01-09-2013, 12:58 PM
#3871 | |
Oddometer: 12
choke on carb
2KF-1410A-00-00 PLUNGER, STARTER, will fit perfectly, michael |
01-09-2013, 01:01 PM
#3872 |
Oddometer: 12
ups, did not see that somebody else answers the question, they work perfectly, put one in a 1986 xt600, no difference!
01-09-2013, 01:18 PM
#3873 | |
Oddometer: 42
01-09-2013, 03:36 PM
#3874 |
Andreas RD07a
Oddometer: 522
01-13-2013, 02:24 PM
#3875 |
Oddometer: 1
Hi
New owner to an old 1990 2NF. Found a Öhlins rear shock for 95-00? year model. Will it be a possible fit for my older one? |
01-17-2013, 12:38 PM
#3876 |
MotherThumper
Oddometer: 19
Could anybody tell me how to inspect brakes? I bought used front brake rotor and new front/rear brake pads. There is no leaking, I cannot tell if the pistons are working well, the rear one has much more stroke than front. I don't know to inspect the "rubber" parts. Hoses are in good condition but I think I'll buy a new armored hose and change brake oil.
Sorry for my crappy English, I hope you can understand me :) |
01-17-2013, 05:14 PM
#3877 | |
the darkness
Oddometer: 3,588
01-18-2013, 10:34 AM
#3878 |
Oddometer: 2
That's a cool picture Andreja, might have to use it as my background pic. Looks like you can ride all over the place.
01-18-2013, 01:55 PM
#3879 | |
Oddometer: 47
01-18-2013, 04:32 PM
#3880 |
MotherThumper
Oddometer: 19
Sydney Andy, thanks for instructions dude
indytxl, let me know if you need more pics of it, I'll be glad to share 'em in this topic ![]() Edit: I've bought a rack for my XT with a toolbox, spare clutch cable, new mirror and clutch lever "holder" and a chain slider for rear fork :) |
01-19-2013, 12:13 AM
#3881 |
Joatmoa
Oddometer: 46
Riky Cross
There are quite a few people who have been upset by a lack of product for the money they have spent with http://www.accessorimotocross.it
If I were you I would steer clear. As a general tip, if they don't take Paypal then there is something wrong! |
01-21-2013, 02:39 PM
#3882 |
Oddometer: 3
Funny spark
I´m restoring a XT600Z 34L 1983. The spark is weak or seems to fire every 6-8 time of kicking. I have only rebuilt the ignition circut and have no battery or charging system. The two systems are fully independent as I understand. I had the bike running but it´s getting harder or impossible to start. So is this a bad wire connection, faulty CDI, Ignition coil measurs good. Pickup coil is a bit off the chart (110ohm and 110ohm both sides so I think it´s a measuing problem).
Has anyone had the spark come and go? /Fred. OK the CDI is no good. I switched from my 43f. CDI anyone? Freddan screwed with this post 01-23-2013 at 12:42 AM |
01-21-2013, 05:09 PM
#3883 | |
Oddometer: 314
Yes the ignition system is “stand alone”. 110 ohm is about right for the pickups. Disconnect the black/white wire from the CDI when testing, it is the “kill” wire. By disconnecting it you rule out a failure in the ignition switch, kill switch, wiring, etc . Check the Ignition coil, my XT550 has the same igniton: Primary = 0,5 ohm plus/minus 15% Secondary = 6K ohm plus/minus 15% I have a CDI from hpi.be in my XT550 (the original one died two years ago) ,it was plug and play, no problems so far. |
01-21-2013, 06:17 PM
#3884 | |
Aspiring human
Oddometer: 2,134
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
01-25-2013, 08:40 AM
#3885 |
Oddometer: 42
Hey Guys Happy New Years
I got an 89 XT600 and in search of the right side Crank Case Cover, Don't Need the case, just the cover that bolts to it, The previous owner re-drilled and tapped the crap out of one of the oil screws on the side cap is, Now its leaking little by little mostly when I do freeway riding and the bike build pressure, Ill see it on the side of the case, Ebay however seems to be filled with complete cases for sale but no covers? any ideas on where to locate or does someone wana sell one? Also dont have money for a new one. |
