Old 11-19-2012, 09:40 PM   #3811
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,039
Originally Posted by webmonstro View Post
hi all
just droped by too show you all what great bike we have
Yesterday me and a couple of freind's went on a short ride
along the area of a local dam and river (Aguieira dam on the Mondego river)
In center Portugal
here's some pics:
in the morning there was alot of fog
Had to go over the train line
The train whent by after about 2 min after we went over
hope you'll injoy
Nuno
Thanks for posting!!
BIG ED XT FAN is offline   Reply With Quote
Old 11-23-2012, 12:13 PM   #3812
jch
Oddometer: 39
Rack
Originally Posted by dougfromindy View Post
*****I just bought this rack, its very nice HD from Germany, an sw motech brand, I will be mounting a givi e30 topbox to it....If you want one for spring you had better order now, not in stock, 3 months wait from Germany ***
Does anyone have this rack or another one that will fit on the back of my 1991 XT600E? Thanks
jch is offline   Reply With Quote
Old 11-27-2012, 02:10 PM   #3813
jch
Oddometer: 39
Originally Posted by Dannog View Post
I picked up a send hand tacho pick up drive (from the earlier XT model) that bolts straight into the existing heads. There is a cover plate on the head now which I can remove and the drive bolts straight in. New tacho cable and everything works. Problem is still mounting the speedo/tacho mount plate to the triple as the centres dont line up and I have been unable to find a second hand one on ebay yet.
The tacho drive looks like this and bolts into the RHS of the cyclinder head.
Thanks for the info - I got a tach on my 1991 XT600E as follows
Had:
XT350 tach and cable, broken mounting plate from an xt350
Bought tacho drive as above on ebay for $30 shipped
I removed the blank plate from the head and mounted the tach drive (the blank plate was very brittle and a bitch to get out - it is now in about 5 pieces). Dremeled my half mounting plate and attached to one of the four handlebar bolts using the existing post hole in the bracket. Cut off the corresponding post on the tach. Attached the tach to the bracket using the other post. Attached the cable from the drive to the tach. It is higher than the guage cluster but is very solid an looks pretty good. I left all of the indicator lights alone and will likely just run a bulp to the tach to light it up.
Old 11-28-2012, 12:42 PM   #3814
no eye deer
Oddometer: 8
Quick question on oil filter bolt.
G'day,
just did the first filter change on the XT600e.
Usual story of stripped thread.
Question is, the top front bolt hole- does it have a channel at the end to lube the crank?
Some posts say use a longer bolt- some say dont.
I would either use a longer bolt (if I can find one) or use a stud and some thread repair epoxy stuff.
But dont want to block an oil channel with either a bolt or a gob of epoxy.
Hope you can help.
Mark
no eye deer is offline   Reply With Quote
Old 11-29-2012, 01:49 AM   #3815
no eye deer
Oddometer: 8
Come on you mob! The question is wafer thin....
Old 11-29-2012, 03:26 AM   #3816
Fred333
Oddometer: 43
Hi Mark,
there is just the lower bolt "doing" something.
The one with the bigger head and bigger thread.
If you pull out this lower bolt, you can drain the oilfilterhousing into the sump in order do avoid the mess when you take the oilfiltercover off.
That is (to my knowledge) the only "function" of this bolt.
The other two are just holding the cover.
Maybe you mean the very small screw on the top of the oilfilterhousing?
This one is need for getting the air out of the oilfilterhousing.
After the filterchange you start the engine and open this little screw.
When there is oil coming you close this screw. and you are done.
This provides lubrication for the head.
If this is total rubbish... tell me!
Olli
PS: Never swap out this lower bolt!
the diameter is vital!
It closes the channel for draining the oil into the sump.
Take the clutchcover off and repair the threads proper. So you can use the original bolts.
TT 600 36A, 59X, 3SW bastard
Restauration here: http://www.tenere.co.uk/forum/viewtopic.php?f=4&t=82
XT 600 Z Tenere (34L)
Fred333 screwed with this post 11-29-2012 at 03:39 AM
Fred333 is offline   Reply With Quote
Old 11-29-2012, 04:30 AM   #3817
TheRadBaron
Oddometer: 321
Maybe the problem is with you, rather than with us. Your post is sort of strangely worded and not the easiest to understand. You're not entitled to an answer.
