Very curious what area's inside there need tending too. If i can find a detailed link, i might just give it a go.
Also, is removing the motor from bike needed to remove top end ?
Old 08-23-2012, 12:51 AM   #3624
McGoo
McGoo's Avatar
Oddometer: 63
I haven't done it, but apparently not. There is meant to be enough wiggle room once tank, coils, etc are off to get the head and the barrel off. It's only the crankcase that needs engine out.
McGoo is offline   Reply With Quote
Old 08-23-2012, 01:24 AM   #3625
webmonstro
webmonstro's Avatar
Oddometer: 203
No it is not necessary
Can you pinpoint the noise ? valve cover maybe ?
Maybe just remove vale cover and have a look
thinking like rocker arms ?
Nuno
Old 08-23-2012, 03:13 AM   #3626
damo2010
damo
damo2010's Avatar
Oddometer: 394
I'm just thinking, if you get on ok with your local bike store maybe you can ask the mechanic to give his impression so you have some idea before opening up
Damo
Old 08-23-2012, 08:16 AM   #3627
xtscruff
Oddometer: 20
help!!!
i have a xt600z, it has recently been stalling below 2000rpm, it has massivews shut down popnbang, this has happened when the bike fails to tick over or slowing down, i have been informed this is most likely the idle jet has a blockage, but, today i go to start it and nothing, its turning over, but the spark is very weak, anyone got any ideas,please, i bought this while still sorting the xt550 out.
xtscruff is offline   Reply With Quote
Old 08-23-2012, 09:12 AM   #3628
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 522
The first time I was listening to your recording I said it was way too excessive. I guess the feel of the sound out of the computer did not let me feel in well enough. Also (at first time listening) I heard a much stronger pronounced high notes ticking for whatever reason. Perhaps some speaker quality issues or maybe it was too early for me in the morning. BTW: I challenge others who posted here to listen closer again as well.
Indeed, now I listened to it again and it sounds very similar to the sound that my engine is making for about the past 30.000 miles.
It IS certainly (the for the XT600 typical AND for the XT600 harmless) piston slap, as mentioned earlier. If you listen to it carefully, the noise should be a bit different (somewhat louder) in cold condition and would get a bit better after warming up, although sometimes when the engine is really hot you might hear it even louder.
It is all normal = no worries, ride the bike, ride it until the wheels fall off AND don't let anybody tell you othervise!
If the engine runs strong and does not use more than 1 quart oil per 1000km, then I would under NO circumstances open this engine, as any attempt (especially by somkeone for hire) tying to fix this might very well turn out to be the END of your engine.
A-Wind screwed with this post 08-23-2012 at 02:41 PM Reason: added text: if the engine runs strong and does not use more than 1 quart oil per 1000km, then...
Old 08-23-2012, 10:25 AM   #3629
JensEskildsen
Oddometer: 841
I think it sounds really excessive
2003 xt600e 118.000km on stock motor.
1986 xt350 94.000km
JensEskildsen is offline   Reply With Quote
Old 08-23-2012, 02:50 PM   #3630
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 522
The XT600 Thread
I would love to hear/see a video of yours running as a comparison.
A-Wind screwed with this post 08-23-2012 at 03:37 PM
Times are GMT -7.   It's 04:21 PM.
