Old 03-12-2011, 04:33 PM   #2746
KrAzyOSUcOwBoY
kRaZy
Oddometer: 81
Any pics of the giant loop tank bag with a Clarke or IMS 3 gal tank?
KrAzyOSUcOwBoY is offline   Reply With Quote
Old 03-12-2011, 10:08 PM   #2747
header
Chris
header's Avatar
Oddometer: 1,684
What does it cost to swap out the gears from an MXC to an EXC? I found a promising deal on an MXC but I can't find anywhere that gives me a reliable answer to how much swapping the gears would cost used (new I found it to be right around 500)
KTM 530exc
Header's journal
525exc refresh
header is offline   Reply With Quote
Old 03-12-2011, 10:34 PM   #2748
DRjoe
DRjoe's Avatar
Oddometer: 4,295
One of the pro builders on ktmtalk.com should be able to help you out.
Caflash seems to have plenty of good second hand parts.
http://ktmtalk.com/index.php?showuser=2312
Old 03-13-2011, 07:33 AM   #2749
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,402
There's been an EXC trans on ebay for awhile for about $300. You could throw an offer to the seller. It has worked for me in the past.
I was looking to do the same trans swap. Then I came across a full 525EXC basket case. I put all the suspension on my boys bike and built the motor for mine. I was lucky and it only cost my another $200 to get the motor running. My full 450mxc is now sitting safely in a box as a backup.
Tip- Use the KTM gasket set. It has everything you will need, all seals washers & o-rings included. The gasket set alone is $160.
Caflash would also be a good source for the gearset.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC
To Think is to Create!
My2Wheels
dad2bike is offline   Reply With Quote
Old 03-13-2011, 08:50 AM   #2750
header
Chris
header's Avatar
Oddometer: 1,684
Thanks guys, that really helps.
It means the 2002 MXC for sale is very close to the price of the 04 EXC I found.
KTM 530exc
Header's journal
525exc refresh
Old 03-13-2011, 09:01 AM   #2751
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,402
Wait! You didn't note it was a 2002 mxc. 2003 they changed the clutch attachment on the mainshaft. Go for the 04EXC. There are several good evolution of the RFS threads on KTM talk. 04 is way better than the 02.
Tom
My2Wheels
Old 03-13-2011, 11:37 AM   #2752
BAKERMAN
The Real BAKERMAN
BAKERMAN's Avatar
Oddometer: 194
Originally Posted by FakeName View Post
Giant Loop was my choice, and I stand by it!
DO you guys run with STEERING DAMPERS ?
CHURCHILL FELLOW 1983
BAKERMAN is offline   Reply With Quote
Old 03-13-2011, 01:34 PM   #2753
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,208
YeS I dO.
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 03-13-2011, 02:04 PM   #2754
BAKERMAN
The Real BAKERMAN
BAKERMAN's Avatar
Oddometer: 194
YeS I dO.
HOW do they work ?
Old 03-13-2011, 02:12 PM   #2755
crazybrit
crazybrit's Avatar
Oddometer: 8,066
HOW do they work ?
Is this really what you're asking? Or how well do they work?
If it's the later you'll get you a wide range of answers depending on who you ask. You need to just try a bike with one and see what you think. Otherwise it's like asking for a tyre recommendation.
crazybrit is offline   Reply With Quote
Old 03-13-2011, 02:48 PM   #2756
BAKERMAN
The Real BAKERMAN
BAKERMAN's Avatar
Oddometer: 194
Sorry should know better, are thet worth the money ?
Old 03-13-2011, 02:53 PM   #2757
nevermind
Muchacho mui loco
nevermind's Avatar
Oddometer: 2,303
Yes. Set up properly, they are the dogs danglies. However, I'd say NO if your children have to go without food so you can get one...
nevermind is offline   Reply With Quote
Old 03-13-2011, 04:34 PM   #2758
oregonlmd
Dirt,street,its all good.
Oddometer: 81
I run the Scotts. Makes riding rough terrain less fatiguing because you don't fight the bars getting deflected. They inhibit hi-speed tank slappers, too.
oregonlmd is offline   Reply With Quote
Old 03-13-2011, 04:46 PM   #2759
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,402
Once you get used to running a stabilizer, you will surely notice if you aren't.
I was riding sweep a few weeks ago and was all over the place and had serious arm pump by the time I got done. I later found out my pinch bolt had dropped off. The arm was just dangling there. I have since installed a new bolt. I happen to run GPR's on all my bikes. I've heard the Scotts has a a 2 speed dampening. I have no experience if that is better or not. Cost seems to be comparable.
Tom
My2Wheels
Old 03-13-2011, 04:53 PM   #2760
crazybrit
crazybrit's Avatar
Oddometer: 8,066
Yes plus the Scotts (dirt) has a free return to center. The GPR dampens indentically in both directions (same as the Ohlins/Scotts street). Each has their fans and detractors. EMIG is the same as Scotts IIRC though they claim that their no return to center damping is unique to them
I've also heard it said that the GPRs need more frequent service. Nice thing about the GPR is that there is only one knob to turn
Times are GMT -7.   It's 02:05 AM.