The desire for safety stands against every great and noble enterprise. -Tacitus
TheRadBaron screwed with this post 11-29-2012 at 04:36 AM
TheRadBaron is offline   Reply With Quote
Old 11-29-2012, 04:54 AM   #3818
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 203
G'day,
Hope you can help.
Mark
only the bootm one act's as a drain
i have used a stud in the past but best solution would be to just rebuitd tread with helicoil or someting
Nuno
webmonstro is offline   Reply With Quote
Old 11-29-2012, 05:06 AM   #3819
Fred333
Oddometer: 43
I think it has something to do with the way of life in Europe/Australia vs the way of life in the US and A.
I do know how Mark words are meant.
But this leads to nowhere...
Olli
Old 11-29-2012, 11:13 AM   #3820
Olas
the darkness
Olas's Avatar
Oddometer: 3,588
Hi guys, I am back.
I am trying to sort out this 1984 XT600 that runs pretty good but the idle seems to be off. When you give it gas it will run fine but the idle seems to hang around 3-4k RPM until I blip the throttle and then it comes back down. I need to make sure that the throttle valve and secondary piston aren't sticking open still but is there anything else that I might check out?
Jetting is all stock, float level is within spec, fuel screw is at 1.75 turns and all the intake rubber has been replaced so I am fairly confident that it is not drawing any air from unwanted places.
Thanks so much.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 11-29-2012, 11:54 AM   #3821
no eye deer
Oddometer: 8
Originally Posted by Fred333 View Post
Hi Mark,
Olli
Thanks Fred,
Yeah, I mean the two top bolts that hold the oil filter cover on. The bottom (drain) screw and the bleed screw are still good. The one at the front facing the front wheel, is the stripped one.
My worry was was that this hole was open inside the crankcase. If I tried to rethread it, swarf would go into the engine. If I tried "Thread repair" it would put epoxy into the crankcase.
I SHOULD take the clutch cover -I know- but really I dont want too:) Too slack......
But I'll work on this, maybe get a stud if I can find someone in Cairns that has half a brain. The last bolt dealer I went to (biggish shop) said "Nah, thats an automotive thread. We dont have those"
Thanks Fred!! Done well!! Thanks Nuno! Usefull replies Good on ya!
Old 11-29-2012, 11:57 AM   #3822
no eye deer
Oddometer: 8
Originally Posted by Olas View Post
Hi guys, I am back.
Thanks so much.
Sounds like -maybe- a frayed throttle cable? At the top prolly. Or sticky stuff around the carby linkages? Trapped/kinked throttle cable?
Mark
Old 11-29-2012, 12:58 PM   #3823
webmonstro
webmonstro's Avatar
Oddometer: 203
Mark
I've seen this happen on a 660 (similar carb) on the top of the primary carb there is a linkegde under the plastic cover
attached to a shaft this is what makes the slide rise and go down inside the carb, the link has a screw that hold it on the shaft
It was a little loose and the slide would not go down by itself making the idle hang until the throttle was bliped.
here: (blue arrow):
Nuno
webmonstro screwed with this post 11-30-2012 at 04:45 AM Reason: leared how to write
Old 11-29-2012, 07:25 PM   #3824
BIG ED XT FAN
Oddometer: 1,039
Hi guys, I am back.
Thanks so much.
Any photos of your 1984 XT 600?
Old 12-01-2012, 08:17 PM   #3825
Olas
the darkness
Olas's Avatar
Oddometer: 3,588
Mark
Nuno
Thanks for the replies guys. I had to take the wheel off for repair. It will need new spokes. So once I get that sorted I will start on the carb again. I put some marvel mystery oil in the gas and ran it to lube and clean the inside of the carburetor while it sits with the wheel off. The engine felt and ran strong, and pretty quiet for 13,000 miles.
Ed, I will get some pics up very soon... The bike just looks so sad right now, I need to take care of some things on it first.
I am looking for a set of spokes for this '84 XT600. Can anyone point me in the right direction here? I see kedo has a set for the '87-'89 XT600s but they don't list anything for the '84. Where there some major changes done to the XT in '87?
Rebuild threads:
Times are GMT -7.   It's 11:31 PM.
