Old 10-04-2012, 05:53 PM   #4276
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 311
Originally Posted by skibum69 View Post
fixed
Now you're just going to confuse averyone with that Frenchy stuff And I don't know nothin about no musical instruments either
I'm not day dreaming, I'm prerunning
21 days exploring Baja
http://advrider.com/forums/showthread.php?t=922187
Moto Vaquero is offline   Reply With Quote
Old 10-04-2012, 09:20 PM   #4277
bhorocks
bhorocks's Avatar
Oddometer: 346
Originally Posted by B-Rod View Post
Holy cow! I want to see a night shot of those things in action. Night ice racing this winter anyone? Nothing like blinding your competition.
Really want to get it out for some night shots but had to go out of town. When I get back I'll provide!
bhorocks is online now   Reply With Quote
Old 10-04-2012, 10:15 PM   #4278
Bungholio
Bungholio's Avatar
Oddometer: 708
Originally Posted by selaznog View Post
A lot of guys, myself included, put the fan on a switch to have more control over the power draw.
Exactly what I did on my 530 since the thermo switch supplied with the fan didn't work.
Bungholio is online now   Reply With Quote
Old 10-05-2012, 08:38 AM   #4279
espressodrinker
Cape Town Wanderer
Oddometer: 199
12 volt domestic LED lamps
I was looking in a lighting store today and they sell Osram 4 watt 12 volt A/C LED lamps for down lights.
Now I know that the stock headlight is A.C. and nominally 12 volt, so would this work as a spotlight globe?
If the stator is giving out single phase power, than at 3600 rpm the frequency would be 60 Hz, so a lot of the time the globe would be running at very high a/c freqquency, but would it matter?
The specific globe is
Osram LED STAR MR16 20 25.
Just for a laugh I put one across the headlight and it seems to work fine.
Don't know how long it will last though because I think the stator isn't very well regulated. I measured 30v A/C across the headlight !
espressodrinker screwed with this post 10-05-2012 at 08:41 AM Reason: added line
espressodrinker is offline   Reply With Quote
Old 10-05-2012, 02:59 PM   #4280
BHW
BHW's Avatar
Oddometer: 4,128
2005 525 EXC....things to look for, avoid, etc for that particular model?
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 10-05-2012, 05:05 PM   #4281
Moto Vaquero
Trail less traveled
Oddometer: 311
This is a great bike and the frame was upgraded to the oval tubing in '05.
There is an issue with the starter gear aka idler gear for that year only that should be switched to '06 parts.
There is also a shifter locking lever that has ball bearings in it (they all had this until '07) that should be changed out with the one that has no bearings as it can disinigrate and put little ball bearings in your gear box and ruin your day.
These are both easy and inexpensive to do but are very important.
For more info go to ktmtalk and search in the rfs section, lots of info.
Moto Vaquero screwed with this post 10-05-2012 at 09:50 PM
Old 10-05-2012, 06:35 PM   #4282
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,966
There is also a shifting lever that has ball bearings in it (they all had this until '07) that should be changed out with the one that has no bearings as it can disinigrate and put little ball bearings in your gear box and ruin your day.
The Locking lever thread is here.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 10-08-2012, 06:24 AM   #4283
Jaronimo
Jaronimo's Avatar
Oddometer: 115
hey all, Ive got a question about the display unit, mine has completely packed up, the sunlight has blackened one corner, my current display is in klms, and I am looking at a second hand display out of the US which is obviously in miles, is there a mode where you can switch the settings? as I bought the bike with the damaged screen ive never really worked out how to use all the buttons/modes?
any help would be great
current bikes : 01 XR 650R and 03 ktm 525exc, I cant decide one has to go, arraahhgg Both went I now saddle a Berg fe 570, beastie
Jaronimo is offline   Reply With Quote
Old 10-09-2012, 05:58 AM   #4284
400psi
Cropdusting
400psi's Avatar
Oddometer: 491
Quick question that may have been answered elsewhere but do you guys reset your suspension sag, or change springs, to accommodate the extra fuel and camping gear or just load up and go? I am at the top range of my spring rate for set up. (04 450 exc?)
I'm so far behind I think I'm in first
400psi is offline   Reply With Quote
Old 10-09-2012, 06:52 AM   #4285
jeventures
Oddometer: 228
Yes.
My EXC450 and 950 ADV are able to display in both miles and km. The manual for my '06 EXC tells you how to do this...should be the same for yours.
Every man dies but not every man lives.
jeventures is offline   Reply With Quote
Old 10-09-2012, 09:20 AM   #4286
yondering
yondering's Avatar
Oddometer: 1,100
Don't change the spring rate, but add some preload to correct the sag.
yondering is offline   Reply With Quote
Old 10-09-2012, 10:02 AM   #4287
400psi
Cropdusting
400psi's Avatar
Oddometer: 491
thanks for the info
Old 10-09-2012, 04:42 PM   #4288
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,477
I tried to get from Attapeu to Pakse (Laos) via the southern route, down near the Cambodian border on the weekend.
Didn't make it... drowned the bike, flattened the battery, pushed it a ways and then left it on the track for 24 hours while I walked out to get the battery charged.
This was the easy bit, going in
Wrecked my best.... and only.... pair of riding boots trying to kick start it... then had to walk 5km in them... through swamps and mud. I think I'll be riding in my shoes soon
Lotsa cute girls in the village
Fresh food too. Mostly rats with one squirrel
Had to throw the oil away after only 3 days. Bugger
Last time I had to carry a KTM, it was the Super Enduro... and it was easier than this time. Thick sticky mud, a couple of short, skinny local guys and a slightly built woman and a kid. Still we got it through, dry.
For once, I'd have been better on the Super Enduro. It'll go through water and slop at least a foot deeper than the 525. Its intake is via a snorkel right up under the filler cap and its plugs are well sealed. Between the bike and the village there was at least two more spots that'd drown the 525... or require a long carry, and I was told there was a lot more further on, so I turned back. My visa expires tomorrow, so I couldn't risk an extended stay out there. I'll do that road next trip.
I eventually got back to Attapeu and made Pakse via the middle route over the mountains, through Paksong. Some interesting riding in there, over pretty major landslides that have stopped anything other than bike traffic getting through
Not the most stable road I've ever been on. That's a landslide waiting to happen.
I've got a new tyre coming in overnight on the bus... an IRC 110/80/18. Woo Hoo....
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 10-14-2012, 02:23 PM   #4289
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,502
wow, I have nothing else
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 10-16-2012, 04:14 PM   #4290
blake716
nine toes
blake716's Avatar
Oddometer: 12,680
Originally Posted by The Bigfella View Post
Is your Giant Loop the Great Basin or the Coyote?
I'm planning on ordering one this week, but I'm not sure which one to get.
_________________________
blake716 is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
