Old 08-10-2012, 06:33 PM   #4066
yondering
yondering's Avatar
Oddometer: 1,100
The kill circuit basically just grounds out the ignition, preventing spark. It is OK to leave it grounded; it only has power when the engine is running.
yondering is offline   Reply With Quote
Old 08-10-2012, 06:52 PM   #4067
Bicycle Phil
Bicycle Phil's Avatar
Oddometer: 698
Goblin Valley in Utah, just a few weeks ago. It rained the night before and then again the next morning. Enough to calm the dust and cool things off a bit.
-Phil-
San Francisco Motorcycle Club
Thank you: MX1West, Renazco Racing, KTM Twins, Rally Management Services
Bicycle Phil is online now   Reply With Quote
Old 08-10-2012, 07:00 PM   #4068
Bicycle Phil
Oddometer: 698
Utah perfection.
-Phil-
Old 08-10-2012, 08:41 PM   #4069
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,038
Cool shots, Phil. Is that the Orange trail or Waterfall?
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 08-10-2012, 10:09 PM   #4070
Bicycle Phil
Oddometer: 698
Orange trail.....
In 3 days of riding in Utah I saw nary a soul on the trails....the temps were quite agreeable....not a drop more than the low 90's at most.
Will certainly return to Goblin Valley/Justensen Flats area.
Had a fine day in the San Juans as well:
Started the day with Black Bear, then Imogene, Engineer, Cinnamon. Camped at South Mineral CG, a real nice spot!
Completely in awe of the scenery. Had to stop numerous times to avoid running off the road as my head was turned either full right or full left trying to take it all in....
-Phil-
Old 08-11-2012, 12:34 PM   #4071
johnkol
Oddometer: 136
Did you actually ride all the way from San Francisco to Utah, or did you truck the bike?
johnkol is offline   Reply With Quote
Old 08-11-2012, 02:19 PM   #4072
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,552
hi Phil
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is online now   Reply With Quote
Old 08-12-2012, 09:58 PM   #4073
Bicycle Phil
Oddometer: 698
Trucked out....
Originally Posted by skibum69 View Post
hi Phil
Howdy Mike!
-Phil-
Old 08-20-2012, 01:55 PM   #4074
vgx
Oddometer: 12
How is called that rubber socket for bulb which is used to hold speedometer light or high beam indicator bulb? Maybe there is a special code or keywords how can I find it? I think about think like this http://www.vwgolf-mk2.com/LED/small%20light/002.jpg but how to find the correct one?
vgx is offline   Reply With Quote
Old 08-20-2012, 02:01 PM   #4075
crazybrit
crazybrit's Avatar
Oddometer: 8,555
They're part of the wiring harness. I don't believe they are available separately (at least from KTM) but I could be wrong.
http://173.74.246.25/munnracing/show...%20(SIX%20DAYS)
Look for #80 which is the flasher harness addon. It has the bulb socket for the turn signal indicator.
The socket for the high beam is next to the other bulb (#45) just above on the main wiring harness (#5).
crazybrit is offline   Reply With Quote
Old 08-21-2012, 04:17 AM   #4076
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,552
electrical frustration with my 525 trying to piece together various circuits to make it rideable in enduro trim now that all of the rally kit is gone, sigh
Beerthief
Old 08-21-2012, 05:56 AM   #4077
LukasM
Oddometer: 5,426
I had to deal with that shit on my 520 EXC where the previous owner completely hacked up the wiring harness. After trying to fix too many stripped and spliced wires that would probably become failure points later I decided to just get a new harness. It was around $90 brand new from the dealer, totally worth it to me.
At least she came out pretty nice for a 12 year old bike with a 25.000+ kms!
Old 08-21-2012, 07:11 AM   #4078
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,552
it might be worth my while to do that, but then I'll have to add stuff for my roadbook etc. Not a big deal I'm sure.
Beerthief
Old 08-21-2012, 09:29 AM   #4079
team ftb
Befuddled Adventurer
Oddometer: 1,761
Looking for opinions please
Gents - I've been riding and enjoying my 525 for many years now. Got about 560+ hours on the gal now and she's fully sorted and set-up perfectly for me and my riding style.
2005 525 EXC:
Motor
*20 hours on new 570 piston and cylinder and rebuilt DJH head with +1 KW valves
*100 hours on rebuilt and balanced crank w/Annular bearings
*all bearings and gaskets and final drive shaft replaced
* TT stator and lightened flywheel
*SX exhaust
*new Hinson Clutch hub coming ion the mail
Chassis
*Sprung and valved for me by KTM suspension shootout winner. SKF seals.
* 17 degree Topar triple clamps
*2010 complete forks available if I need them
Extras
Clarke tank
Fan kit
HT oil cooler
CRT
Hi flow water pump
TT kickstand
Scotts SS oil filter
Cycra handguards
KTM hardparts Skid plate
P3 header protection
Scotts sterring stabilizer
Baja Designs Squadron lED lighting
During its last outing.
This bike is used primarily for multi day/ multi week long off road rides throughout Thailand, Lao, and Cambodia. I also outfit it with a complete SM set-up, radial brakes etc for fun at the go kart tracks and thrashing the canyons.
My question is will this bike last a few more years or is it time to get the 500? Small things like electrics getting corroded are starting to appear and my concerns are am I vulnerable to components failing that I will not expect due to the hours on the bike. Ie Gearset failures, oil pump gears, blah blah. You know things you don't think about wearing out but may fail over time. Is this a rational concern? Has anybody had failures such as these?
I live and ride where I need to trust my bike absolutely. The 500 is an unknown but realistically the only thing I fear on the engine is the FI.
The suspension and brakes on the 500 will be better but not sure about the motor compared to my 570. The 500 will flick side to side easier through tree's but since I'm usually carrying 25 pounds of gear strapped to the bike will it be enough benefit for me to notice it once loaded up?
Curious on your thoughts.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 08-21-2012, 10:42 AM   #4080
dentvet
Oddometer: 1,371
I would stick with the devil that you know.
also, I don't want to have to look in the 500 thread to see your photos
dentvet is online now   Reply With Quote
Times are GMT -7.   It's 06:17 PM.
