Old 06-20-2010, 02:46 PM   #1741
DaveRMS
DaveRMS's Avatar
Oddometer: 1,194
Hi Duke,
Same problem, same fix, just different side of the seal failing.
Easy :-)
Dave
Originally Posted by Hayduke
Question for the RFS guru's;
I started getting a leak from my waterpump seal weep hole (again ), and I ordered the replacement seal kit from Travis on KTM talk. Now I realize it's not coolant, but oil leaking there (just a little bit, occasionally). Will the seal kit fix this or do I have a deeper problem.
DaveRMS is online now   Reply With Quote
Old 06-20-2010, 02:54 PM   #1742
Raul Duke
DROC
Raul Duke's Avatar
Oddometer: 1,831
Originally Posted by FakeName
I'm no expert, but I won't let that stop me from posting on the internet as if I am....
There are two seals in the carrier, one for oil, the other for coolant. Assuming the seal for oil is compromised, it could explain the leak.
+1
Raul Duke is offline   Reply With Quote
Old 06-20-2010, 05:51 PM   #1743
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
Originally Posted by GSNorCal
Hi Duke,
Easy :-)
Dave
That's what I thought. I replaced it once before when coolant was leaking. About 60 hrs. ago. Luckily it only took me about 20 minutes to replace it.
It only leaks a little when the bike gets really hot, so not urgent.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 06-20-2010, 05:55 PM   #1744
Raul Duke
DROC
Raul Duke's Avatar
Oddometer: 1,831
Be careful not to damage it on the shaft when you put it on. I think the kit you have on order from Travis will have a protector for it. If not just use a bit of electrical tape on the shaft to cover the end.
Old 06-20-2010, 06:06 PM   #1745
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
Yep, it has a little protector on it.
Old 06-20-2010, 09:09 PM   #1746
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,360
Check the cam too. The seals have a habit of grooving the camshaft and even new seals have a hard time sealing. If yours is looking iffy you can try to smooth it out with some emery cloth to see if that helps. If not then it's time for a new cam.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 06-22-2010, 06:58 AM   #1747
john_aero
john_aero's Avatar
Oddometer: 1,173
taught here may be good place aks ye lads as cant find a seperate thread on the ktm 520 exc.
what they like for reliability, its an 02 and i am looking getting one fore enduro and trail riding to go along with my bmw dakar
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 06-22-2010, 10:01 AM   #1748
GR0NK
GR0NK's Avatar
Oddometer: 2,360
Other than a few updates, the 520 is the same exact motor as the 525. The biggest reliability update to do on the 02 is to swap the cam gear out for the later style. The old one has a bolt with a nylock nut that acts as the auto decomp stop. In some rare instances, it has been known to come apart and then you have a couple steel parts floating around that can get into the crank. Also there is a lower cam chain guide upgraded with a screen to prevent anything but oil from going into the crankcase from the stator side.
How many hours does this bike have. Anything more than 300-400 I would pull the head and have the valves inspected/replaced. The stock KTM ones are soft and wear pretty fast.(300 hours for me, ridden hard with some MX in there) Kibblewhite stainless steel valves (oversize if you have a shop that can cut the seats is a bonus) is the ticket. Those valves will go beyond 1000 hours easily.
Sean
Old 06-22-2010, 10:28 AM   #1749
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
I'm at 147 hours on my '05 525, and I just adjusted the valves. This was the first valve adjustment that I've had to make a significant adjustment- the intake valves were tight! I figure I'll be doing the Kibblewhite valves eventually.
BTW- have I mentioned how much I love this bike lately?
Old 06-22-2010, 10:40 AM   #1750
john_aero
john_aero's Avatar
Oddometer: 1,173
cheers, being an irish bike i wouldnt trust any of the hours/times as never know what lads do to the speedo cable to make bike look fresher.
just going over the add more closely and looks like bike has had hard life and picture of bike seems show that
cheers for the fast reply
Old 06-22-2010, 10:54 AM   #1751
svs
All Hands on Deck!
svs's Avatar
Oddometer: 25,072
I'm at 149 on my 05 525.....
Valves are good. Yes. very much love the bike.
If a physical fact can produce a psychological state, a psychological state can produce a physical fact... The whole of creation is asleep within the deep of man and is awakened to objective existence by his subconscious assumptions.
svs is online now   Reply With Quote
Old 06-24-2010, 05:22 PM   #1752
fuzzydude2
CMA'er
fuzzydude2's Avatar
Oddometer: 212
Seat
Anyone do the Guts comfort seat? soft/med/hard? it is supposed to be wider and flatter than the stock seat for about $120.
I have a Ranazco on my DR and it is a great seat but cost much more.
Wonder if the Guts would be similar?
any other options worthy of investigating?
I do not want something taller.
thanks,
"To boldly go where no man has gone before"
Star Trek
06' Triumph Sprint / 00' Goldwing
01' Moto Guzzi California Special
98' KTM 620 RXC / 05' KTM 525 EXC
fuzzydude2 is offline   Reply With Quote
Old 06-24-2010, 05:26 PM   #1753
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,847
Yes!
I highly recommend the Guts lower/wider. I bought it for a long-distance seat, but have since ditched my tall seat- it's that much more comfortable.
Go for it!
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 06-24-2010, 06:15 PM   #1754
pterry
Desert rider
pterry's Avatar
Oddometer: 622
Yes!
Go for it!
I was looking on the Guts site. So...you have to buy a kit and staple it together? The EE seat I bought was all together in one piece. I do like the idea of a soft WIDE seat.
_ __7_
O="^O
The magnitude of your duchebaggary could clean a whales vagina.
pterry is online now   Reply With Quote
Old 06-24-2010, 06:29 PM   #1755
team ftb
Befuddled Adventurer
Oddometer: 1,760
Question:
I've got 13-52 gearing. I like the tractor feel offroad but could compromise a little.
1.What would be a good middle of the road gearing? I think stock is 15-45.
2.Or should I do separate gearing for each set up and what for sreet?
Stock is 14/48. I use this gearing for Dual Sport riding and its great as it can lope along the pavement at 65 MPH with the throttle just cracked, however my bike is a 570. For stictly off road I switch to a 14/50.
For my Sumo set-up for the street I use a 14/42. Great for the 2nd - 4th gear corners and still tops out over 100MPH. I've used 14/48 and 14/50 at the kart tracks.
Enjoy your motard set-up!!
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Times are GMT -7.   It's 03:32 PM.
