Old 09-10-2012, 09:06 AM   #4171
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
CB, you figure out anything about the cooler / TT stator interference?
none of us are as dumb as all of us
clapped_r6 is online now   Reply With Quote
Old 09-10-2012, 09:25 AM   #4172
hizzo3
Oddometer: 32
Originally Posted by clapped_r6 View Post
thanks. i'm thinking i want to put on the TT 100w stator, ht racing cooler, and spal fan kit. i think i'd rather have it on a thermostat than having to remember to turn it off!
In the Jeeping world, we use a thermostat with an override switched with a 5 minute timer set up for when the ignition turns off. While that may seem overly complicated for a DB, it has its uses.
Sent from my Galaxy Nexus using Tapatalk 2
hizzo3 is offline   Reply With Quote
Old 09-10-2012, 09:40 AM   #4173
yondering
yondering's Avatar
Oddometer: 1,072
Originally Posted by crazybrit View Post
you can use a thermostat with a pc fan ....
That's what I'm doing. $15 temp switch from NAPA threads right into the bung on the KTM radiator. The PC fans are cheap enough to not worry about breaking them. I have a list of part numbers for this stuff if anyone needs them.
yondering is offline   Reply With Quote
Old 09-10-2012, 09:41 AM   #4174
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
i also just noticed that safari makes a 4 gallon tank for the exc? although spendy, i think safari makes a really good product. i had resigned to keeping my 3 gal. clarke for most things, and then picking up a 6.6 acerbis for remote stuff. the problem is, i don't NEED 6 gallons for that (i know i don't need to fill it up all the way!)
anybody running the 4 gallon safari? 4 gallons sounds about perfect. any unusuable fuel in that setup?
Old 09-10-2012, 12:33 PM   #4175
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
another q i couldn't find:
i *think* i want to run 14/48 for general use, but am going to pick up a second wheelset for straight up dirt (rimlocks, bigger knobs). i've heard about people running different gearing with the same chain (flipping the axle blocks?). what will fit? i'd rather not change the front out all the time, i'd think if a 52 would fit that'd be the way to go?
Old 09-10-2012, 12:44 PM   #4176
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 41,608
I run a 14/51, and sometimes switch to a 15 c/s sprocket, and flip the blocks. The 15 will just barely fit, but it works.
Hayduke is offline   Reply With Quote
Old 09-10-2012, 01:08 PM   #4177
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,496
i am running a 14/52 for singletrack riding and i have a cush hub rear wheel with a 48 for long trips/pavement/open desert riding and i just flip the blocks.
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE LINK
www.RAZR.whereamiriding.com
RAZR is offline   Reply With Quote
Old 09-10-2012, 01:18 PM   #4178
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
sweet. that's exactly what i wanted to hear!
Old 09-10-2012, 05:07 PM   #4179
blake716
_____________
blake716's Avatar
Oddometer: 3,499
Which under fender should I replace my stock one with?
I was looking at Sicass and Baja Designs. Is one better than the other?
_________________________
blake716 is offline   Reply With Quote
Old 09-10-2012, 06:02 PM   #4180
crazybrit
crazybrit's Avatar
Oddometer: 8,040
I guess I'm not 100% what you mean by "under fender" or what your replacement goal is. Are you referring to the number plate carrier and switching away from the "long" US one?
I just used the short ktm one (the 05 parts fiche shows both long and short, $21 each). You can reuse the bulb, just need the euro lamp holder ($3.84), plastic lens ($7.01) and the mounting lens screws. A guy over at ktmtalk classifieds sells the short with an LED light mounted. I'm sure both the companies you mention sell one too but I have no experience.
Apologies, if this isn't answering the question.
crazybrit is offline   Reply With Quote
Old 09-10-2012, 06:44 PM   #4181
blake716
_____________
blake716's Avatar
Oddometer: 3,499
Yes, the part that holds the license plate.
I'll checkout KTMtalk. Thanks
Old 09-10-2012, 06:46 PM   #4182
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
i just looked, pretty slick. the PO of my bike hacked the "long" version down, i'm going to see if i can modify it to my liking. if it sux, then the "short" will be on my short list
Old 09-11-2012, 08:56 AM   #4183
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,334
Send a message via AIM to CodyY Send a message via Yahoo to CodyY Send a message via Skype™ to CodyY
I use Sicass assemblies
Not an ACTUAL motorcyclist
CodyY is online now   Reply With Quote
Old 09-11-2012, 04:17 PM   #4184
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,185
Baja Designs rewound "130 watt" stator DC system, OR
TrailTech new "100 watt" stator DC system.
which did you / will you choose, and why? max reliability of increased wattage is the goal.
go.
Old 09-11-2012, 04:35 PM   #4185
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,772
Ive got the 4.1 Safari tank on my 2011 530,so far no problems,easy to mount up,not overly wide at any point,the gas cap threads on easily which is more then I can say for other plastic tanks Ive had. The stock KTM petcock went right on the Safari tank no problem,no leaks. I would say its the right size for what I do. I can stick the stock tank back on if Im strictly local trail riding. Safaris are pricey but its the only 4 gallon tank for these bikes I could find.I like it! The fuel seems to splash around and get used just fine.
6.6 is TOO big unless your absolutely going survival style desert riding.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is online now   Reply With Quote
Times are GMT -7.   It's 03:12 PM.
